Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Hotpoint Ultima WDM73
How do you replace the "spider bracket" in this Hotpoint..I think it goes on somewhere to the back of the drum, but not sure how to access it. Any help gratefully received. Thanks.
  • anderson3626 Oct 11, 2008
    How do you do that then ? Is there a guide somewhere to talk you through each stage ?
This is to much to type quite invoved,You need to be handy with tools and big hammer and drift,Proberly 3 hours work for you.
Posted on Oct 11, 2008
  • 99 Answers
The whole tub has to come out then split,it is worth changing bearings at same time.Parts can be supplied by us.
My hotpoint ultima is not heating, the drum spins. could you advise what the problem is
For most Hotpoint (and other named) models there is a common problem often indicated by 'F08' which decodes as 'heater relay (possibly) stuck'. 'Check power supply connections to the heater, wiring and module (i.e. PCB) connections' (apparently poor PCB connections are often the cause).
So- if you are not electrically confident and competent yourself, which you may be, you need to employ the skills of a partner, friend or service engineer ;-0)
Sorry we cannot be of more help!
Good luck, John C
Mar 18, 2011 | Hotpoint Ultima WDM73 Front Load Washer /...
My Hotpoint wdm73 won't drain. how do I fix it?
  1. You will need to gain access to the drain pump through the bottom of the Washing machine. Remove the Drain hoses from the pump, clear any debris, change, etc. If it is clear, or the error continues after clearing, replace the drain pump.
  2. If you replace the drain pump and it still won't drain, you will need a new Control Board.
Feb 27, 2011 | Hotpoint Ultima WDM73 Front Load Washer /...
How do you remove the back from a hotpoint ultima wma64/65/66?(not sure which it is) can't find any sort of screws or bolts
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The rear of the cabinet doesn’t come off only the lower panel and an inspection plate in the centre. If you are talking about the rear of the container; that doesn’t come off either the tub splits from the centre. For a workshop manual on the WMA range of machines visit
Mar 04, 2010 | Hotpoint Ultima WDM73 Front Load Washer /...
Door lock symbol showing on screen and door will
Assuming child lock is not on...Water not fully going away/ blockage @ filter.
Nov 02, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
Close door error on display when door is closed on WDM73
Th eswitch that teel it that door is open is out of position or bad.
Jun 19, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
Tub wont turn jammed
hi this sounds like your bearings have collasped and the drum has slightly twisted the bearings will need replacing which is about £120.00 for the repair has the complete drum has to be taken out m8
Jul 16, 2008 | Hotpoint Ultima WDM73 Front Load Washer /...
u need to put something like a wooden hammer handle into the hole in the spider at the back when u have put it in spin the inner drum clock wise fast so it undos the spider or pulley wheel to some people once the spider is all the way off u need to put the nut back on just so it is level with the spindle with a rubber mallet strike it fast and hard and it will move the inner drum to come out once it comes so far out u need to undo the nut and remove the inner drum totally
Sep 01, 2007 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
82 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
