Question about IBM ThinkPad T43 Notebook
Sound problem I cleared programmes on my laptop to create more disc space and accidentally deleted my sound device. as such i dont recieve sound and also my yahoo messenger doesnt work even after down loading the current messenger version. I will appreciate your help. Derash
    Genius:
  • 1,124 Answers
Hello, first off all, check if the sound device is activated
Second of all, you have two ways to get your sound driver:
1) Put your IBM cd recover and find there the sound drivers. (Usuallly is a folder with a number)
2) If you don't have the cd, go to ibm webpage at www.lenovo.com
then go to Support >> "software and drivers" put your machine number and model and get the sound driver there.
After that, you have to download the driver to your laptop, then go to "My PC" >> Properties >> Hardware >> Device Manager >> Audio ----->> and update the driver with the new one. That's it.
Please don't forget to rate my help >> Thank you!
Pablo
Posted on Oct 10, 2008
  • Pablo Csaky
    Pablo Csaky Oct 17, 2008
    Thank you for using FIXYA!
    Dont forget to rate my help!
    Have a great day!
    Pablo :-)
    Let me know if you have further questions about this issue.
How do you reduce Factory disc to create space
Programmes are small in comparison with data. What is the OS?
Jul 30, 2014 | HP Computers & Internet
My acer netbook "D" drive is nearly full
Go to your drive C:, right-click, scroll down to "properties".
An option will pop-out. Look towards the down part and select Compress...... Then click "this"< then "OK".
This will compress your hard-drive and give you more space.
I hope you understand this.
Good luck.
Nov 28, 2012 | Acer Aspire One A150-1006 Notebook
I recently purchased the Toshiba DR570KU DVD recorder. I live and purchased this machine on a small Caribbean Island,and with respect to local people they have no technical knowledge of what they are...
Hi -
I'll try to explain without confusing you any further, but if anything doesn't make sense, please let me know. The instructions on page 79 are contradictory, which doesn't help very much. The upper part of the page suggests you can create extra space on a DVD+RW disc by deleting titles, while the lower part, in the grey box, states you cannot. The bottom part is actually correct.
I'll split this into two sections - blank/unused and used discs then explore a few scenarios.
Blank/unused discs
A DVD+RW is typically 4.7GB and will record approx. 2 hours of video in SP mode or 4 hours inLP mode. If you record more than one programme, they will appear consecutively in the disc editing menu, and shown as numbered blocks in the Title List. The last block shown will always be 'EMPTY', but the actual size of this block can be all or none of the total capacity of the disc.
If you insert a blank DVD+RW disc into the machine and view the title list, you will see this:
Although you can't 'record' to a block labelled EMPTY, this doesn't mean you cannot record to this disc. The blank space on the disc precedes the block labelled as 'EMPTY'.
If you then record one programme of 1 hour duration in SP mode. the title list will look like this:
Once again, although you can't 'record' to the block labelled EMPTY, this doesn't mean this disc is full or that you cannot record anything else on it. The next programme recorder will appear between title 1 and the 'empty' block - as long as there is sufficient space on the disc remaining to record the programme.
If you then record a second programme of 1 hour duration in SP mode. the title list will look like this:
This disc is now full as 2 hours of video has been recorded in SP mode. However, if you'd only recorded 1 hour in total for these 2 programmes, you would still be able to record another hour of video in SP to this disc. The additional programmes would appear between the last numbered title and the 'empty' block - until the disc is full.
The empty block is always present and you cannot 'get rid of it', but it doesn't mean the disc is full or cannot be recorded on.
Hopefully, this goes some way to explaining it, but I still need need to explain what happens with used / full discs when you want to delete programmes and re-record.
There is a maximum length for messages posted on FixYa and I may be getting close to this, so rather than break off in mid-flow, I will continue the explanation for used discs in another message below this one. I will do this right now, but it will probably take me 20 minutes or so to write part 2, so keep checking back. It will be less confusing if you hold any questions until I've written part 2, but I will be happy to answer any after that.
Regards,
BElectric
May 02, 2011 | Toshiba DR570 DVD Recorder
I have tomtom730 can not defrag internal drive not enough space
when connected to your pc you can create space by throwing away alot of sounds an languages you dont use. check if there are more things u dont want an create space by deleting. if you make back up first you can always return them. good luck with tomtom home.
Feb 15, 2010 | GPS
I,downloaded films got to the last stages of burning on 2 disc and it says ive got enough for temp files but the recording proc will need more
You need to clear space on the hard drive as your burning software is unable to allocate the space needed to create a the temporary files.
Go through your hard drives and delete all the movies and stuff that you don't need or have backed up to a DVD or external hard drive.
Once you have cleared enough space your DVD software should be able to create the temp files for burning.
Regards.
Dec 02, 2009 | Computers & Internet
Low disc space cant upload pictures or anything i delted lots of files but still low disc space .zero space please i need help asap.
Just moving things to the trash or deleted files does not clear them from the disk drive.
Try empty trash or remove deleted files.
Jul 13, 2009 | Computers & Internet
Pantech duo wont recieve text messages
 I have the pantech duo and mine did the same thing but I deleted some music that I bluetoothed/synced to my phone and that cleared up the space.  My advice would be to get a micro ds card.
Feb 22, 2009 | Pantech Duo Smartphone
Messages deleted when phone is turned off
You must have cleared photos and videos. however, many people do not realize that an accidental audio recording can use up all the disc space. So check for extra large audio files.
Dec 30, 2008 | Samsung Blackjack SGH-I607 Smartphone
Nero 8 problem
you need to delete on disc content on nero it might full look down see if the bar color occufide the red line it tells you if you there is not enough space or try look for disc info then look for total use space check if theres enough space for burning your disc. hope i help you with your problem :p
Mar 01, 2008 | Computers & Internet
IBM ThinkPad T43 Notebook Logo
118 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
