Question about Epson Office Equipment & Supplies
Printer wil not print i have 12 items on the printer i can not fin how to cleare the pinter
    Scholar:
  • 45 Answers
Open the printer queue (by double-clicking on the icon of the printer) so you can see your 12 print jobs.
Click on the menu item "Printer" and select "Cancel all Jobs".
If that doesn't work, you can cancel each job by right clicking on it and selecting "Cancel".
Label_Guy
Posted on Oct 10, 2008
How could we set default page setup from 11 inch to 12 inch in epson fx-2175
Dear friend,
Jus do the following:
press 2&3 button simultaneously when printer is power on.
Press itemdown (1) one time press set button 2 times
turn off and turn on pinter
Press set button once
check the print for 12 inch
Mar 11, 2011 | Epson Office Equipment & Supplies
PIXMA MP780 All-In-One InkJet Printer: Getting Printer Error 6A00 light on pinter flashin...
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 07, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Error 6A00 appears. Wil not print. Cannot find
I found this elsewhere and it is from a Canon technician.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
so what I would do is check for something blocking the paper path, plus turn off the printer, manually move the print head from one side to the other and back, and then turn the printer back on.
Jan 08, 2010 | Canon PIXMA MP610 InkJet Printer
Pinter power up but cannot print
Please follow the steps below:
1. Make sure that the printer driver is properly installed to the computer and you can print directly connected to it.
2. Install the PSAdmin Utility to the computer.
3. Connect the print server to the router and your printer to the server.
4. Open the PSAdmin Utility and you will see the server icon at the lower portion of the window.
5. Locate the TCP/IP and click the plus (+) sign.
6. Get the IP Address of the print server and ping it.
7. Make sure that you can ping the print server.
8. Go to the Control Panel > Printers and Faxes.
9. Right-click the printer icon > Properties.
10. Ports tab > click the Add button.
11. Select Standard TCP/IP > New button beside the Cancel button
12. Next > Custom > enter the properties
13. Type the IP Address of the print server > Next
14. Select LRP and then type L1 for the queue name > OK
15. Next > Finish
Make sure that the printer is set as the default printer and online. Right-click the printer icon > Properties. Click Print Test page under the General tab.
Good luck and have a great day!
Jun 10, 2009 | IOGear GPSU21 Print Server
I had problem with dymo, so we printed receipt thru other printer and now got dymo fixed, so i tried to print, but it's not printing, i looked in printer que, there's some printing items that i cann't get...
right click the items in print queue and delete them. You have to wait a few secs before the print queue is clear. You can also try to reprint the same thing by right clicking the item in print queue.
Jan 02, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
KYOCERA FS C5020N PRINTER QUEUE
remove from driver from control pannal>add remove program>
uninstall your printer driver & reinstall it i m shore its help u
Feb 21, 2008 | HP PSC 1410v All-in-One Printer
Network Printing Issues
Hi alexredfern, Have you checked that the printer is set to be the default printer on the problem PC?
Nov 14, 2006 | Xerox Phaser 6100/BD Laser Printer
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
