Question about Kenwood Audio Players & Recorders
I have a hi fi amp a Kenwood ka 3020se. It is about 13 years old and the input selector switch is causing the sound to breakdown but if it is held manually just off station its o.k. Its worn. I live in the U.k. where do I get a replacement part? Cheers, John.
  • 68 Answers
Try Servisol switch cleaner first, available from Maplin just a sqirt and press switch on/off rapidly several times make cure before you go for a new switch
Posted on Oct 10, 2008
What is the wattage output of the kenwood ka 728 integrated amp?
Specifications Power output: 130 watts per channel into 8? (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.007%
Input sensitivity: 0.2mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 69dB (MC), 87dB (MM), 107dB (line)
Output: 150mV (line)
Dimensions: 340 x 109 x 369mm
Weight: 9.2kg
Year: 1984
Kenwood KA 828 Manual Stereo Integrated Amplifier HiFi Engine
Nov 15, 2016 | Kenwood Audio Players & Recorders
Can a Kenwood car cd player stop working from sitting up in the garage over a year? Model# Y21-7750-13
Hi Nina,
Surely the best people to ask would be Kenwood? Their customer support team should have the answer (and it's likely to be 'no').
Try Language Selector
Aug 01, 2015 | Kenwood Car Audio & Video
Don't know how to hook up kenwood ka-994
Check the bellow link for the user manual of kenwood KA-994. In page number 4 of the user manual You can see how to make the connections to the receiver
Manual
Ajin
Mar 09, 2012 | Audio Players & Recorders
Describe your kenwood manual "ka
Hi, Yes it is safe to leave this connection unhooked. The system control is what the stereo uses to remote control a cassette deck,cd,turntable etc... using the amplifier separately should be o.k. I hope this helps, good luck and thanks for choosing FixYa-Prodzilla
Apr 20, 2011 | Audio Players & Recorders
I have a kenwod krf-v5050d amp (old I know). I have my blu ray hooked up via an optical cable however I can not get any sound through the speakers from it. I know it shouldnt be the speakers or the amp...
xjackdeth,
All systems with multiple audio/video inputs for each connection must be told what connection you want it to play. Most likely your selected choice of input is set to an input other than digital. I included a link to download the manual for your Kenwood model; see page 9 for "Input mode settings".
First use the input selector knob to select the input you are using for the blue ray player, then press the input mode button to select digital auto; the Kenwood should take a few seconds to switch over and then you will be in business.
http://audio.manualsonline.com/manuals/mfg/kenwood/krf-v5050d.html
-Chris
Jan 09, 2011 | Kenwood Unity System
When switching on system, it makes loud buzzing sound from amplifier? UK 240v
Unplug everything apart from the speakers that is plugged in to the amp and check the wiring of all the connectors. If the buzzing stops when you do so then it is most likely one of the input connectors or cables causing the problem and it is most likely that the shield or earthing wire in one of those cables is aft faulty and needs repairing or replacing. If the buzzing continues try switching the input selector to something else to see if it disappears. If it does then the input channel that causes the buzzing may be faulty and need repairing and if it does not then the amp itself has an issue and will need repairing. In this case it may be a faulty power supply, preamp or main amp module especially if it comes from both or all channels.
Oct 06, 2009 | Kenwood Audio Players & Recorders
Kenwood KA-880D Amp keeps blowing the 6v 250w fuse
please check the VDR in primary supply side.its directly connect to bouth N&Live wire connections of supply.
nuwan.
Jan 11, 2009 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
No sound from my record turntable into my computer.
If you're certain there is no sound going out of the TT...
Setting the Pre-amp Switch
For increased flexibility of use, this turntable has an internal
stereo phono pre-amplifier. The Pre-amp Selector Switch
is located under the turntable platter, in the rear-center
(Fig. 1). If the system amplifier you are using has a PHONO
input, set the Pre-amp Selector Switch to the “OFF”
position. If your amplifier does not have a PHONO input,
set the Pre-amp Selector Switch to the “ON” position and
connect the turntable’s output cables to the AUX or other
high-level input on the amplifier (described later).
Turntable operates, but no sound at all
1. The stylus guard is still in place.
2. The tone arm Lift button is pressed in.
3. Amplifier controls set incorrectly: wrong input selected,
tape monitor on, speakers switched off, etc.
4. Check the stylus on phono cartridge for correct placement.
Refer to the instructions for replacing the stylus
on page 5.
Turntable operates, but no sound, or sound not loud
enough
1. If the turntable is connected to an AUX (high-level)
input: The Pre-amp Selector Switch may be set to the
“OFF” position (phono-input level).
2. The input gain of the amplified speaker or similar
device may be too low.
3. The stylus assembly may not be fully seated in the
cartridge body.
You could also isolate the problem to either the TT or the PC by trying the TT on some other sound device like a receiver. Make sure the PreAmp Selector switch is ON and plug the TT into any AUX, CD or TAPE input.
Sep 02, 2008 | Nakamichi AV-7 Receiver
168 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
