Question about Panasonic NN-S933BF Microwave Oven
Runs when door is opened, but not when closed.
When a time is set and the unit is started, it will turn on for approximately 2 seconds, then shuts off. After this it starts running as soon as the door is opened. I tried unplugging for a while to see if it may need to reset, but it continues to do this.
  • Mike25655 Dec 18, 2008
    Microwave will run and will turn off as time program. When I open the door, it will start running again.
  • Panasonic Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you only need a switch, you can order a universal type from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Oct 20, 2008
Sharp microwave r1870 only runs for 59 seconds
If it consistently runs for exactly 59 seconds, and shuts off, it's probably the control panel.
If it runs approximately that length of time, you might have a defective thermal protector on the magnetron, or the magnetron is running too warm for some reason.
Mar 24, 2016 | Sharp R-1870 Convection/Microwave Oven
When i use the microwave,it starts for 2 seconds then stops
Robert, I will post links below that may address your problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Microwave Shuts Off After Few Seconds
http://forum.appliancepartspros.com/microwave-repair/2937-panasonic-starts-then-stops.html
Why does my microwave runs for few seconds and stops
Appliance Repair Forums
Feb 24, 2016 | Microwave Ovens
My microwave will not shut off. Doesnit have a reset swith
please unplug it and get it to a tech. Sounds like he timer is shot and could be dangerous.
Jul 08, 2015 | Sharp Carousel Microwave Ovens
Sometimes oven does not work. when ya hit start it just clicks - the screen looks normal for about 2seconds & then shows the clock time.
Sounds like is what's happening:
Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back.
That would be a bad upper interlock switch and charred connector. If so, see:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Dec 11, 2012 | Panasonic NNSN797S Microwave Oven
Starts when closing door
This is a list of possible causes. 1. Defective triac or relay 2. controller is confused (pull power cord for a minute and see if it resets) 3.Defective controller or touchpad.
Mar 02, 2010 | Microwave Ovens
Oven keeps shutting off, says close door or says push start. When you push start again or restart only runs for few seconds and then shuts off again
1)Make sure there is a clearance all round the machine so that there is a good airflow. The sensor is picking up a lack of circulation or heat factor.
2) Chdeck the door switch, it may well not be closing correctly. when the door is closed and prior to hitting start,\; pull the door gently to see how much movement or play is in it. The door should be tight and have almost zero movement. Look at t both sides of the door lock to ensure no debris is preventing it from closing correctly, and the latch itselof is not broken!
Thanks for using FIXYA
Oct 13, 2009 | Microwave Ovens
Model 565.66400, still runs when door is opened?
if unit runs with door open then one of the door switch is stuck closed.there are 2 door switches and they could be assesed by removing the control panel.disconnect wires from top and bottom switches and chkf for continuity.they should be normaly open when the door is open and closed when door is closed.one of them will closed even when door is open.replace that bad one.
Aug 11, 2009 | Kenmore Microwave Ovens
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
JVM1650SH01
your problem most likely is in your door aligment there are 2 arms that need to close some door interlock switches inside the unit next time press in on the door hold it and try to start or push down on the door after it is closed and try to start it
Jan 23, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Open Questions:
Panasonic NN-S933BF Microwave Oven Logo
115 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
