Indesit washing machine
The drum is trying to turn but will not . (it will turn by hand). It then displays aflashing light on the Easey Iron button and the Door Lock button
  • paul cullinan Oct 11, 2008
    the belt is ok, on further investigation there appear to be the odd spark coming from the motor when it tries to start
Most likely a broken belt
Posted on Oct 10, 2008
HELLO MY WASHING MACHINE WM12X INTEGRATED INDESIT MACHINE WAS SPINNING AND WE HEARD LOUD BANG ... THE WASH FINISHED OK BUT NOW THE DRUM WHEN EMPTY SEEMS TO BE "CATCHING" WHEN SPINNING BY HAND. ...
open the back door try to remove the belt and then try to rotate the drum by hand if it stuck again you need to check if there is something between the drum and the chamber
Jun 10, 2011 | Indesit W 123 Front Load Washer
Hi there i have an indesit washing machine and the drum has just stopped turning even by hand thanks craig
If you cannot turn the drum by hand, then there are a couple of possibilities that come to mind.
1- it is possible the drum bearings have siezed up,, remove lower rear panel of washer, and remove the belt the drum should be free to turn.
If it does not, then it is either the main bearings, or there is something fast between the inner and outer drum..
2- if the drum is free to turn, then it could be the moior bearings seized up.
Mar 13, 2010 | Washing Machines
Washing machine not working
The lid switch/latch has failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 10, 2009 | Washing Machines
Severe drum? shaking and display lights flicker during spin cycle
Loose mounting points or broken pins. If not that then possibly drum shaft could be cracked.
Nov 10, 2008 | Indesit W 123 Front Load Washer
Indesit 1000 cycle starts but then lights flash
Check the filter which is under the white panel at the front of the machine(the filter is in the lower right hand corner). Unscrew the filter and remove it. Mine was blocked with loads of grease/limescale. I cleared it out and the machine is as good as new again. I cleared the system with half a packet of soda crystals put into the main drum (on its own without any washing in!) and did a wash at 90degrees. Its as good as new now. Good luck. CK
May 21, 2008 | Indesit W 123 Front Load Washer
Indesit WIL 163
Have you checked the belt?
Mar 06, 2008 | Washing Machines
WIDl126 - door lock and easy iron flash
worth trying this! make sure the drain hose is only down the waste pipe about 6 inchs, and up off ground level about 24 inchs ie. 2 feet.If that don't not work it could be faulty pcb board!let me know.bye,close,ire.
Dec 23, 2007 | Indesit W 123 Front Load Washer
Indesit WIL143S flashing lights
sounds like your power board is damaged. Did you get any washes out of it before it went wrong
Oct 08, 2007 | Washing Machines
Open Questions:
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
