SOURCE: bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
SOURCE: cant pair my bluetooth
To identify where the problem is, try connecting another bluetooth device (like another phone, or a bluetooth headset). The other device will most likely connect. If it does, try contacting the manufacturer of the dongle, they will probably have a simple solution to fix it.
If it does not connect to another device, try deleting the bluetooth devices stored in phone (especially ones you dont use, but you may need to delete more/all depending on the situation) and add then. This fixes connection issues the majority of the time with very little trouble since rebonding what you need later is a simple task.
SOURCE: bluetooth headset wont pair to pc
i fixed this problem by enter "0000" (four Zeros) as the passkey, it accepted it and it didnt ask me to enter the passkey on the remote device ie the headset ,which is handy as it doesnt have any number keys ;)
it then added the device and it stayed on teh "added devices" list!
hope this helps
SOURCE: cannot pair my Emerson EM-227 wireless headset with my Iphone
Some headsets have a built in code not all are 0000 check your documentaion for both the phone and headset
SOURCE: Iphone does not pair with LG HBS-250 Bluetooth Headset
the bluetooth of iphone is not compatible with this.get the bluetooth application installed from itunes store to maki it compatible.
Q. I bought an item from the Former Sharper Image that is broken, what do I do?
A. Unfortunately, we are not able to assist you with products purchased from the Former Sharper Image Company, which filed for bankruptcy on February 19, 2008. We are a new company offering new and innovative Sharper Image products.
Q. What happened to the Sharper Image retail stores?
A. All Sharper Image retail stores have closed.
Q. What is the difference between the New Sharper Image and the Former Sharper Image?
A. On Friday, May 30, 2008, the Former Sharper Image (The Sharper Image Corporated) assets were acquired by a joint venture formed between Hilco Consumer Capital, Gordon Brothers and Bluestar Alliance. This joint venture has been re-established as The Sharper Image. Through a licensing agreement with The Sharper Image, Camelot Venture Group, is in charge of managing and operating the SharperImage.com website and ecommerce platform. SharperImage.com has no affiliation to The Sharper Image Corporated ("TSIC") that filed for bankruptcy in 2008, or any of the various retail stores currently selling Sharper Image licensed products.
