Question about Samsung CLX-3160 All-In-One Laser Printer
Printer stays in off line mode
Do not know how to get printer back to on line mode
Worked. Thanks alot!
Posted on Mar 12, 2009
  • 45 Answers
Hi CoachGlennBr!
Try to right click on the printer in printers and faxes and select use printer online.
Posted on Oct 10, 2008
Document stuck in queqeu cannot print tried changing line tried on off. help c4280
If you are using it witha computer you need to go to the printer section and delete all the documents from the print queue.
Mar 15, 2015 | HP Photosmart C4280 All-in-One InkJet...
How can I reset my printer to stay in portrait mode. It keeps going back to Landsape Mode automattically.
Before making a print job make sure its on Portrait mode.<> Go to Printers select your model and specify Portrait mode.
Jul 25, 2014 | HP Deskjet 3510 e All in One Inkjet...
Epson workforce 600 blurry 5th line
Update: Blurring of every 5th line occurs in text mode but not text & image mode. Know of a way to see text & image as default for all print jobs?
Aug 18, 2012 | Epson WorkForce 600 All-In-One InkJet...
Entered power saver mode how do I get it out of that mode
The power saver mode is a Lexmark X5650 feature that allows you to save electricity when the printer's not being used. That can be configured in the Device Setup in Settings. Adjust it on how long you want the printer to stay on before going on power saver mode but it can't be turned off. When the printer is on power saver mode, press and release the power button to power back on. Hope this helps.
Jul 15, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
My Dell All-in-One 924 Printer stays in copy mode
hi  s_witt212  :
u can rest assure ., cause the default mode onthe printer is : mode -copy .
all dell ink jet printer model s have that as the default option .
the other modes are mode scan and mode fax .
u can choose any mode based on ur need .
hav a gooday !
Jul 25, 2009 | Dell 924 All-in-One InkJet Printer
Zebra LP2824 not printing
Sounds like you put your printer into line mode. Line mode prints code so you can see what is sent to the printer to look for possible mistakes in the code.
To switch from line mode back to page mode.
  1. Turn printer off.
  2. Press and hold the feed button down. And switch printer on.
  3. Release the feed button when the LED flashes red.
  4. When the LED flashes green, press down the feed button.
  5. When the LED flashes amber release the feed button.
  6. Try printing now that the printer is back in page mode which is used for print your labels; line mode prints the labels code.
  7. Do this fast or else it wont work if you are slow.
Jan 13, 2009 | Zebra LP 2824 Printer
161 fatal error C7300
Try this - WARNING - will reset everything to factory defaults
The machine must be put back into "Shipping Mode" in order for the consumable counters to reset.
In order to place the printer back in "Shipping Mode" do the following:
0.27c?openelement&fieldelemformat=gif
1. For the C72/74/92/94 models, hold the (1) and (5) keys down, for the C73/75/93/95 hold (0), (1), (6), and (7), while turning the printer power on. (Hold until "MAINTENANCE MODE" is displayed)
2. Press (0) five times until "ENGINE DIAG MODE XX.XX" is displayed.
3. Press the (2) and (4) keys simutaneously, "ENGINE DIAG LEVEL 3" should now be displayed.
4. Press the (5) key once, "LOCAL PARAMETER SET" should now appear on the display.
5. Press the (6) key three times until "FACTORY WORKING MODE" is displayed.
6. Once "FACTORY WORKING MODE" is displayed, press (3) once so "Shipping Mode" (Fuse Cut Enabled) is displayed in the bottom line.
7. Next press and hold (3) & (7) together, until "Shipping Mode" stops flashing.
8. Power the printer off and back on, now the printer will reset the consumable counters. ecblank.gif ecblank.gif ecblank.gif
Aug 30, 2008 | OKI C5300n Led Printer
Help! Cartridge keeps going back and forth then shuts itself off
Stop your pain and replace, printhead is stuffed too expensive
Faulty cart (I assume you have relaced both with new) too expensive,
Board fault too expensive to fix.
 I know you bought a new cart but you are throwing good time and money after bad, get a new one with a warranty and new inks, don't compromise product with refills, enjoy hassle free printing...
I guess that this machine has in the past had dodgy ink running in its vains and now it showing the signs of it
 ........but there is another possibility, printers have a thin plastic strip on them that runs the width of print area.
This strip has lines on it and the printers head reads these lines to know where it is. This strip can get dirty (usally from refilling), you could try cleaning it gently with metho and a rag
(some inkjets use disc on side of machine instead)
Nov 01, 2007 | Lexmark X3470 All-In-One InkJet Printer
Hp laserjet 4 plus printer, message window "Ready", off line button shows red
You can try to do a "Cold reset"
turn off the printer hold down  the Menu/reset button and turn it back on.
Do you hear the machine go into rotation? the 4 plus has a high pitch sound follwed by the fuser turning ( you'll know when it does it) if it doesn't go into rotation then there is another problem.
Oct 13, 2007 | HP LaserJet 4 plus Printer
Receiving incoming faxes
# Press the button to enter Fax mode. # Press . # Press the right or left arrow button to select [Receive mode settings], then press the button. # Press the up or down arrow to select the receive mode that best suits your needs(you probably want "FAX ONLY" When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only), then press . # Press repeatedly to return to fax standby mode.
Aug 07, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Samsung CLX-3160 All-In-One Laser Printer Logo
174 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
