Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser and Ice Maker
The refrigerator is only 2 years old (model GSH22JFTACC) and over the past couple months I could not get water or ice out of the dispenser. I placed a blow dryer to the dispenser from the inside of the freezer door, I was able to defrost something to get the water and ice to dispense. However, it keeps freezing back up. Any ideas ideas on what is going on? Is this the defrost heater? or is it the computer module?
  • 120 Answers
It might be your selenoid that closes the ice door in the chute but the water thing is says another thing might be wrong if you need service call 562-688-3627
Posted on Oct 12, 2008
The water dispenser is not putting out water and ice maker is not making ice. The fridge frequently cycles like it is trying to send out water.
it's still under warranty for up to 1 year,call whoever you bought it from and it should be repaired free of charge and next time you write send model number.
Dec 08, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
It's not making ice. Not sending water to the ice maker. I replaced the filter this morning. Water is dispensed for drinking , but not for the ice maker.
I just replaced the water valve because my water dispenser in the door kept dripping. Google parts for your model and put in water valve. It will cost around $80 for the part. My sic year old did most of thr reacement after watching an online video.
Aug 22, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a side by side with ice/water dispenser on the freezer side of the door. a couple of months ago the ice maker stopped working and just today the water stopped coming out the dispenser and none of...
1light not work , may lightbuld loose in the socket , or door switch
2 ice maker not work? may the ice maker arm shut-off. sut-off arm to be on(sure be down position)
3 is the ice maker switch in the off positio ( on some models)
4 is the freezer door not closed completely ? if it will not shut all the way,push the door firmly shut for the water dispenser poblem
5 check water filter. or water valve clogged or bad? replace them if necessary
good uck
Jan 11, 2011 | Whirlpool Refrigerators
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore refrigerator Model No. 106.56839600 water dispenser
Hi
The water is kept cool in reservoir in the fridg. Remove the inlet tube push for water check pressure better worse? Work your way back to valve
good luck
Apr 12, 2017 | Kenmore 21.7 cu. ft. Side-by-Side...
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker repair and still no ice
  • The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser . The valve that the ice-maker relies on may be bad,
  • or it could be the ice-maker itself.
  • Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees.
  • In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
  • Note: The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
btw- you can replace the whole icemaker system for around  $115.00.
  • charging you $250 for a $20 drive motor is ridiculous! my 12 year old son can change the drive motor in 15 minutes.
Jul 06, 2008 | Refrigerators
Kenmore Side by Side Refrigerator Model #106.50544001
It's time to replace the dual water inlet valve (the part the water line connects to). A bit of sediment or other fine object can get in the seat or the material itself can deteriorate and allow a tiny amount of water to pass up to the icemaker.
Jan 04, 2008 | Whirlpool GR2SHWXPB 21.7 cu.ft. Top Mount...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
144 people viewed this question
Top Refrigerators Experts
KJ4QOB
Da Doc
Jim Akins
