Question about HP 49g+ Calculator
The calculator, hp49g+, will not turn on by pressing the "ON".
I bought an HP 49g+ calculator about two years ago. I don't use it very often, when I tried to press the "ON" key to turn it on, the calculator would not turn on.
Changing batteries did not help either.
  • 1 more comment
  • steve-00 Jan 12, 2009
    I have the same issue.
    If you do a reset 2 button command - it works but will not turn off again!
    [until a timeout period]
    Rgds
    Steve
  • GOLDENEAG70 Mar 29, 2009
    hp49g+, will not turn on by pressing the "ON"."
  • Anonymous Apr 03, 2009
    My "ON" button seems to have gone for good, doesn't works unless you press it really hard.
  • HP Master
  • 8,064 Answers
If batteries are fresh use a paper clip and insert it in the hole (reset) to the left of the serial number. Press gently.
Hope it helps.
Posted on Sep 10, 2009
Hi, if pressing on and F5 together immediately starts the selftest your keyboard is OK, but one of the capacitors on the HP49G PCB are broken. I replaced all three and the turn on/off problem was gone.
Hope this helps.
Joachim
Posted on Nov 20, 2009
HP 15C commas and decimals interchanged
Turn the calculator off, press and hold the decimal point key, press ON, then release both keys.
Apr 20, 2013 | HP 15C Scientific Calculator
Hi: I bought a HP 10bii Financial Calculator. I find it difficult to get a correct answer... For an easy example, I try to find the future value of $100 today after 3 years with an annual interest rate...
What you've done is calculate the future value after 3 months, not 3 years.
Press 1 SHIFT [P/YR] to set the payments per year to one. Now the FV key should give you 115.76
Feb 15, 2011 | HP 10bII Calculator
My son went to turn on his TI-84 Plus calculator and it wouldn't go on. He had used it in class a few hours before. We tried replacing the AAA batteries, but that didn't work. We tried replacing the...
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we can go on from there.
Feb 01, 2011 | Texas Instruments TI-84 Plus Silver...
How do I factor using the fx-115 ES calculator? would a problem like 9x^2+24x+16-Z^2 be solvable on this calculator? If not, does Casio sell any calculators that would help me factor this equation?
No, your calculator cannot factor polynomials. You need a calculator that has a CAS (computer Algebra System)
Yes Casio sells calculators with CAS: The FX-Algebra 2.0 and 1.0, the FX-9860GPLUS/GII SD, the GRAPH85 or 80 and the Graph 100+. You also have the CLASSPAD Series 300PLUS and 330.
TI and HP also have CAS calculators.
Texas Instruments
TI 89 /Titanium, Voyage 200PLT, TI92PLUS (discontinued), TI Inspire CAS.
Hewlet-Packard
HP 48G/G+/GX, HP40G, HP49G/G+ and the top of the line HP50G
Oct 28, 2010 | Casio FX-115ES Scientific Calculator
My for the TI 84 Plus Silver Edition screen doesn't work. I changed he batteries including the back-up. The screen won't light up. I bought this calculator around 3 years ago.
If that doesn't work, remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries.
If that doesn't fix it, please append a comment to this post and we'll go on from there.
Sep 12, 2010 | Texas Instruments TI-84 Plus Silver...
My HP 12C is displaying with a comma rather than a decimal. I don't know how this happened and don' t know how to rid of the comma and return to a decimal. Please help.
Turn the calculator off. Press and hold down the decimal point while you press ON. The digit separator and radix sign will flip each time you do this.
Jun 21, 2010 | HP 12c Calculator
My HP 48G does not come on.
Warning
In the keyboard test (below), make sure the keys are pressed in the right order. If the calculator fails the keyboard test then it needs repairs. (Ignore the begining of the post and skip to the last part For Repairs )
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the dagnostic tests.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  4. Release the [ON] key
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.-
For repairs
There is an HP customer self repair (CSR) which you can contact. On the site it is sais that the service is available for products under warranty or on contract. but you have nothing to lose by contacting them. Here is the link to the web site
You can also try this site. They do repairs on most models, except the newer ones.
Hope it helps and Thank you for using FixYa.
Do not forget to rate the solution.
Nov 29, 2009 | HP 48gx Calculator
Replace cracked LCD screen on HP 50g
It doesn't look good for being able to purchase the display as a part. I checked HP and the unit is not listed. I saw a 49G but no repair parts listed. you can research with HP at:
http://h20141.www2.hp.com/hpparts/part_search.asp?mscssid=1237E7A2A0D7420DB6F72ACEAF1A2FE3
Hope this helps
Mar 21, 2009 | HP 50g Graphic Calculator
When I turned on my 48gx a month ago some of the alpha keys did not work. Today most of the keys(alpha,numeric as well as functions) don't work. I've owned this unit for over 7 years and have barley used...
Before thinking of repairs, you should first determine if it needs repairs.
The following procedure valid for the 48G should work for the HP48GX.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Mar 04, 2009 | HP 48gx Calculator
HP48SX Battery drain
I suggest you use rechargeable batteries. They usually drain faster than the alcaline ones anyway.So have 2 sets of rechargeable batteries. Evaluate the number of days a set lasts. Insert the charged batteries before the old ones are thourougly drained.
The life of your batteries in the calculator depends on the usage.
About repairs: I am convinced that it will cost you more to have it fixed than to buy a new HP calculator (HP 49g*'s, HP 50g* 's).
Hope it helps.
Nov 13, 2008 | HP 19BII Calculator
HP 49g+ Calculator Logo
530 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
