Question about Cell Phones
LG5000 cell phone mode
My phone is displaying on the main screen and I am not able to use my phone. I can dial out and I can text but I am not able to hear the call nor is the caller able to hear me.
I have searched the user manual for a fix but could not find anything.
  • 282 Answers
Try to turn off computer,remove battery and turn it back on
Posted on Oct 10, 2008
Pleaase fix it.
Posted on Nov 12, 2008
How do u install it in your car
there is a users guide and maunals in the package,just follow instructions:
Please note this car-kit will not work in cars that use optical cabling. Check with your car dealer before ordering. Also, since this car-kit is installed by hard-wiring to the existing car stereo, professional installation is highly recommended.
Turn on the car engine and the phone connects wirelessly to the Parrot CK3100 Car Kit. The screen unit has easy-to-navigate menu options just like your phone, and your mobile phone book is wirelessly downloaded to the car kit. Calls can be dialed either through the screen, or by using voice-recognition speed dialing. According to your phone's model and firmware, most features are accessible from the hands free console, including one-touch redial, dual call, and auto-answer.
Feb 23, 2011 | Parrot Hands-Free Car Kit with LCD Display...
How do i turn off the message keypad noise that happens when im typing a text message?
Sounds
• To set volume for media and videos, from the home
screen, touch Menu > Settings > Sound &
display > Media volume.
• To play tones when using the dial pad, from the
home screen, touch Menu > Settings > Sound
& display > Audible touch tones.
• To play sound on a screen selection, from the home
display > Audible selection.
Feb 22, 2011 | Motorola Mobility Defy Cell Phone
I dialed ##8378<SEND>, then clicked
Typing ##8378 Send brings up the phone test screen. When you select #2 (Field Test) and then select OEM monitor and select "enable" the phone resets and enters test mode.
In test mode you can press the volume up button to bring up the test menu. You can navigate this menu using the 1 and 3 keys on the number pad.
The most notable screen in test mode is found by pressing 3 until you reach SHDR protocol monitor will bring up the screen that displays real time reception and transmission information.
Other screens display other system information, but I caution against "playing around" with these menus too much.
To temporarily hide the test mode screen you can press the volume keys again. To take the phone out of test mode completely follow these steps:
1. dial ##test or ##8378 and press send 2. select 2 (field test) 3. scroll down to and select 10 (OEM monitor) 4. scroll down and select Monitor DISABLE 5. the phone will reset and return to normal mode.
Feb 13, 2011 | Casio G''zOne Type S Cellular Phone
How do you change language from Spanish to English on this phone? I put it on spanish somehow and i cant get it back to english.
Hello
Using Settings
Settings contains many submenus that let you customize your phone.
Display/Info Features The Display/Info menu controls how the keypad and display appear: - changes the wallpaper that • Wallpaper appears on the idle screen. - sets the size of text on the display. • Text Size - changes the look of the display. • Theme - controls whether main menu • Home Icons icons appear on the idle screen. - controls backlight illumination. • Backlight133 Customizing Your Phone - controls whether the time and date • Clock appear on the idle screen; sets time and date format; sets year. - controls whether the items on • Menu View your main menu and Java applications menu appear as large icons or a list. - sets large digits to appear on • Large Dialing the idle screen when you enter a number. - sets the language that your phone • Language displays.
for more information Get the manual from here http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/i850/US-EN/_Documents/Static%20File/i850_UG.pdf
Hope this helps if so do rate the solution
Jan 05, 2011 | Motorola Mobility i850 Cellular Phone
My screen is blank-- i can make calls by dialing the number, or receive calls but can't see anything (so cant see/send texts or know who's calling). HELP? either how to fix it or how to I forward texts...
hi
first you should restart your phone.if you still have same problem means there must be fault in display screen.you should change the display screen of your mobile.but make sure that you should go to your company service.because there are local salesmen they will change old displays .just change the display screen of your mobile
thank you
Dec 17, 2010 | Verizon Communications LG Chocolate Cell...
Parrot ls3200 displaying goodbye
Good bye appear when the car kit switch off. Then suppose to be in relation with the question of the 12 ignition. If it doesn't disconnect of switch off in relation with the car, maybe the kit has a 12 DC and not an ignition connected.
If you can disconnect the power supply of the kit, just do it, and it should normally coming back to the main screen.
Mar 20, 2010 | Parrot Ck3200 Ls - Color Cell Interface...
How do i get mute off my phone
Well that would be hard to believe you can't get mute off since you have to personally initiate mute while during a call and the mute would be disable after you hang up. The mute button is located on the left side below the screen. Now here is what you might want to look at. Make sure TTY mode is off, this option would put your phone in permanent mute. Go to settings then to call settings, TTY mode should be off. If this still doesn't work and your phone displays "car kit" on the main screen then your phone is probably water damage or needs repair.
Jul 13, 2009 | LG VX8350 Cellular Phone
AT&T Motorola V3 Razr-Main Display problems
You can replace your LCD screen to repair the phone. It's quite easy to do. There's a guide here http://www.formymobile.co.uk/v3disassembly.php
Nov 13, 2008 | AT&T Motorola RAZR V3 Cell Phone - Black
Car kit
My cellphone is stuck in car kit mode and i cannot hear anyone calling me but i can text people. How do i get this feature off!
Sep 05, 2008 | LG VX8300 Cellular Phone
Main screen blank
Same problem here...must be a bug with the phone or has to do with DST..Appears all E815's will not work.
Oct 23, 2007 | Motorola Mobility E815
Cell Phones Logo
210 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
