Question about Toshiba Satellite M35X-S349 Notebook
Battery Charge and shut down
When I turn the comoputer on the battery charge light goes on until just before windows boots up. Then it goes off.
The fan runs for 3 seconds when I first power up and then never runs again unless I turn the computer off and then turn it on again then it runs for three seconds again.
When I run any memory intensive application the computer seems to shut down due to overheating.
I'm really at the end of my rope on this.
Please help.
pete@tzgroup.com
  • pete268 Oct 10, 2008
    Frenzy,
    How do I do that.
    And thanks.
  • acruz8489 Mar 12, 2009
    This happens to mine as well. I'm running on BIOS ver2, the most recent one.
    Sergeant:
    Champion:
  • 258 Answers
There's is some problem with the bios setting set the bios setup to default setting to get back to its stable settings
Posted on Oct 10, 2008
  • Efren Javier
    Efren Javier Oct 14, 2008
    during the computer startup,press del or F2 then a blue screen appears that's the bios setup and find bios defaults then hit that then reboot and check if the problem still occurs
How long have u got to charge it for for 1st use because I charge it all day when I turn it on the next day the battery kept going down I'm still charging it
A new battery comes charged well enough to start the car, if it keeps going flat u have a problem either with the charging system or a power drain, so once car is turned off sonthing is staying on draing the battery. Or the battery could be faulty but very unlikely. To check the charging start car and put a volt meter on the terminals of the battery should be reading aprox 14.2 v if it only reads 12 something then u have a charging fault. If charging fine then have to test for a power drain and the easiest way to do that is to open bonnet or boot depend where battery is lock the vehicle up and wait about 20 mins for the car to shut down Ecus etc remove earth terminal off battery and put a 12v bulb from the earth terminal of battery and the earth lead if the light shines u have a power drain remove each fuse in turn remember to put it back after until light goes out then u have the offending circuit. Hope this helps
Jan 23, 2015 | Cars & Trucks
Charging battery compaq presario c700
If you can reach inside the computer and rub the battery contacts gently to remove the corrosion ,which is invisible , this will help greatly. Sometimes even a new battery will suffer the same. Clean the battery contacts also turn off the laptop and charge it fully do this on a regular basis. Say once every 2 months
Nov 05, 2013 | Computers & Internet
Power schemes battery
Chances are that your battery doesn't / wouldn't hold a charge anymore. The laptop runs off battery power. When it is plugged in, the AC power "goes right through the battery", to support the laptop's operations. When the power cord is unplugged, and the battery doesn't hold a charge, the laptop will shut down, as your battery is (too) low to continue supporting the laptop's operations.
The easiest way around this problem is to get a new battery for the laptop.
If your battery is (quite) new (and a Lithium battery), you may wish to see if you can "revive" the battery's "life" ... first by depleting the battery (completely), then charging it (until it shows it is full, plus a couple more hours), and repeating this process a few times. If you're lucky, the battery will slowly/gradually start to hold some charge, but, don't expect it to be very long.
The (preferred) way to use re-chargeable batteries is to charge it fully, unplug it from the external power source, use it until it is depleted, then plug in the external power source to charge it up (fully) again .... and NOT to keep it on a power source all the time.
Oct 26, 2013 | Lenovo G500 59373039 Intel Core i5-3230M...
My dell inspiron1750 is on idle, not charging the battaery
Is the battery fully charged? Is the battery dead? Shut down, unplug , remove battery, reseat battery, reboot. Will it boot on the battery only? If no replace battery.
Dec 23, 2012 | Dell Inspiron Computers & Internet
Battery charging problem on my asus x50rl, onto 2nd battery now, initial charge ok but will not charge up now
you may need to recalibrate the battery, to do this you need to run the laptop until it shuts down due to power, turn it back on and on boot press f2 or w/e your bios key is and plug it back in then let the laptop run until it dies again. plug it in and let it charge completely. i hope this helps
Jan 03, 2010 | ASUS Computers & Internet
My aspire one d-250 battery doent charge
My problem was: Although the Batt Light shows the "charging" the desktop indicators show the battery is at 100%. If you dscinnect the power supply the computer dies.
SOLUTION: I found this worked on both occasion it happened to me occasions.
1. Shut down the netbook.
2. Remove battery for +- 15 min.
3. Replace battery.
4. Do not switch on netbook, ie boot up, until charge light goes to green ie indicates fully charged.
Dec 28, 2009 | Acer Aspire One PC Notebook
Shut off
If the battery has gone flat before you started re-charging it, the phone has turned itself off.
Let it charge for 5 mins, then hold the red button down until you see it re-booting. You can use it while its charging.
Sometimes the cellular phone receiver does not come on when it reboots, if the battery isn't charged enough - when you make a phone call it will let you know and ask to turn on if the battery is charged enough.
Store it in the special holster it came bundled with - when you put the phone in the holster it has something that turns off the display to save battery (phone still on) and other useful things like activating vibrate mode.
Enjoy.
Sep 02, 2009 | RIM BlackBerry Storm 9530 Smartphone
Battery won't charge
a car battery? how eactly do you do that?
May 22, 2009 | HP Hewlett Packard Pavilion DV9500T 17"...
Turning on problems
plug ac in...turn on pc...wait for boot then press and hold power switch(on pc)down until you hear shut down .restart.
if no luck remove battery and do the same precedure(without battery )
if/when pc startup and is in windows replace battery anytime.
Apr 10, 2008 | Toshiba Satellite A25-S207 Notebook
Open Questions:
See all Toshiba Satellite M35X-S349 Notebook Questions
Toshiba Satellite M35X-S349 Notebook Logo
126 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
