Pdf file hi i keep having a dialogue box appear on my laptop when i switch on or off it comes up with desktop nozzle check ,save pdf file as ...when i try to save it comes up with the message path does not exsit please verify the correct path was given.Your help in this matter would greatly be appreciated thank you amran
  • 849 Answers
It seems a virus activity, check with an updated virus cleaner.
Posted on Oct 22, 2008
How can I save my document when I can't find FILE on top left screen?
Their are still many more option available for the person to save the file that is given below:
1. You can press ctrl+s which will save your document. It is a shortcut for saving the file.
2. when you trying to close that file it will automatically ask for the saving the file, a dialogue box will appear and you press save the file.
Jul 17, 2017 | Top Computers & Internet
How do I run cleaning option -- won't print
Select something to print. Then go to FILE - PRINT and when the dialogue box appears, click to right of named printer on PROPERTIES. Then when that dialogue box appears, click on the MAINTENANCE tab and you can then click on Head Cleaning. Just make sure there is at least one sheet of A4 office-type paper in the printer, as when the clean has finished, you need to click on Nozzle Check. The printout will show if the nozzles are now working. Never do more than a couple of such cleans and always follow with the Nozzle Check printout - you can turn the paper round to use a fresh part - it only uses a small part of the paper each time.
Jul 17, 2015 | Epson Stylus Photo R1800 InkJet Printer
When i try to save excel files to desktop they aren't saving the latest version,...
I don't think your computer is having an issue with capacity. I don't exactly know what the problem is, because it could be many things. However, if you want your Excel files on your desktop that you keep modifying, you can make a folder on your desktop, and then save them into that. It may be a good idea to delete each earlier one when you save new ones. Hope this helps!
Oct 08, 2012 | Apple MacBook Air
I need to type a paper for homework but don't have a printer can I type and save?
Easy
Type your paper and then select File > Print.
At the bottom left of the print dialogue box there is a button marked PDF. click on it and select save as PDF, You will then get a SAVE dialogue box asking for a title and save location.
Save it to the desktop or to a memory stick but make sure the title has .pdf after the name as it may not print on a Windows system without it.
Nov 12, 2011 | Apple MacBook Laptop Computer Mac...
My files are created in adobe pagemaker now I want them to convert in jpg or pdf format how?
1. Save the Pagemaker document. If you don't do this before proceeding, a pop-up box will remind you.
2. Go to File>Export>Adobe PDF. A dialogue box of PDF options will come up.
3. Determine what you want to use the PDF for. If you are exporting for a specific print job, the printer will give you Distiller settings. Otherwise, in Job Name, just choose the settings that most closely meet your requirements: High Quality Print for a printout, Smallest File Size for a document that will be viewed online.
4. Click "Export." An "Export PDF As" dialogue box will pop up. Choose the folder in which you wish to save the PDF, and name the file. Check the "View PDF" box, so the PDF will open after it has been created.
5. Watch the dialogue box. It should show that Distiller is creating the file. When finished, the PDF document will open.
Good Luck!
John Vickers
Aug 13, 2011 | Computers & Internet
I own a brother mfc 7840W and want to scan to a word file then convert it to a pdf how would I do this?
hello there
first thing, scan the document and when you typed the filename below that box is option, you can select what extension name you want to that file select pdf and click save. be sure you have pdf reader or acrobat reader etc..
Thanks
Nov 13, 2010 | Brother MFC 7840W Printer
Hi, I cannot print a pdf file or that kind of attachment. Only Word can print. Adobe error shows up and want to shut down the program for protection. I never had the problem before. Just started.
Is it a file that you created in pdf format, or is it one that you have had emailed or attempting to open from another source? Some pdf files have protection put on them by the file originator to avoid the file being changed/printed. Here are some tips to try to get them to print for you.
  1. Open your computer's Internet browser.
  2. 2
    Type www.a-pdf.com/security/a-pdf-rr.exe in the browser's URL box to access the PDF restriction converter "A-PDF Restrictions Remover."
  3. 3
    Press the "Enter" or "Return" key. Your Internet browser will access the site's PDF converter file. A dialog box will appear on your screen--"Opening a-pdf-rr.exe."
  4. 4
    Click "Open" or "Run" to download and set up the program directly. Click "Save" or "Save As" to save the program's setup file on your computer for running later--use this option if you using a slow connection like dial-up. The program will download and set up on your computer if you selected the "Open" or "Run" option.
    If saving the file to your computer, navigate to the directory where you want to save the file to. Select the "Desktop" if you have a hard time locating downloaded files on your system.
    You do not have to access the A-PDF Restrictions Remover website again once the file starts downloading or saving to your computer.
  5. 5
    Double click on the "a-pdf-rr.exe" icon to open the program, if you selected the "Save" or "Save As" option.
  6. 6
    Click "Run" when prompted with the "Open File -- Security Warning."
  7. 7
    Click "Next." Click on the circle by the wording "I accept the agreement." Click "Next."
  8. 8
    Select the directory where you want to save the "A-PDF Restrictions Remover" file. The default is your "C:\Program Files\A-PDF Restrictions Remover" folder. Click "Next."
  9. 9
    Click "Next," "Install" and then "Finish." A-PDF Restrictions Remover will start automatically.
  10. 10
    Navigate to the directory where the protected PDF file is located.
  11. 11
    Right-click on the PDF file name. Select "Remove Restrict & Save As."
  12. 12
    Select a location to save the converted PDF file to. Click "Save." If you want to change the PDF file's name, enter a new name in the box next to the wording "File name." The protected PDF is now converted to a unprotected one.
  13. 13
    Double-click on the converted file to open it.
  14. 14
    Select "File," "Print" and then "OK" to print the unprotected, converted PDF file.
  15. Printing a Protected PDF By Taking a "Screen Shot"
  16. 1
    Open the protected PDF file2
  17. Press the "Alt" and "PrtScrn" keys together. The PrtScrn key is located on the upper right-hand side of your keyboard, if using a desktop computer keyboard. If using a laptop, the PrtScrn key is located above the "F10" function key.
  18. 3
    Open your computer's word processing program by clicking on the program's icon on your system's "Desktop" or from the "All Programs" menu.
  19. 4
    Press "CTRL" and "V" keys together to paste the screenshot into a blank document.
    If using a Mac, click "Edit," "Paste" from the main toolbar at the top of your word processing program.
  20. 5
    Click "File," "Print" and then "OK" to print the PDF screenshot. If the protected PDF file contains more than one page, press the "PgDn" key and repeat steps 2 through 5.
Oct 29, 2010 | Canon FAXPHONE L80 Laser
Hp officejet pro won't print pdf files
In order to print PDF file format grab CutePDF.
  • Visit cutepdf.com . Click "Free Download." A box will appear asking, "Do you want to run or save this file?" Answer with "Save." The download will begin. Download Ghostscript (see link in Resources). Look for "You Can Get the Free GPL Ghostscript 8.15 Here" sentence and click "Here." This download is required for the CutePDF program. Save the GPL Ghostscript file to your desktop.
  • Double click the "CuteWriter" icon on your desktop once your downloads are complete. Click "Next" on the Setup - CutePDF Writer screen. Click "I Accept the Agreement" on the License Agreement screen. Click "Install." The CutePDF setup will run. Click "No" to the CutePDF Writer Setup box that appears next that asks "Would You Like to Download the Converter?" You have already downloaded the converter. Once the setup is complete, a Readme.htm file will appear in your Internet browser. Read this file or print it.
  • Double click the "Converter" icon on your desktop (it will have a black "G" as its icon). Click "Setup" on the right side of the WinZip Self-Extractor converter.exe box. Another box will appear and then disappear. The setup is complete, and CutePDF is ready for use. CutePDF installs itself as a printer, and this allows any Windows program to create a PDF.
  • Open any Windows application like Microsoft Word or Excel. Open any document you would like to convert to a PDF file.
  • Click File > Print. Select "CutePDF Writer" from the Name List in the printer box. Click "Properties." Choose your "Layout" and decided how you want your page to print. Click "Paper / Quality" and "Color."
  • Click Advanced > Page Size. Click "Print Quality" and change the DPI. The bigger the DPI, the larger the file size of the PDF will be. If you are creating a PDF to be emailed, choose 72 DPI or 144 DPI. If you are printing this PDF, choose 300 or 600 DPI. If sending the file to a commercial printer, choose 600 or 1,200 DPI. For most applications, just adjust the DPI setting and leave the other settings alone.
  • Click OK > OK > OK. A "Save As" box will appear. Enter a filename for your PDF file and select the directory you would like to save the file to. Click "Save." Your PDF is done.
  • Oct 27, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
    I am out of ink for blue and yellow and just want to print in black (i have plenty of black) can i keep printing. It keeps prompting me before i can resume to replace empty ink cartiages. I really need to...
    Perhaps... when you click "print", and the Print Dialogue box appears, try checking the box "Print in Grayscale". It may work, it may not (it's your printer itself that is stopping the process, not windows).
    If it's not the standard Word/Excel type program, you can also trying "printing to file" through something like "PDF-Adobe PostScript Printer", which will "print" to a PDF... transfer to disk/flash drive, and head off to kinkos!
    Hope it helps!
    Sep 01, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
    My self rakesh,using 2007 microsoft word,how to convert the 2007 word format to 2003 format
    Convert a document to Office Word 2007 The Word Convert command clears the compatibility options so that the document layout appears as it would if it had been created in Word 2007.
    1. Click the Microsoft Office Button default.aspx?assetid=za100771021033, and then click Convert.
    2. In the Microsoft Office Word dialog box, click OK.
    3. Do one of the following:
      • To replace the original file with a file in the Office Word 2007 file format, click the Microsoft Office Buttondefault.aspx?assetid=za100771021033, and then click Save.
      • To save the original document in its original file format and create another document in the Office Word 2007 file format, click the Microsoft Office Button, click Save As, and then type a new name for the file.
      Note If the original .doc file is saved in a location other than your local drive, Word keeps the original .doc file and creates a new .docx file when you click Convert.
    Mar 14, 2009 | Microsoft Windows Vista Ultimate Edition
    Computers & Internet Logo
    32 people viewed this question
    David Payne
    David Payne
