SOURCE: STR8-60 stylus
I suggest you contact the MUSONIC web site. They specialise in cartridges and styli.
SOURCE: TurnTable left channel no signal
Somewhere in the jack or the plug you have a wire broken. You will just have to look for it. If you have a volt ohm meter, this will aid you in finding the broken conductor. When you find the bad connection, you will probably have to solder it back together.
Testimonial: "Very quick response! Helped me get to the next step. Thanks!"
SOURCE: Have a stanton STR8 60 turntable that I forgot
turntables have very low output signal need a phono input to amplify it more than cd,cass. if has mono output use rca conn 2 to 1
Testimonial: "makes perfect sense. thanks for your help"
SOURCE: stanton turntable: STR8-30 need to
You look at the cartridge, determine its make/model number if visible and web search for that with 'replacement stylus'. There is no way we can tell what is installed on it.
