How do i connect the ps3 with a panasonic tv - Computers & Internet
  • 23 Answers
Make sure your Panasonic TV is HD-READY, you can find them in sale at any TV shops now, you can check to see on your current TV if it is HD compatible by looking at the front of your TV and see if it has the words HDMI or HD Ready written somewhere. If it doesn't, then you can't play your Playstation 3 with the HDMI plug that is given to you with the console.
If not, just plug the AV cables in and you'll be good to go, just it won't be in High Definition.
Posted on Oct 10, 2008
Why wont ps3 play out of hdmi port or input connections on Panasonic PT-61LCX65?
becaue you need to enable hdmi on the setting of your TV and perhaps you also need to adjust to the same HDMI value in both PS3 and TV Menus
Apr 01, 2015 | Panasonic PT-61LCX65 61" Rear Projection...
How to connect a ps3 to a panasonic sc-btt190 home theater
My suggestion would be to use the ps3 to connect to TV using hdmi & then use an optical audio output (toslink) from TV to the btt190... You would think they would have one or two hdmi connections there but no they have none.... This is how I connected appletv to the btt190.... Works fine you just have to set tv input to appletv and btt190 input to >>ext in >> digital in....
Good luck. Btw have you connected to network? Did you have any troubles - mine will not connect via cat5 cable...
May 19, 2013 | Panasonic Sc-Btt190 Home Theater System...
Ps3 hook up to panasonic PT-53WX54J
If none of the connections on the set work look for a menu on the unit in the owner manual for the PS3---it may be a selectable setting in that that is causing this problem--also try the PS3 on another set to make sure it is ok.
Jun 15, 2012 | Panasonic PT-53TW53 53" Rear Projection...
Cannot connect my PS3 to Panasonic TV via HDMI, my PS3 will connect to other HD TVs using HDMI but not Panasonic
Does your TV work on VGA, it maybe worthwhile getting a HDMI---VGA lead and try that as it sounds like your TV isn't working, and you've tried the obvious. Do any other HDMI devices work on your TV, like DVD HD/SAT?
Apr 22, 2011 | Televison & Video
Trying to hook up PS3 to Panasonic viera LCD hdtv with HDMI cable and tv is not reading it and has no picture or sound. What may be the problem? Thanks!
hi,
ur ps3's HDMI out is a full hd video (1080p). if u r tv does not support full hd this problem can occur. do one thing. connect the ps3 to any full hd tv and go to its video setup, then down scale its video resolution to 1080i. after that connect the ps3 to ur tv. u will surely get video.
ok
Jan 11, 2011 | Panasonic Viera TC-L32X1 32 in. LCD HDTV
Ps3 is connected to sony bravia lcd with hdmi cable. also connected to tv is panasonic HHD dvd recorder. whenever ps3 is turned on dvd recorder cannot pick up tv channels and therefore cant record
Thats in your routing of the wires. The way the PS3 is set up it takes precedence, and there is really no way around it. You have to turn off or disconnect the ps3 while trying to record.
Sucks.. but its the way it is.
May 06, 2010 | Sony Playstation 3 (PS3) Console
Linking up Plasma,PS3, and Receiver
If your tv and reciever have optical audio (square-ish hole with a red light), that would be the easiest way. Just get an optical audio cable and plug it into the optical out on the tv and into the optical in on the Sony.
Dec 30, 2008 | Panasonic Viera TH-50PZ80U Plasma TV
How to get surround sound workin with ps3 and tv
you have to select the dolby surround button from the remote to get the sound
Dec 25, 2008 | Panasonic Home Theater System System
I just brought a plasma tv and how do I hook up my cable tv and ps3 to it?
standard cable, just hook it to ant 1 or 2...your ps3 should have an hdmi connection, looks like an oversized usb cord. hook your ps3 into hdmi 1 or 2 or 3, doesn't matter. then switch your inputs on the tv accordingly.
Jul 11, 2008 | Panasonic Televison & Video
Computers & Internet Logo
David Payne
David Payne
