Question about HP Officejet 5610 All-In-One InkJet Printer
Ink cartridge won't release
Ink cartridge will nt release so I can replace
    Novelist:
    Scholar:
  • 111 Answers
The replacement process isn't always very intuitive. Fortunately, HP.com publishes a web page with detailed instructions:
Replace the Print Cartridge
Good luck.
Posted on Oct 10, 2008
Prnter won't recognize red ink cartridge. When I push down on the cartridge the recognition light comes on, but goes off when I release to close printer cover.
My printer just died. The first indication of a problem was ink cartridges not being recognized. I replaced 3 in one night. The next time I went to print the entire unit just lost power and will no longer power on. From what I've been reading a bad print head can fry the logic board. At that point the only solution is to replace the board. For a 5+ year old machine and a logic board that will cost ~$100, it doesn't seem worth repairing.
Dec 14, 2012 | Canon PIXMA MP830 All-In-One InkJet...
My Pinnacle Pro 901 is set to print using black ink only but it keeps telling me I need to replace color cartridges and won't print.
You won't be able to print if one of the cartridges is out of ink. The printer needs all cartridges with sufficient ink levels to prevent damaging the printhead.
Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
Oct 25, 2012 | Lexmark Pinnacle Pro 901 All-In-One Inkjet...
My HP 940C printer won't move the ink cartridge
Symptom look like carriage jammed in service station,open cover gently try to pull carriage out if its jammed, open top & side covers, release service station capping through manually rotate gears, once its released, push carriage left side, remove service station & verify why its jammed, if found any breakage replace it, or clean it..but little bit technical skill required..see the similar diagram below:
Dec 22, 2011 | HP DeskJet 940c InkJet Printer
E15 keeps flashing and wont let me use printer
issue: ERROR LED: E, 1, 5
Solution: Reseat ink cartridge (MP150 / MP170 / MP450) Reseat Ink Cartridges Reseat (remove reinstall) the ink cartridges if an error appears Removing Ink Cartridges: After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.Press down on the semi-circular tab to release the cartridge and then remove it.Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.Note: Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.nstalling ink cartridges after confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position. Note: After confirming that the scanning unit support is fixed into position, release your hands.Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.) Confirm that the ink cartridges are installed properly <1> The ink cartridge is not installed properly.<2> The ink cartridge is installed properly.Fold the scanning unit support and close the scanning unit (printer cover).Wait until the preparatory operation is complete; it takes about one to two minutes
Oct 01, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Hi, I have the Canon Pixma MX310 and I tried to replace the ink cartridge but I messed i up and I still don't know how to replace it... I think it's error 5100 or something because it says it on...
Installing ink cartridges:
Make sure that the machine is turned on, lift the Scanning Unit (Printer Cover) with both hands, then pull the Scanning Unit Support (A) down into place.Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.Note: - Do not attempt to reattach the protective tape once you have removed it.do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
  1. *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  2. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)Confirm that the ink cartridges are installed properly.OR
  3. <1> The ink cartridge is not installed properly.
  4. Fold the scanning unit support and close the scanning unit (printer cover).
  5. Wait until the preparatory operation is complete; it takes about one to two minutes.
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
Sep 24, 2011 | Canon PIXMA MX310 All-In-One Printer
When i try to print give message that '' ink has run out, replace the ink cartridge and close the cover" and so on the orange light is blinging.
Ink has run out mean in cartridge ink level counter reach zero level. Cartridge can not be used again even though it was refilled, because the counter still reads zero level.Replace the new cartridge or reset the counter using ip1600 ink level resetter. But I thinkthe more effective is to turn off the ink level counter. Just press the ink button about 30 seconds and then release. After that will appear ink level counters have been released.In the ink image on the monitor status will appear gray.
Feb 09, 2011 | Canon PIXMA iP1600 Printer
Epsom printer dx7450
you could have one of several problems here.
i,d suggest printing several test pages, and observe whether the red comes through after this.
if this does,nt work remove the cartridge, and replace ensuring the cartridge goes in with a firm click.
finally if you have the original software installed for the printer, try a head cleaning operation.
Mike @ Compurepair.
Jun 22, 2008 | Epson Stylus C60 InkJet Printer
Photos
give your printer a DIAGNOSTIC TEST , is a cleaning test procedure of the ink cartridges, there you should know if you need to replace the ink cartridges.hope this helps AJ
May 08, 2008 | Canon PIXMA MP470 All-in-One Printer
Epson stylus cx4200 all-in-one?
1. Make sure the printer is turned on.
2. Make sure the document cover is closed, then closed, then open the scanner.
(Do not open the scanner when the document cover is open).
3. Press and release the ink button. The 'On' and 'Ink' lights flash.
If one of the cartridges is low or empty the printer moves that cartridge to the 'ink out' mark. Go to step 4.
If no cartridges are low or empty the ink cartridge holder moves to the ink replacement position. Go to step 5.
4. Pree the 'ink' button again.
If more than one cartridge is empty or low the next cartridge moves to the 'ink out' mark.
Once the printer identifies all the empty or low ink cartridges the print head moves to the ink cartridge replacement position.
5. Open the cartridge cover, squeeze the tab at the back of the empty cartridge and lift it out.
6. Before you open the new cartridge package shake it four or five times and remove it from the package .
(Don't remove or tear the label on the cartridge otherwise ink will leak out) .
(Don't touch the green chip on the front of the ink cartridge - you could damage the cartridge).
7. Place the new ink cartridge into the cartridge holder and push it down till it clicks into place.
8. Replace any other cartridges that need replacing.
9. Close the ink cartridge cover and press it until it clicks into place.
10. Close the scanner.
11. Press the 'ink' button. The printer starts charging ink and the 'on' light starts flashing . This takes about a minute . When it's finished the 'on' light stops flashing and remains on and the 'ink' light goes out.
You'll see all the above, with helpful pictures, at
this Epson support page
Mar 19, 2008 | Epson Stylus CX4200 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
