Question about Canon PIXMA MP600 all-In-One InkJet Printer
Uniformly faded ink
PROBLEM: all colors and black print about 30% of brightness.
CAUSE: She (can't blame her; okay, I can) closed laptop cover while big-colored doc. was sending to printer. Printer seized up, and after several remedies, it printed. (re-installed driver, deep cleaning, aligned heads, etc.)
SOLUTION? I tried all the manual's steps to no avail. HELP?
HINT: printer utility shows Canon S800 - gimp print v. 5.0.0-beta 2
SOURCE: smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Posted on Nov 21, 2008
Bogdy_3003
  • 17 Answers
SOURCE: Canon i9900 printer will not print group 2 colors.
Set your printer at maximum quality and dpi
Posted on Dec 27, 2008
SOURCE: canon pixma ip500 horizontal bands of non-printing areas
Hi it's Gill again. I've been looking around more on the net and I think the problem is our printers need new printheads which I'm told are spare parts easy to change. Hope this helps. Gill
Posted on Apr 03, 2009
SOURCE: Canon Pixma ip3000 printer, changed black ink
i had the same problem and just repeated the cleaning and testing, eventually the black showed up but took more than a few repetitions
Posted on Jun 30, 2009
  • 5 Answers
SOURCE: I have a canon i960 printer. It won't print blue.
I would guess that the printhead is bad. Google cleaning printheads or get a new one. Sometimes , not always you can clean the printhead instead of replacing. (take out and clean by hand)
Posted on Apr 07, 2010
Why do I have white / faded print when printing black? It also has problems printing straight lines - sometimes jagged sometimes just faded.
I do not know for sure but it sounds like the paper is not griped properly, this would cause the jagged lines. I would try another ink cart when the loose paper problem is resolved. I hope this helps.
Jul 23, 2014 | United Stationers HP Officejet Pro 8600dn...
Print quality with black ink is poor throughout the page
hi, i have one of these to, mine is still running on the "test" inks as well but i have all colours in mine, anyway i digress, you can try, going to print something , when the chose printer box apears, choose cpl300 then choose properties ( to the right ) then choose graphics thumbnail, on quality choose best, then at the bottom you will see advanced options, then just click print all txt black, and click darken txt, and that should give you nice black txt....hope this helps
Mar 15, 2010 | Samsung CLP 300 Laser Printer
Black color has faded to unreadable Have replaced all components
chean the black cartridege with a cleanex and tap it to see if ink will come outm if it does bor then it has dried out and needs replacement.
Jan 11, 2010 | Dell 5100cn Laser Printer
All colours and black print faded. Black is a
ANSER #1
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
tanks.
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Color ink cartridge is defective but black cartridge is okay.
No, you can't print with only one cartridge in the printer. The printer needs both of them to close the electric circuit. Remove the color cartridge and inspect it. Clean the electric contacts on it- sometimes, when the contacts are dirty, the printer cannot recognize the cartridge. If that doesn't do the trick, you will need to replace the color cartridge.
Nov 17, 2008 | HP DeskJet 932c InkJet Printer
The printer will not print in color and the black is faded
are your cartridges old and did you remove the protective stickers from them
Nov 08, 2008 | Lexmark X1270 All-In-One InkJet Printer
Can you set default to print using only black ink?
Wow, what an incredibly unhelpful answer. Thanks, HP shill.
The answer is no. Selling ink is how printer companies make money, and they will do everything possible to make you buy more ink, even when you don't need it.
Mar 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
A faded line prints across the page
The imaging bar has speck of dust on it.
Turn printer OFF.
Open the printer. Pull out the transfer roller. Should have a big green handle. Do not touch the roller.
Look inside for a shiny rectangular block about 5inches x 0.5 inch.
This is the imaging bar. Using a lint free cloth with no chemical and no water, gently wipe this bar to remove any specks of dust/paper specks.
Put roller back.
Close the printer.
Turn printer ON.
Problem fixed.
May 02, 2007 | Konica Minolta magicolor 2430 DL Laser...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
old marine
old marine
