Question about Toastmaster 1148X FastBake Bread Maker
Need New Drive gear
I need a new Drive gear for the motor shaft
  • simonchen Nov 24, 2008
    Dear Sir :
    I need dirve gear too, Would you please tell me where I can get .
  • 68 Answers
Seems like a ton of people are having issues with this toastmaster product, the OEM is no help?
You can send me the gear and I can quote making you a new one, same with belts, whatever, we fab parts all the time for tons of special devices,
call the OEM first if not write me at and I will see what I can do for toastmaster owners
Posted on Nov 12, 2008
How do you get balance shaft drive sprockets off?
You need to remove the balance shafts first. Be VERY careful or you will end up breaking off the tab that the small hold down bolt goes through. You need to remove this little bolt first of course. I found that using a pry bar on the bottom of the sprocket itself seemed to work best.
Once you have the balance shaft out, clamp it in a vise using wood or something similar so that you do not damage any if the surface that rides on the bearing. Then remove the 15 mm bolt holding the gear (sprocket) on. Re-install the new gear and torque to 37 ft-lbs. The new gear is slotted so it can only go on one way. Do not mix up the intake & exhaust balance shaft gears. Good luck.
Jul 07, 2014 | 2003 Chevrolet Cavalier
Drive Shaft stopped kneading dough
To give the mixer strength it has planetary gears. Something may be wrong in the gear section
Nov 26, 2013 | Bosch 800-watt Universal Plus Mixer with...
My interrupter cup keeps flying off on my craftsman garage door opner model 139.53648srt1
This sometimes happens after changing a drive gear. If this is the case follow the instructions below.
You probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
If you didn't just change the drive gear you will find the motor shaft is moving towards the rear and knocking the interrupter cup off. Replacing the drive gear with the new coupler and washers will cure this problem.
Jun 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
I need a new motor for the Gemmy Ferris wheel, Item 71-92125. The motor is a Huayi 60TYZ-A
Did you get an answer to your question about the Ferris wheel?
May 24, 2011 | Toys
The starter on my XV750SE dont get in gear. The starter runs but does not turn the engine. But it works ok with sparkplugs remowed.
the starter gear is a series of rollers, that grab a smooth drive, it will spin the motor with no plugs cause its easier. will need new rollers, and a new drive if it has marks on it. there are also some rubber bushes the shafts spin in, that may look ok but can allow the shaft to move slightly, which can affect the rollers from grabbing
Apr 05, 2010 | Yamaha XV 535 Virago DX Motorcycles
Micra gear box Cv joint relacement
this easy, drain oil from gear box remove that drive shaft (u need a ball joint splitter)
replace gearbox seal, pry out old 1 with screw driver, gently tap new in, oil edge of new seal 1st. replace oil, ps dont leave to long as will damage gearbox when lack of oil
Aug 09, 2009 | 1994 Nissan Sentra 4-Door
Gear slipping in dewalt dw056
Those gears are only held on the motor with their tight fit, if yours is slipping that easily the motor will have to be replaced. The new motor will have that gear on it.
Apr 07, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Not printing at all. Screen appears as series of exclamation marks
I had the same problem with my label marker. Changing the batteries fixed the problem
Jan 08, 2008 | Dymo LabelManager 300 Desktop Labelmaker...
Broken gear on BFP-703 base
The drive is replacable and available from Cuisinart, you will have to sign a waver to get the part. the drive is screwed onto the motor shaft with reverse threads. the plastic drive will have to be completely broken off of the unit to expose a brass"nut" which was internal to the drive. depending upon your model you may have to remove the lower half of the base unit to access the lower part of the motor shaft. there will be a slot in the end of the shaft for a large flat blade screwdriver. this is used to hold the shaft still while turning the drive "nut" with a vice grip pliar or similar. the new drive is just threaded onto the shaft and normal operation tightens it.
Feb 14, 2007 | Cuisinart BFP-703 Blender
Toastmaster 1148X FastBake Bread Maker Logo
180 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Oscar Netto
Oscar Netto
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
