FixYa.com
Tags:
Nikon Fieldscope III 60mm
Nikon 60mm/f2.8 macro
By pandamama - usenet poster
I just bought the nikon 60mm/f2.8 macro.
I purchase it mainly for the macro.
Has there been a review of this lens in any magazine?
Can I also use as my normal lens?
How good is it at infinity?
How does it compare compare to the 50/1.8 or the 35-70/3.3-4.5
I terms of image quality?
One flaw in the lens:
If you are in auto focus mode on the body and lens
then switch the auto focus on the body to manual. The lens
becomes "free floating" changing its focus internally.
This is a real problem because I often auto focus
then change to manual as a form of focus lock.
Is this normal for this lens?
Any suggestions?
John D. Hoford
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 26, 2006
Helpful (85)
LiZzIe
LiZzIe - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
In article <>
And in article <1991S>
(David Jacobson) (that's I, er me, er
whatever) replied:
[stuff deleted]
Sorry for being too anxious to reply and thus wasting net bandwidth. I
should have checked before replying.
My 60mm MicroNikkor does indeed slip when the lens is in AF and the body
in manual, particularly if facing straight up or down.
For serious macro work, I almost always use manual focus. For that the
lens must be in manual mode, and slipping is not a problem, since the
focus ring is engaged and provides friction. If you don't want to do
that, but still want to get a focus lock, cradle the lens in your left
hand. Then you can push the AF lock, which is below and right of the
lens (from photographer's position) with your little finger.
-- David Jacobson
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Joey2
Joey2 - usenet poster
Rating: 0%, 0 votes
in article <>, (John Hoford) says:
No, I LIKE this feature a lot. I switch to manual focus on the lens
and leave my camera in AF, thus when I switch lenses I don't have to worry
about forgetting to change the camera back to AF.
Jeff Wolford uunet!cpqhou!jww
Compaq Computer Corp
(713) 374-9465
(713) 374-9465
Solution #3
Not Rated (0)
jessie25
jessie25 - usenet poster
Rating: 0%, 0 votes
It will, umm, blow the $*&(&$ doors off the 35-70.
Solution #4
Not Rated (0)
lawyer
lawyer - usenet poster
Rating: 0%, 0 votes
I don't know, but lots of people on the net have said great things about
it. I have one and like it very much. Even on 4x6 prints it seems
sharper than my 50mm f/1.8 "normal" lens, but I have not done any
controlled tests.
Yes. But there is one drawback. The focussing is extremely sensitive.
1/4 of an inch on the circumferance of the focusing ring (in manual
mode) moves it from infinity to 2 feet. On the 50mm f/1.8 this takes
about half a turn. In auto mode, this takes 1/2 turn of the screw,
while on the 50mm it takes 6 turns. However, the AF on an 8008 seems
up to it.
Again, no formal test, but it seems fine to me.
As I said, it seems sharper to me than the 50 f/1.8 in general use. But
I've never done a real test. I don't know about the other lens.
For readers who don't own one, there is a rotating lever on the 8008
body that retracts the screwdriver-like blade of the focus moter from
the screwdriver-like slot on the back of the lens. This is the only way
to select manual vs. auto focus on most Nikon AF lenses. But the 60mm
MicroNikkor also as a control on the lens itself. In the AF mode, the
focusing ring on the lens is disengaged. In the manual mode, the AF
screwdriver-like thing is disengaged. The complaint here is that if you
put the lens in auto (expecting focusing via the screwdriver-like slot)
and the camera body in manual, disengaging the screwdriver-like stuff,
that the focusing will drift.
I've never experienced this, but then I haven't really tried it either.
-- David Jacobson
Can you Help with these Spotting Scopes problems?
Spotting Scopes
Crossman Mark 1 CO2 Pellet Gun
I live in Huntsville, Ontario,... Answer This...
Spotting Scopes
Borescope
Need circuit diagram for... Answer This...
Spotting Scopes
Assembly
how to put together a Crossman... Answer This...
Spotting Scopes
not holding air
I have the crosman medalist... Answer This...
Brand New Nikon 60mm Micro 2.8...
I tried to use this lens but... Answer This...
Repair Service
Find Spotting Scope Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
