Question about Kenmore Elite 45986 Front Load Washer
Kennmore Elite mod#11045087400
I keep getting a code FH which i have the followed what the manual says to do but the I still get the FH code. What do I do?
There is a filter at the bottom of the unit that sometimes needs cleaned. You have to take of the bottom panel to get at it. It looks like a cylinder and you have to turn it counterclockwise.
If there is water in the unit, be prepared for some to spill.
You will likely find change...pencils, pens, and so on in this.
I've owned mine for 5 years and just found this out in the last week...
Hopefully that will fix your issue ;-)
Posted on Oct 19, 2008
I had same problem and I PAID repair guy to come out and he cut off about a foot of darin hose off it was down in my drain to far (he said) and trap was sucking out water or some thing like that haven't had problem again
Posted on Oct 11, 2008
Why does my kennmore smartwash elite keeps beeping and fashing f 02 signal
Your drain pump can't drain all the water, so your drain pump has a cap on it to clean out the filter. Clean the filter and try again, if this code comes back, replace the pump. Good Luck
Aug 17, 2014 | Washing Machines
DU code for kennmore elite washer
I have the same problem. I replaced the lock latch and the code still comes up and note I I'm back to square one. Ugh I wish there was a way to disable the dash and reset it.
Sep 07, 2012 | Kenmore Oasis 4.6 cu. ft. Canyon Capacity...
My Kennmore elite quiet pak 2 washing machine stops in middle of cycle and flashes letters h and f
Hello & Welcome to FixYa
FH error is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
Kevin
Jun 20, 2011 | Washing Machines
Getting an FH error code during the cycle count down
The FH code indicates it is not detecting water fill at the flow meter. Since you say that the washer is filling okay, I would check the wiring between the flowmeter and the control board. A common cause of this problem on this machine is the wiring harness jiggling loose. Unplug and reseat the wiring harness and see if it clears up the problem. Also look for and clean out any corrosion build-up where the harness plugs in. Hope this helped and best wishes.
Aug 05, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3 flashing FH
The following link explains the "FH" error:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
This can be a rather tough one to figure out, even with the error code explanation. I would recommend unplugging the washer for AT LEAST 30 minutes first. This will reset the Central Control Unit (CCU). In many cases this is all that is required to correct momentary glitches with the unit. If the error code reappears, check your washer installation to rule out the easiest possiblities, first. This means checking to ensure you don't have a siphoning condition, checking your drain lines and checking to ensure your fill hoses aren't kinked or clogged. Read through the link thoroughly and let me know if you have questions. I hope this helps you.
Jan 09, 2009 | Kenmore 46462 Front Load Washer
Keeps flashing clean Kenmore dishwasher 665.17019401 need a new owners manual
i was trying to install my kenmore elite 665 dishwasher but i cant find the plug do they come with one? or were do i hook it up?
Sep 22, 2007 | Dishwashers
Kenmore elite front load washer
look for an error code on those washer it will be and f-02 something like that or HF FH it will have an f keep an eye out for that
Mar 19, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
119 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
