The touch pad mouse cursor on my Dell Inspiron 4000 ME/OS IE6 has become overly sensitive and needs resetting. I looked everywhere to find how to do this. The problems are several: placing the cursor on the site to open it without clicking will open the site, also moving the cursor over info will hightlight the info without clicking, sites that I do not want to open may open because the cursor ran over the web sites, news sites, ads, etc. The problem occurred when I had serious problems when Earthlink(ISP) changed their Home page and settings. Of course, they said it was my PC"s problem. I had no antivirus or firewall on because of difficulty finding one that worked with ME. Slowly, the problems were being corrected. Earthlink finally sent me the CD Norton Internet security for ME and insisted that I install it immediately and that all problems would be resolved. I did and my PC developed very serious problems:(1) I could no longer access Earthlink email or hotmail email, (2)nor could I access any security sites either over the web, emails, or my accounts,(3) nor could I update any programs (4)and I could not get Nortaon Removal Tool sent because I could not access the email. Finally after 2 months and many calls, a master tech from Earthlink knew how to override the email problems and then sent me the link to Norton Removal Tool. I removed the software right away, and the above problems went away. Meanwhile Earthlink corrected their settings, but my PC was left with several readjustment issues. Could you help me with touch pad mouse cursor issue? Also the auto disconnect idle screen comes up saying that your PC willl be disconnected from the internet in so many seconds . Do you want to disconnect? How do I reset this to off? It is very annoying and the PC will disconnect in the middle of a email letter that I am typing orreading info on web,etc. Thank you Marilee marileekernis@hotmail.com
  • marileek Oct 11, 2008
    Thank you all for your quick response to my cursor problem. daisyq31 suggestion worked. Thankfully I did not have to go any farther.
    Could you tell me how to uninstall Macromedia Flash Player 8.022. On 9/28, I downloaded it for free from Brothersoft.com site; On 9/29 I found out that all the adobe/ Macromedia Flash Players v. 8.024 and earlier have serious securitity vulnerabilities and they are difficult to uninstall. I have had 5 correspondence with Brothersoft customer service as to how to do this. They would only send me a product info descriptions on how the product works and finally an add/remove instruction. I know how to do this. I believe it is interfering with the Internet Explorer functions for I often receive a screen saying THERE IS A PROBLEM WITH THE INTERNET EXPLORE AND YOUR PC NEEDS TO SHUT DOWN AND RESTART.The screen is frozen.I try to shutdown through SHUTDOWN, a WAIT AND END TASK screen appears. If the PC won't do this , I either CLOSE BY POWERING OFF OR CRTL+ALT+DELETE. I WOULLD LIKE TO LOAD FLASH PLAYER 9 which supposedly not a problem with Internet Explore.. Does my PC need ACTIVEX or ACTIVEX CONTROL? I thilnk EARTHLIINK (ISP) may have deleted it. HOW CAN I FIND IT? I have looked, but I probably don't know how. My PC is DELL Inspiron 4000 with P3 IE6 and standard dial-up connection.Thank you, MarileeK marileekernis@hotmail.com
    Problem Solver:
  • 9 Answers
Let me know if you've already tried this:
For your mouse, go to "Control Panel" and click on the mouse icon. Click on the "Touch Pad" tab. Make sure the "Tap off when typing" box IS checked. Click the "touch sensitivity" button and adjust to "low". Click "apply" and "ok". If you've already done this let me know.
As far as your connection, I understand you have earthlink? What type of connection/modem do you have? With this information I can help
Posted on Oct 10, 2008
  • Mary Cantu Oct 11, 2008
    I am glad that I could be of assistance! To uninstall Macromedia, follow this link: http://download.macromedia.com/pub/flash...
    The problem may have come from your security settings. After you have uninstalled it, If you want to try to reinstall, first Check to see if your security is at the most set on "medium". Also, there may have been previous versions that needed to be uninstalled prior to installing the updated version. Let me know if this helps.
    Thanks
    Genius:
  • 1,124 Answers
Marilee:
This issue can occur because of one of the below possibilities.
These may vary depending upon the type of mouse you have connected to the computer.
Mouse is not clean.
Optical portion of mouse is blocked.
Moisture or other material on finger.
Solution:
Mouse is not clean
Users who have an optical mechanical mouse (most common mouse for desktop computers) are likely experiencing erratic behavior because the mouse is not clean or is dirty. Information on how to clean the mouse can be found on our cleaning page.
Users who have an optical mouse are likely experiencing erratic behavior because a portion of the optical eye is blocked. Most commonly this is caused by a hair.
Users who are using a touchpad may experience erratic behavior because of moisture or other material on the finger such as lotion.
Mouse has been cleaned and still has problems
If cleaning the touchpad not fix the problem you can Go to your manufacturer website (dell) and download your touch pad mouse controller and reinstall that again in your computer.
Or try using and external mouse till you can fix the problem.
Please don't forge to rate my help! Thank you :-)
Pablo
  • 282 Answers
Try to reinstall your touchpad driver found here
I have a Dell Inspiron 1545 which has three problems, the battery discharges faster than when used by another computer of the same make, the screen lighting often blinks severally before it completely goes...
http://download.cnet.com/ccleaner/
run crude cleaner to get the flicker and speed the laptop up
get a new battery... if discharges too fast.. like less than 45 minutes
cursor jumping around.. watch your touchpad..
commonly you are touching the mouse pad during some keystrokes
you can set the mouse pad sensitivity downward under control panel--> mouse---> synaptics mouse pad sensitivity also
Jan 21, 2011 | Computers & Internet
I have a Dell laptop computer with Windows Vista Basic. The mouse on the screen has become very sensitive and sometimes it clicks on an item when it scrolls across the screen. How can I make it less...
  1. Right-click on the desktop and select Personalize > Mouse Pointers . The Mouse Properties settings window will open.
  2. Alternately, click Start and type Mouse in the Search field, and select Mouse when it becomes available in the program list. The Mouse Properties settings window will open.
  3. Select the Device Settings tab. Select the Synaptics TouchPad device and click Settings . In the Properties for Synaptics TouchPad window, expand the Sensitivity topic.
  4. Select the PalmCheck option to adjust the sensitivity of the touchpad to avoid erratic cursor movement caused by accidental touching of the pad during normal typing.
  5. Select the Touch Sensitivity option to adjust how much finger pressure is required to move the mouse on the screen and how responsive the touchpad is to taps.
Jul 12, 2010 | Dell Vostro 1000 Notebook
I need help disbling this touch pad
You need to look into the user information manual for that notebook to see if there is a disable function. If nothing else works, Place tape over the touchpad and that should help. Additionally, you can look at your mouse sensitivity settings in Windows under control panel and reduce the sensitivity of the mouse.
Jun 29, 2010 | ASUS Eee PC 701 Notebook
My touch pad is SUPER sensitive, when I type, my cursor ends up all over the place. I read up on hitting the f7 key, but I am totally computer illiterate. When you guys say hit the function key, do you...
From Dell:
Customizing the Touch PadYou can use the Mouse Properties window to disable the touch pad or adjust the touch pad settings.
  1. Click Start keyboar4.jpg , and then click Control Panel.
  2. Click Hardware and Sound.
  3. Click Keyboard.
  4. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad.
    • Click the Touch Pad tab to adjust touch pad settings.
  5. Click OK to save the settings and close the window.
Oct 06, 2009 | Dell Inspiron 1526 Laptop
Cursor jumping around when typing on a Dell 1530
It is most likely the touch pad...a way you can tell is if you have a USB mouse, turn off the touch pad and use the USB mouse...go to type and see if it still jumps around.
Sep 16, 2009 | Dell XPS M1530 Laptop
Eratic movement of cursor using touch pad
Sounds like you have a touchpad malfunction. If its an older laptop, I would recommend replacing it. Not worth the hassle of trying to install a new touchpad...
May 12, 2009 | Dell F3534 Touchpad
My Dell Inspiron 6000 notebook computer curser "jumps around"
I frequently have the same thing when using a Dell laptop. The problem MAY be with the touch pad. Without noticing it, my thumb touches the pad and away goes the cursor!
So try this: Open the control panel and go to mouse. Look at the top for Touchpad. There is a setting in there for sensitivity. Reduce the setting so that you need to apply more pressure on the touch pad to move the cursor. Test it a few times to make sure it is still functional before closing the control panel. Then try typing something in a word processor and see if it is any better.
Good luck, and please let me know if this helps.
~ Spoem
Mar 30, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron B130
Hello, this normally happens on laptops. I think that it is from the sensitivity of the touch pad. You would have to check the position of your hands when typing since when your finger happens to touch the pad unexpectedly, the cursor quickly jumps to where ever the mouse pointer is: As a result, whatever you type next will rather go there instead of your current position.
Hope that helps
Thanks
Nov 08, 2008 | Dell Inspiron B130 Notebook
Dell Inspiron 1526
your touchpad is just one case to sensitive. deactivate it by hitting "fn+ the tuchpad deaktivation key on your keyboard" and get yourself a mouse
Jun 22, 2008 | Dell Inspiron 1501 Notebook
Sensitive touch pad
Hi, click on start and control panel. go to mouse properties. Try to look for a tab that says either touch or touchpad. you can change the sensitivity settings there. however if this doesnt work, this could only mean that this is a physical problem with the toucpad. try to apply pressure on the outer side of the touchpad. if it moves, you're gonna need a replacement palmrest.
Oct 02, 2007 | Dell F3534 Touchpad
Computers & Internet Logo
185 people viewed this question
David Payne
David Payne
