No image icon in the tray error messages = No computer connection, No scan option We have reinstalled the setup several times. It will put a image icon in the tray, but , when you reboot the computer it is no longer their.
    Genius:
  • 1,605 Answers
Are we talking about Computer of printer????
Posted on Oct 10, 2008
Please let know in hp0fficejet4355 how to scan and save in my laptop
On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running.
Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality and result in the No Connection error message. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software.
After you have made the scan, you can find it using the Photosmart Software. It is also stored in the "My Scans" area under My Documents on your computer.
Jul 04, 2010 | HP Officejet 4355 All-In-One InkJet...
No scan option error message pops up when i press the scan button, it says no computer is connected to the device, but my computer is connected and it says is working properly
First of all, Do you have HP Solution center installed on your computer, if yes, then check if you are able to scan from solution center, if yes then all u need to run a file from c:\Program Files\hp\Digital Imaging\bin\hpqtra08.exe
once you will run it, check if u have a digital imaging monitor icon with a check mark in the system tray(where the system date and time are displayed), if yes then populate the front panel destination list in the solution center and add shortcuts to fron panel list and update device, turn off and ON the printer , then try scanning.
If solution center is not installed , then install the software full feature.
Jan 23, 2010 | HP Officejet 5610 All-In-One InkJet...
"no scan options" refer to device documentation - Mac
>check if you have hp solution center icon on your desktop and digital imaging monitor running on your system tray---an icon with a green check mark on your system tray.
>if this are not presen that is the reason why you have that error message
>try reinstalling the sw
Aug 05, 2009 | HP Photosmart 2575 All-In-One Printer,...
Scan button on printer pulls an error message when pressed
you must reinstall the windows and after that install the software drivers and it will work
Jul 30, 2009 | HP PSC 1350v All-In-One InkJet Printer
My new hp officejet pro L7590 printer tells me that "no scan options" are available. I bought this as a all-in-one printer. help, I need to scan
Hi Kate,
This error occurs if HP drive services are not functioning properly, so try my solution
Solution
Follow these steps in the order presented to resolve the issue.
Step one: Verify that the Digital Imaging Monitor is ready
The Digital Imaging Monitor must be running in order for the Scan To function to work. The Digital Imaging Monitor icon normally appears in the system tray at the lower-right corner of the computer screen, and the monitor is ready when a check mark appears on the icon after Startup is complete.
If the Digital Imaging Monitor is in the system tray, proceed to Step two.
If the Digital Imaging Monitor does not appear in the system tray, follow these steps.
Windows 98, Me, and XP
1.Click Start , and then click Run .
2.In the Open text box, type msconfig .
3.Click OK .
4.In the System Configuration Utility window, click the Startup tab.
5.Search the list for HP Digital Imaging Monitor .
6.If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. 7.Proceed to step three to uninstall and reinstall the software.
8.Select the HP Digital Imaging Monitor check box.
9.Click Apply , and then click Close .
10.Click Yes to restart.
Windows Vista
1.Click Start .
2.In the Start Search text box, type msconfig and press Enter .
3.On the User Account Control window, click Continue . The System Configuration Utility window displays.
4.Click the Startup tab.
Step two: Populate the destination list
1.The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
2.Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
3.On the Windows desktop, double-click the HP Solution Center icon.
4.On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
5.If more than one HP device is installed, click the tab for the All-in-One product. The HP Solution Center shows only the functions, settings, and support options that are appropriate for the selected HP product.
6.Click Settings .
7.Click Scan Settings and Preferences .
8.Click Scan to... Setup .
9.Click the Destination List tab.
NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
10.If the Front Panel Destination List is empty, continue with this procedure.
11.If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
12.Click each program to include on the Scan To list.
13.Click the Add arrow.
14.Click OK .
15.Scan a document using the Scan To button on the front panel.
16.If the scan fails, try to scan using the HP Solution Center Scan button.
17.If the scan still fails, proceed to Step three to uninstall and reinstall the software.
Step three: Uninstall and reinstall the software
1.Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
2.If the software installer does not automatically start, complete the following steps.
3.Click Start , and then click Run .
4.In the Open text box, type X:\setup , where X is the letter of the CD-ROM drive.
5.Click OK .
6.On the installer screen, click Uninstall . If there is no Uninstall option, the software installation is incomplete.
7.Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
8.If the model supports custom install, install HP Imaging Device Functions to scan from the printer. The recommended install will install this feature automatically. It must be manually selected during a custom install.
9.Follow the onscreen instructions until the printer software is completely installed.
10.After successful installation, scan a document.
Step four: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Thanks
Riz
Jan 13, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Scanner doesnt work
Step one: Verify that the Digital Imaging Monitor is ready The Digital Imaging Monitor must be running in order for the Scan To function to work. The Digital Imaging Monitor icon normally appears in the system tray at the lower-right corner of the computer screen, and the monitor is ready when a check mark appears on the icon after Startup is complete. If the Digital Imaging Monitor is in the system tray, proceed to Step two. If the Digital Imaging Monitor does not appear in the system tray, follow these steps. Windows 98, Me, and XP
  1. Click Start , and then click Run .
  2. In the Open text box, type msconfig .
  3. Click OK .
  4. In the System Configuration Utility window, click the Startup tab.
  5. Search the list for HP Digital Imaging Monitor . If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. Proceed to step three to uninstall and reinstall the software.
  6. Select the HP Digital Imaging Monitor check box.
  7. Click Apply , and then click Close .
  8. Click Yes to restart.
Windows Vista
  1. Click Start .
  2. In the Start Search text box, type msconfig and press Enter .
  3. On the User Account Control window, click Continue . The System Configuration Utility window displays.
  4. Click the Startup tab.
Step two: Populate the destination list The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
  1. Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
    • On the Windows desktop, double-click the HP Solution Center icon.
    • On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
  2. Click Settings .
  3. Click Scan Settings and Preferences .
  4. Click Scan to... Setup .
  5. Click the Destination List tab. NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
  6. If the Front Panel Destination List is empty, continue with this procedure. If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
  7. Click each program to include on the Scan To list.
  8. Click the Add arrow.
  9. Click OK .
  10. Scan a document using the Scan To button on the front panel.
  11. If the scan fails, try to scan using the HP Solution Center Scan button. If the scan still fails, proceed to Step three to uninstall and reinstall the software.
  1. Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
  2. If the software installer does not automatically start, complete the following steps.
    2. In the Open text box, type X:\setup , where X is the letter of the CD-ROM drive.
    3. Click OK .
  3. On the installer screen, click Uninstall . If there is no Uninstall option, the software installation is incomplete.
  4. Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
  5. If the model supports custom install, install HP Imaging Device Functions to scan from the printer. The recommended install will install this feature automatically. It must be manually selected during a custom install.
  6. Follow the onscreen instructions until the printer software is completely installed.
  7. After successful installation, scan a document.
Step four: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Aug 14, 2008 | HP Officejet J5780 All-In-One InkJet...
I am trying to scan a pic and my scaner says no scan options
  3. Click OK .
Windows Vista
  1. Click Start .
  2. Click Settings .
  9. Click OK .
    3. Click OK .
Jul 08, 2008 | Office Equipment & Supplies
Scanner problem
I understand that you are receiving the error to install the All-i n-one software while scanning from the printer front panel.
You have not informed whether the unit is connected in network or with USB cable.
However, follow the below given instructions to resolve the issue.
Verify that the communication between the computer and the printer is fine and the full version All-in-one software is installed in the computer.
Solution one: Verify that the Digital Imaging Monitor is ready The Digital Imaging Monitor must be running for the scan to feature to function. The Digital Imaging Monitor normally displays in the system tray in the bottom-right corner of the computer screen, which is next to the time. The Digital Imaging Monitor is ready when a check mark displays on the icon. This can take some time after startup to complete the initialization and for the check mark to display on the icon. If the Digital Imaging Monitor displays in the system tray, proceed to Solution two - Populate the destination list . Search for the file " hpqtra08 " in your computer and run the file. Solution two: Populate the destination list Here are the steps to set the scan options: 1. Open the HP Solution Center. 2. Click Settings. 3. Click Scan Settings and Preferences. 4. Click Scan to… Setup. 5. Click the Destination List tab. 6. If the Front Panel Destination List is empty, this is the reason the All-in-One is generating the error message, and you should continue with this procedure. 7. Click each program that you want to display in the scan to list. 8. Click the Add arrow. 9. Click OK. This should resolve the issue that you are experiencing with. Regards, Lawrence
Jan 04, 2008 | HP OfficeJet 7310 All-In-One InkJet...
No scan options say refer to device documention to trouble shoot
Check whether the Digital Imaging Monitor is running .
If yes, good.
Now, please open HP Solution Center and setup the destination list .
Double click >> HP Solution Center >> settings >> scan settings and preferences >> scan to .. setup >>
Add all the entries from " available scan destinations " to "front panel destination list " >> click >> ok .
Now, try to scan from the front panel of the All-in-One .
Dec 06, 2007 | HP Officejet 5610 All-In-One InkJet...
Cardridge problem for my 5610v
try with another cartridge, maybe you have a faulty one.
try cleaning the connectors on both printer and ink cartridge.
Nov 21, 2007 | HP Officejet 5610 All-In-One InkJet...
Computers & Internet Logo
David Payne
David Payne
