Question about Xerox FaxCentre F12 Laser Printer
Xerox F12 FAx Machine
On the display screen is:
Please Wait.....
Printing
There isn't anything printer at this time. I have cycled the power on the printer, made sur ethe connections were fine, changed out the drum ( worn out), I have made sure the parts were in there really good.
Someone was sending a fax, the fax was sent successfully but when this display came up about printing the transmission of this job this is where everything stopped.
Please advise
  • msanchez Oct 10, 2008
    This did not resolve the issue, when trying to clear the msg or trying to print.
    This is what has been done so far:
    1. Cycling the power
    2. Unplugged the power for 30 minutes
    3. Cycling the power then holding down the start button which placed this into Diag, mode, but still not being able to print anything out.
    Please let me know of any other options you may think of
    President:
  • 2,072 Answers
You will have to perform a memory clear . Here are the steps, but after doing this you will have to re enter the fax ID and phone number, also you will have to reset the power save mode to where ever it is now.
Here ya go.
The Clear System Data Memory option restores all the user-selectable options to the factory defaults.
  1. Press the [Menu / Exit] button on the Control Panel.
  2. Press the [Up] or [Down] arrow button repeatedly to select [Memory Clear].
  3. Press the [Enter] button.
  4. Press the [Left] or [Right] arrow button to select [Machine Setup].
  5. Press the [Enter] button.
  6. Press the [Left] or [Right] arrow button to select the required option: [Yes] or [No].
  7. Press the [Enter] button.
  8. Press the [Menu / Exit] button to return to the previous menu.
  9. Press the [Stop / Clear] button to return to the Standby mode.
Posted on Oct 10, 2008
Xerox workcentre 3325: What do you do when you are having lines on copies when using the top feed?
NO NO NO.
Don't rush things. If you don't know how a laser printer functions, please don't touch anything. Let someone with knowledge clean the machine. Rubbing the wrong roller, can damage the printer bend repair.
Only clean the parts you are allowed to clean. Like removing dust on places outside the printing area.
Jul 15, 2014 | Xerox WorkCentre 3325/DNI - multifunction...
Hi, I have a Fuji Xerox 3200MFP. I can fax with no problem, scan with no problem. But I can not print or copy - anything that requires printing. The Status Window gives me "Printing... Please...
Most likely it's the driver. Try going to the Fuji website and see what drivers are available. It's possible that the driver your using isn't designed to work with your operating system (such as designed for Windows XP and your now using Windows 10, etc.)
Jun 16, 2017 | Xerox FaxCentre F12 Laser Printer
The LCD screen keep displaying "Printing" but
I have seen this so many times I thought I would post an answer on this so you can repair your Brother MFC series machine that says printing and will not function. Using this procedure will save you from having to call out a service technician. Any time your machine says "printing" and will not do anything simply turn off the power. Now hold down the red clear/stop button WHILE turning the power back on. Continue holding the clear key for a few seconds then release. Your "printing" message should be gone and your machine should be back at the ready screen.
Good Luck and Thank You for using Fixya!
WheatlandServices
Dec 16, 2010 | Brother MFC-8220 Fax
LSU error in XEROX workcentre pe220. What is the
R/sir,
I have a Fax machine of Xerox make model PE220.From BSNL line connectivity is allways out of order.I want to connect FIXED CELLUR TERMINAL (FCT).After conecting machine give dial tone for outgoing calls.and other end caller received a fax tone on their machine when they want to make a call on my machine.But printer is not printing after some LCD diplayed a massage communication error.Kindly GUIDE me for change in settings.
Thanks and regards
PK Jain
(Pennywise)
Dec 15, 2010 | Xerox WorkCentre PE220 Series
Screen reads "printing...please wait"
If this machine has memory boards on the back, turn off the machine and take the boards out.
turn on the machine, and reinsert the memory boards.
Sometimes these boards lock up the machine.
If this does not work, the fuser may be the problem.
Oct 28, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Error code 117-363 printer starts machine is awake
only see error code 117-363 and not permited other option
Nov 26, 2009 | Xerox 6180MFP/N Printer
Xerox phaser 6180 mfp error code 133-290
Before attempting to resolve the error 133. -290, print a copy of the configuration report on the copier / fax. Use the navigation on the front panel to access the configuration menu to get the impression. Review printing to make sure it understands the network settings. This is a protection against configuration settings being lost when you troubleshoot.
Clearing Memory reset the memory of the Xerox Phaser 6180MFP, Dell 3110cn or Dell Machine 3115cn to erase the stored contents and eliminate corrupted data. Disconnect the analog line and power cord from the printer. Wait at least 10 minutes. Then reconnect the analog line and the power cord. As the machine starts, press the "All Clear" "Stop" buttons to prevent automatic printing of the status page. Check the error display panel 133 to 290 times the machine is fully initialized.
Corrupt Adjustmen
Jun 20, 2009 | Xerox 6180MFP/N Printer
Will not print fax's
1. Unplug the fax machine from the power outlet.
2. Press and hold the "Stop/Exit" key, then plug the power cord back into the power outlet.
3. Continue to hold the "Stop/Exit" key for 5 seconds. The display will return to date and time.
4. If the display does not return to date and time, please repeat the process to make sure the procedure was completed correctly.
May 20, 2009 | Brother IntelliFAX 5750e Laser Fax
In Xerox PE 220 I could not receive my fax
YOU MUST CHANGE THE CHIP BECAUSE WHEN THE MACHINE SAYING THAT THE TONER IS EMPTY ALTHOUGH IT IS PRINTING IT DOESN'T PRINT THE FAXES
Apr 04, 2009 | Xerox WorkCentre 220 All-In-One Laser...
Xerox FaxCentre F12 Laser Printer Logo
134 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
