Question about HP LaserJet 4350 Printer
49.ff04 service error - HP LaserJet 4350 Printer
  • 6 more comments
  • Anonymous Oct 15, 2008
    49.ff04 service error problem
  • hclrm Nov 21, 2008
    49. ff04 error on HP 3800n
  • Anonymous Dec 05, 2008
    Will not print due to error 49.FF04
  • Edgar Gadea Jan 08, 2009
    I have the same problem with a color laser jet 4600n
  • Anonymous May 21, 2009
  • Mohammad Ikram Aug 19, 2013
    Problem in CM4730mfp 49.ff04 turn off then on
  • Anonymous Mar 12, 2014
    My printer display me 40. ff04 Service ide error
I did replace the Jet Direct card, problem hasbeen resolved
thnks full for your advice.
Posted on Jan 12, 2009
    Problem Solver:
  • 9 Answers
Check and remove the HDD and try it for a while. Replace the jet direct card and try (if you have one installed) and try. Update the firmware. If that fails then someone is sending a corrupt file\print job to the printer.
Posted on Jan 08, 2009
Prefab
  • 152 Answers
SOURCE: 49. FF04 Service Error on
General troubeshooting for HP 49 Errors
49ErrorsSupport
Posted on Feb 24, 2011
seeker5211
  • 1089 Answers
SOURCE: " 49.FF04 Error Turn off
Critical firmware error. Can be caused by invalid print commands, corrupt data, invalid operations or even electrical noise in the cable.
Turn off the printer, then turn it on.
Press Stop to clear the print job from memory.
Turn off and back on.
Print a document from a different software program.
If that document prints, go back to the first program that failed and print a different file.
If the error comes back, that file is corrupt.
If the message persists with different programs and print jobs have the formatter replaced.
Posted on Apr 17, 2011
jaylex
  • 417 Answers
SOURCE: HP 4350 printer
EIO is the port for the network card on the back of the machine turn off machine remove card from EIO2 and install into EIO1 turn machine on and see what happens. If this does not work then open the formatter casing and remove the memory chips (OF COURSE WHEN THE MACHINE IS OFF) after removingone turn machine on and see if it boots up.
The 49 error is normally a software issue with the machine and it has locked within the network area or the memory.
Hope this helps you and please rate me
Cheers J
Posted on Dec 31, 2007
komguy
  • 2306 Answers
SOURCE: Service Error
The 49 series errors are firmware errors, you may need a new formatter pcb.
Posted on Nov 18, 2009
Testimonial: "thanks for the additional detail, great information. "
BaronVonNuke
  • 1915 Answers
SOURCE: HP Laserjet P3015 Error 49.ff04
These errors are almost always caused by outdated firmware. Print a configuration page and check the firmware version against this website . If your version is older than the one on HP's site then download the top option which is the easy install version and run it on your computer.
Posted on Mar 11, 2011
My printer hp laserjet 4350n displayed error 49.FF05 SERVICE ERROR .what is the problem
49.FF04 - in older 4xxx printer it mneans a firmware error - try to do:
1. cold reset
2. updaete firmware
3. remove network card from printer and instert it back - or try to turn printer on without it.
4. reinstall the formatter - phisical connection may be not good ( formater is a "cage" that the networc card is inserted)
go to http://www.hp.com for more information
May 27, 2015 | HP LaserJet 4350n Printer
49 service error ff04
your printer driver is corrupt or the files your printing are corrupt- most 49.xxyy errors are down to software external to the printer. not sure?.
disconnect the printer from all network points and cycle the power - when it is ready perform a path print test ( found under the diagnostics menu on the printer itself ) and you will likely find no errors ( if by some horror of horrors you do get 49.xxyy error then you will need to replace the firmware chip - Very Very unlikely) -
what to do--
remove the printer and uninstall from the workstation - reboot the PC - re install the latest driver for your operating system downloaded from HP website
re connect the printer - print away !!
Jan 28, 2014 | HP LaserJet 4600dn Color Printer
Try changing the network cable. Connect the other end to another port of the ethernet switch.
If it doesn't work, remove the Network cable and using the printer console reset printer to factory default so that printer use DHCP.
Connect back network cable and try again.
Some people powered down and remove & cleaned the RAM edges. Removed and reset the EIO network interface.
Dec 25, 2013 | HP LaserJet 4100 Laser Printer - Plain...
Our HP LJ3005Px shows the following error: 49.FF04 Service ne Error What can we do?
Firm ware error issue.If printer comin to ready mode try to up load form ware, no ready mode replace formatter
May 04, 2011 | HP LaserJet P3005 Printer
Apr 16, 2011 | HP LaserJet P4014n Printer
49.FF04 ERROR Turn off then on It will not print
i changed the network port,then, i ping the IP Address it pass.
Aug 24, 2010 | HP LaserJet P4014n Printer
HP Laserjet 2420dn will not print and is displaying message '49.FF04 service error'
Does the error display when printing a particular job, or anything that you print? If you have extra memory installed, remove it. Power up and try again. If it won't clear replace the formatter
Jan 29, 2010 | HP LaserJet 2420dn Printer
49-ff04 error
That's a firmware error, not enough memory to print requested page, wrong format for printer, an unavailable font, bad memory, bad formatter board, any number of things.
Jan 12, 2010 | HP COLOR LASERJET CP 3505 N PRINTER
Service Error
Nov 18, 2009 | HP LaserJet 5500DTN Printer
HP LaserJet 4350 Printer Logo
5,906 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
