GE medallion 850 washer leaking water at bottom
4 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Washer leaking
There are several things that will leak under a GE washer. The the usual suspects are drain hose connections, or hoses that have cracks or holes. I would inspect the hoses first as this would be the easiest fix. The other thing that can causes problems is the wash tub seal on the bottom of the tub. If the spanner nut (under the agitator) comes loose, the seal will unseat and the tub will begin to drip (I've had this one happen to me). Another cause can be the wash tub itself (I've also experienced this one). Inspect the wash tub for cracks. The tub can develop stress cracks and begin to leak. Especially if this is a washer that was involved in a move. To access the inside of the machine, the front should come off by pushing under the front lip of the machine with a putty knife. There are metal clips that hold the front to the top. Look in the crack with a flashlight to locate them. Push in with a putty knife to release and the front should just come off. I hope this helps you.
Posted on Jul 06, 2007
JULIANFIX
  • 975 Answers
SOURCE: Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Posted on Apr 22, 2008
jtate9
  • 68 Answers
SOURCE: GE WJSR 1070A Leaking
It sounds like you have a leaking pump. The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Please rate this solution
Posted on Jul 29, 2008
I need a thermostat and an element for a GE Medallion 850 Electric dryer repair man told me we can no longer find parts for this model it's too old. Anyone know of a website i'm having no luck.
Try calling GE Appliance Parts at 1-877-959-8688, or Sears Parts Direct at (888) 930-1491. If they don't have the parts, you probably are out of luck.
Apr 02, 2015 | GE Dryers
GE Medallion 850 Frige does
Can you please explain the issue in detail?
Oct 05, 2008 | Refrigerators
My GE topload washing machine is leaking
Check the hose that connects to the bottom of the tub to the drain hose. Make sure that hose is securely fastened.
May 29, 2012 | GE Washing Machines
Dryer heats to proper drying temperature and then temperature is not maintained and drops off causing long drying time when on timed drying...GE Medallion 850 - bottom heat sensor was cleaned.
you didn't mention if dryer was gas or electric. gas dryer could have bad valve coils which will work for a short time and then fail, cool off and then work again and fail, causing intermittant heat.
May 05, 2010 | Dryers
1 HAVE OIL ON THE FLOOR BENEATH MY MEDALLION 850 WASHING MACHINE THE UNIT IS STILL WORKING
Possible causes are seals gone on drive shafts allowing water into the gearbox and thereby pushing oil out of the breather (Oil floats on water )
Or a crack in the gearbox casing
Oct 27, 2009 | GE WBSR3140DW Top Load Washer
My GE dishwasher is leaking water from the bottom of the machine
first check to make sure door gasket is ok, if bad, replace and test. Make sure to remove bottom front panel during a test and inspect the motor and motor gaskets. It may be leaking here, replace leaking components as needed.
Jul 01, 2009 | GE 24 in. GLD6200L Built-in Dishwasher
GE Medallion 850 oven self-clean instructions
how do i work the oven section i don't understand the settings
Oct 26, 2008 | Kitchen Ranges
GE Top load washer.
Hello rschneeweis
Welcome,
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Huuum
Please remember to leave a rating
Oct 04, 2008 | GE WBSR3140D Top Load Washer
Washing Machines Logo
531 people viewed this question
Top Washing Machines Experts
