Question about GE (JASHO97748) (3 Pack) Headset
I just bought a GE Portable headset with detachable MIC
I do not know how to get it to work. I have a HP Pavilion. I have the new VISTA software. I cannot get the microphone wizard. Do I need a updated driver? MY PC says that I have a Realteck '97. That is old.
What do I do.?
  • Anonymous Jan 27, 2009
    Purchased the headset to use the microphone and it doesn't work at all.
  • Anonymous Jan 30, 2009
    it still dosent work i tryed i have a hp pavilon8 10n
I had the same problem, but fixed it. All you have to do is:
(I have a Dell Laptop)
1. Go to the control panel
2. Go to the sounds, speech and audio devices
3. You are supposed to see the icon that belongs to your sound card (Mine is SigmaTel Audio), click on it
4. Activate the port where the microphone is connected, close
5. Configure your microphone as you normally would
6. It should work
Posted on Jan 03, 2009
Also using an HP Pavilion and Vista. However, if I plug the microphone directly into the port, it works. The problem is obviously in the headset itself.
The port is definitely activated, as my old mic worked fine.
Posted on Aug 12, 2009
  • dmusacchia Dec 26, 2010
    I also have this headset, and finally have it workinging perfectly on my HP Pavilion with Vista. I had trouble using it with Skype. I uninstalled and reinstalled Skype. Then, when I opened Skype, the setup/test screen appeared that tests the speakers and microphone. The default microphone setting did not work. I changed it to "Integrated Microphone Array.." and all's well!
My hp pavilion dv6000 speakers and mic are not functioning even headset
Have you tried installing the correct sound drivers? If not, go to:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3224050&lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=1842153
Then select your current operating system and select your sound drivers. If that does not work, it might be the speakers and mic connector aren't connected properly onto your board, your speakers and mic are faulty or your on-board sound is completely faulty. In that case take it to your nearest Laptop Repair Shop. If its under warranty, take it back to the shop you bought it.
Jan 29, 2013 | HP Pavilion dv6000z Notebook
I have an HP Pavillion dv2700 laptop with windows Vista. My mic was working fin until a few weeks ago, now no one can hear me on google voice or skype. I checked the mic settings and it is not muted and...
You can try going into device manager and find the device and remove it then reboot and let it reinstall the mic drivers. If that does not work try going to the HP site and see if a new driver is available and install it. The mic could have gone bad and you may have to buy an external mic.
Thanks for using FixYa
May 30, 2011 | HP Pavilion DV2910US Laptop
I have a compaq presario v3700 with windows xp.It has conexant high definition as audio. I plug in my headset. It works in terms of audio hearing on headset but u can also hear it on computer. Then my...
Don't think its the drivers, because you can hear audio.
Do you have your mic with your headset or separatedly? If with headset, maybe your headset has a physical switch where you can enable/disable mic (seen this feature on some Locitech headsets).
You can also check whether you have Mic muted in your audio control panel. Go to Control Panel, open Sounds and Devices and File - Properties if I remember correctly (sorry, I have Vista now) and put a check before Mic property to bring out the Mic volume level bar to see whether it's muted or not.
Hope this helps,
Tom
Nov 17, 2009 | HP Pavilion dv9000z Notebook
Having the same problem.
Well you just solved your own problem, I agree 100 percent on that.
Aug 12, 2009 | GE (JASHO97748) (3 Pack) Headset
Mic is not recognized
i have a GE 98980 headset and window vista wont reconize the mic but the headphones work fine. How do i get the mic to work?
Jun 02, 2009 | GE (98980) Headset
Hp pavillion dv6000 headphone mics don't work, external mics work
check external mic in another system.
update the bios of the sytem.
update drivers of sound cards
Apr 11, 2009 | HP Pavilion dv6000z Notebook
Logitech USB Mic/Headset not working with Vista
if you dont have any installation disk, well just download it from the internet. then install.
Mar 12, 2008 | Computers & Internet
Portable Headset W/Detachable Mic
First, double click on the volume icon located in the system tray. If you do not see the volume control for Mic, then you will need to make it show up by going to Options --> Properties --> Check the box labeled Microphone --> Click Ok. You should now be able to see the volume control for the Mic. Make sure that this is not muted and the sound is turned up.
Second, you must have a sound card installed in your computer that supports microphones. Please check with your cards manufacturer or PC manufacturer to make sure.
Oct 17, 2007 | GE EasyCam Webcam
Query regarding mic support in Windows Vista
Yes you do indeed need to have Vista Drivers, That said sometimes the XP drivers MAY work if they and the software are installed in XP Compatibility Mode. Vista has been a nightmare for us in the Computer repair industry... one can only hope that all driver issues are addressed in any service packs to come? I doubt it tho...It seems a case of out with the old and in with the new...wheather ya like it or not.
Aug 07, 2007 | Altec Lansing Stereo Headset with...
GE (JASHO97748) (3 Pack) Headset Logo
1,575 people viewed this question
Top GE Radio Communications Experts
eradiostore
eradiostore
J.D. Browning
J.D. Browning
Van Allen II
Van Allen II
Are you a GE Radio Communication Expert? Answer questions, earn points and help others
