Question about Maytag Neptune MDE5500AY Electric Dryer
Where's the power source...
Maytag Neptune dryer panel control doesn't work. Light inside the dryer works when you open the door. Guru posted advice to check the power source on the dryer...where is that and how do I check it? Thanks
  • 1 more comment
  • quintfamily Mar 29, 2009
    Same thing, control panel is dead but the light inside the dryer is working. Checked and have power thru motor drive relay but not the heater relay. Have any ideas? Do you think we need a new circuit board? If yes where can we get one?
  • fitstar360 Apr 03, 2009
    When i first got this dryer, it wouldnt start when i pluged it in.. my signifigant other had to put his special touch on it to begin working... soo, now its doin the same thing because we had to unplug it and its showing 88 and it wont turnon.. gosh dangit!  i need to do laundry!!
  • pino24 Apr 06, 2009
    I have had the dryer since 2002. This is the first time I am having this issue. I plug it in and it goes to 88 then to 54. I can't change from air fluff to sensor or timed drying. The electricity obviously works because I have power to it. If you have had this problem - what was it and and how was it fixed -also, how much was it and did you have a Maytag repair guy or an outside repairman do it? Diane
  • 725 Answers
He most likely want you to check the power at the wall plug...Red to white 120v black to white 120v and Red to black 240v... if you have it at the wall check the other end of the pig tail .. make sure a wire is not burn off at the terminal block...
Posted on Oct 12, 2008
Maytag neptune
Make sure your light control is turned on. Either turn odometer pin or there is a control left of steering wheel that controls the light level
May 11, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Hello all, My MDE7500AYW Maytag Neptune Dryer was working today and just quit. It is plugged in and the drum light works when the door is open, close the door and nothing. No LCD display, no...
looking at schematics looks like you main control board is the faulty part. you have done a very good job of tracing the voltages from the source. been that all voltages are present and door switch is good the part left is the control board. here is the part# 33002886. you can find it at sears website or service center.
good luck to you.
Feb 15, 2011 | Maytag Neptune MDE7500AY Electric Dryer
Maytag Neptune MDE5500AYW panel lights work but not dryer
inside the control panel is a tech sheet that has some diagnostics on it . there is a membrane button test or something to that effect. I suspect that the start/pause button is the problem and you would need to replace the console w/touchpad.about $130-140 new. there are some used ones on ebay.
May 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG4000BWW
check your door switch it might be broken. push the door switch in with your hand. does the light turn off? if no this is your problem
Aug 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Control Panel frozen. Displaying "8.8." Cannot reset.
controls were somewhat an issue with these. but service manual can be found in the maytag library at servicematters.com it will detail method of entering diagnostic and reading codes. post results
May 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
Oct 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryer
hI FOR THIS PROBLEM I WOULD CHECK THE POWER SOURCE AT DRYER
Sep 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Electric Dryer - Control panel doesn't light unless door is open
the power connects for the 240 volts to the outside screws on the terminal block the center connector is the nutral connection
Jun 09, 2008 | Maytag Neptune MDE6800 Electric Dryer
Control pannel wont cut on and dryer wont start
We are having the same problem. We have the Neptune dryer MDE5500AYZ. The control panel doesn't come on. We know it's getting electricity as the light in the dryer is on. Is there a reset button in the dryer?
May 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
is the drum light on while the door is closed?? look on the teck sheet found in the lower front panel for a wiring diagram momery servers me there is a thermal fuse chances are this is bad if you cant find this tech sheet I will look in my invoice book and see if I can find the sheet for it good luck let me know what you find out
Dec 23, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
171 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
