Question about Nikon D80 Digital Camera with 18-135mm Lens
Nikon D80 won't autofocu
Hi All....I've tried everything I know how (new at this) but for some reason my autofocus stopped working. I'm not sure if I messed up the settings but I'm unable to get it back to where it was. Is there a reset function or can someone advise what to do. Here are the settings: 1) The A/M switch on the lense is set to A, the AF/M lever on the front of the body is set to AF. I swapped the lense to a Quantaray 28-80mm lense and the autofocus works. I have a 4 yr warranty on the system from Circuit City. Should I bring this in for repair?
I had this problem too and found that my lens wasn't firmly attached!
Check to see that your lens is firmly seated in the camera. Do this by holding the lens and twisting counterclockwise carefully. If you hear a click, you probably just fixed the problem!
Posted on Dec 08, 2008
Trying to decide between purchasing a Nikon D80 or 3100....any advice?
The D3100 is newer, for what it's worth. It has LiveView and video capabilities.
The D3100 is intended for beginners, the D80 for more experienced users. The D3100 is easier to learn, the D80 is easier to use once you learn it. The D3100 is lighter, the D80 is more rugged.
The other major difference is that the D3100 does not have an autofocus motor, depending on the lens to have one. This means that some lenses (those not designated AF-S by Nikon) will not autofocus on the D3100 while they will on the D80.
The ultimate decision is up to you. Only you can decide which features are most important to you. Also, if you can, try to get your hands on the actual cameras. See which one feels more comfortable to you.
Jun 11, 2011 | Nikon Cameras
Autofocus stopped working
I fix these all the time for this problem, The focus motor is bad, Tony
May 23, 2010 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Hi K akima...have followed your advice, but no luck. When I go to continuous mode, it only lets me shoot a single shot, the display briefly reads r 08 then returns to r 09 again. I`ve tried my other lenses...
nikon r09,r11, etc . it mean memory buffer of your camera. memory buffer is a temporary memory for your captured images before it store to memory card.
if r00 it mean, you can't take a picture, even 1 picture... that because the camera buffer memory is full.
the number of memory buffer will also drop if noise reduction on
Feb 14, 2010 | Nikon D80 Digital Camera with 18-135mm...
18 - 135 lens won't autofocus after fall - is it worth reparing?
Hi Vink,
I would recommend that you at least let someone at a camera shop take a look at your lens. Or contact Nikon. Here is a list CLICK HERE of Nikon authorized service centers, hopefully you are located near one of these. Or you can call Nikon for some advice. You never know, it may be repairable.
If can live with it as a manual focus lens that probably would be a good solution also. Then you could buy a new lens with the money you would have spent on the repair. Actually you are lucky that the lens can still focus after a fall.
I hope this helped and good luck!
Nov 13, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Autofocus quit working
Do this:
- Make sure the autofocus button in the front of the camera is set to AF
- Make sure your AF switch in your lens (if it has one) is turned ON
NOTE: Please rate our help to keep this free service online
Jun 16, 2009 | Nikon D80 Digital Camera with 18-70mm Lens
I have the Nikon 18-200 lense and it will not autofocus on my D80. I tried other lenses on the camera and they auto focused, so I presumed it was the camera. I sent it for repair, received it after being...
Try you 18-200 lens on another Nikon DSLR. If it still does not Autofocus. It is the lens. Sometimes the electrical contact points of the lens are not making correct contact with the camera. ok?
Mar 05, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Autofocus problem
sir, replace ur lens image reading sensor
Apr 06, 2008 | Nikon D50 Digital Camera
Problem shooting portrait
That's just the quirky autofocus of the d80. Try tilting the camera diagonally to focus and tilting back up to shoot.
Unfortunately, autofocus issues like those are the difference between a d80 and a d200/d300 :/
Mar 20, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 auto focus
I had the same problem but then I realized the lens was not "in" all the way.  It had not clicked into place when I changed lenses.  This might work for you....it did for me.
Oct 28, 2007 | Nikon D50 Digital Camera
Nikon D80 Digital Camera with 18-135mm Lens Logo
135 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
