FixYa.com
Tags:
Nikon COOLPIX L3 Digital Camera
Replacement of "mirror foam" on Nikon EM ? (by 2 users)
By Joey2 - usenet poster
I'm considering buying a used Nikon EM. However, there is a slight problem
in the camera, and I'm wondering whether it's a major problem or not.
It's the foam that cushions the mirror on its way up, that is alongside the
viewfinder. It is very old, and starts to "melt". It leaves some greasy
traces on the lower end of the mirror, and I think it's not "cushioning" the
mirror anymore. Thus, the mirror goes up and *BANG* slams the viewfinder.
Is it a serious problem ? Can this foam be easily replaced by a service
shop, or can I do it myself with some foam and glue ?
Any help would be appreciated.
Thanks,
Marc
wwwww
g( o 0 )g
--oOO--(_)---OOo
Marc Kossa, Groupe Bull c/o IBM, L3 Support Group
11400 Burnet Rd, Austin, TX 78758 Loc:905/6F-015
.ooo0 0ooo. Tel:(512) 838-1831 Fax:(512) 838-3625
( ) ( ) kossa@austin (IBM) M.K (Internet)
\_) (_/ "Don't shoot at nuclear weapons !" - Travolta in Broken_Arrow
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by nitaboo, posted on Jan 10, 2008
I was lucky enough to find a Nikon EM camera on my way from work one day. I have'nt a clue how to use it but would love to. When I look through the lens I see spots on it. Is there anyway I can have them cleaned or replaced? I really would like to make good use of this camera. Also I need to know what flash to use with it. What the cost is etc. If someone out there can help me I would greatly appreicate it.
Solution #1
posted on May 26, 2006
Not Rated (0)
Bouncy
Bouncy - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
: Hello,
: I'm considering buying a used Nikon EM. However, there is a slight problem
: in the camera, and I'm wondering whether it's a major problem or not.
: It's the foam that cushions the mirror on its way up, that is alongside the
: viewfinder. It is very old, and starts to "melt". It leaves some greasy
: traces on the lower end of the mirror, and I think it's not "cushioning" the
: mirror anymore. Thus, the mirror goes up and *BANG* slams the viewfinder.
: Is it a serious problem ? Can this foam be easily replaced by a service
: shop, or can I do it myself with some foam and glue ?
I've had this done a few times on Nikkormats - the going price is
probably $35 to $50. The EM is very much a bottom-line camera,
and I'm not sure I'd spend much on fixing one up unless the purchase
price was very low.
Look for a deal on a Nikon FE - should be somewhat cheaper than
an FE2 and offers much of the same functionality.
Reed C. Wilson (o) (770) 399-3445
Advance Technology Consultants (f) (770) 512-4096
5 Concourse Parkway, Suite 2800 email: rwil@atc-usa.com
Atlanta, GA 30328
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Riddle
Riddle - usenet poster
Rating: 0%, 0 votes
This is a fairly common occurance for older Nikons. Point of deterioration
probably relates to your local air pollution and storage conditions. If you
value the camera, you should probably correct the problem.
I've had it done a couple of times by a local professional. If you need a
recommendation, E-mail me.
Solution #3
Not Rated (0)
Bouncy
Rating: 0%, 0 votes
Yes, it is potentially a serious problem. If your mirror is being
jarred as you say, and it is travelling outside its designed
parameters, then there is a good chance your mirror is being knocked
out of alignment.
Another problem is that the "bang" is introducing more vibration in
your camera, and will likely cause blurred images unless you shoot at
a high shutter speed.
Personally, I would take it to your friendly technician, but that's
only because i wouldn't risk doing it myself!
Monty
Solution #4
Not Rated (0)
Pasty
Pasty - usenet poster
Rating: 0%, 0 votes
I've done this job a couple of times and it's quite straightforward. Here's my procedure, for what its worth:
1. Scrape away the old residue with a small screwdriver.
2. Clean the area where the foam goes with a cotton bud and some solvent (use sparingly).
3. Get a piece of dark foam. Pick something with similar 'springiness' to the old stuff.
4. Cut a piece of the foam a little bigger than you really need.
5. Stick double-sided sticky tape to the foam, on one side.
6. Trim the foam to the final size and shape.
7. Pull off the other side of the double-sided tape and stick the foam into the camera. Done!
My Canon F-1n seems quite happy with its new foam. I would be wary of glue as shutters, mirror mechs, etc. and
glue don't get on well together.
John Fryatt Compuserve: 100013,710
London, UK Internet :
Solution #5
Not Rated (0)
M0nica L
M0nica L - usenet poster
Rating: 0%, 0 votes
I'm having the same problem with the short strip of foam at the top of
the Canon FTb-N mirror box. I'd like to simply remove the old foam and
adhesive, cut a small piece of dark foam and cement it in place. Is this
as easy as it sounds, and what snags can be run into??
Harry
Can you Help with these Digital Cameras problems?
no image in lcd screen
I turned on my L3 this morning... Answer This...
My Nikon Coolpix L3 camera...
My Nikon Coolpix L3 camera... Answer This...
lens stuck open position
still have the same proble. I... Answer This...
Lens error
my camera turns on and the... Answer This...
Camera problem
The camera comes on but when it... Answer This...
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
