My rsa securid shows no code to input for access the only number on the screen is a small no 3 in the right hand botton corner
    New Friend:
  • 11 Answers
This means the device is about the expire. Your SecurID has a expiration date stamped on the back.
Posted on Feb 28, 2014
    New Friend:
  • 22 Answers
It could also be that your system's clock is set wrong. We got "No code" when the clock was set to 5 years ago after we moved a hard drive to another laptop that hadn't been updated since it was imaged by Dell (with Dell BIOS A03) 5 years ago (2010).
Posted on May 26, 2015
2 Suggested Answers
  • 15 Answers
SOURCE: osd menu
This problem is caused by your display driver try updating your display driver.
If you have a graphics card installed then try updating it's software driver
Posted on Apr 26, 2008
My philips flat screen shows no signal and #3 in right hand upper corner just happened when cat knocked over remote no sound
To which model television are you referring? It sounds like you either need to change the input method for the TV or just change to a different channel (2 or 4).
Dec 10, 2012 | Philips Televison & Video
My four year old was messing witht he bottons on the front of my Apex AT2702 television set, and not all it shows is a blue screen with a key symbol in the bottom left hand corner.
There are 7 buttons with its front panel including power ON/OFF switch button.They are; From left to right:- Video, Menu, Volume(-ve), Volume(+ve), Channel(-ve) and Channel(+ve). If these buttons are not there, it will be difficult to operate this set without a remote control. If you haven't the remote contro with you now, buy one universal remote control. The universal remote control suited for this set is COMCAST ON DEMAND CUSTOM-3 UNIVERSAL REMOTE control. The setup codes are:-
0748, 0765, 0767
Jul 11, 2011 | Apex Digital Televison & Video
Usb RSA securID when plug into the usb port, windows 7 says "finding drivers and then errors out with "Unable to find smart card driver"
This pop up only occurs with older versions of the RSA software. Customers should download the latest version of RSA Authentication Client from bres can obtain the SD800 smart card driver -- which is Windows 7 certified -- directly from RSA, but it is not available through Windows Update.
The SecurID "token" from RSA, the security division of EMC, is a two-factor strong authentication mechanism (something you know, plus something you hold). In tandem with a RSA authentication server, a SecurID is used to ID trusted users for firewalls and other restricted networked applications. (It is not itself a firewall.)
RSA's SD800 is a hybrid hand-held authenticator. The SD800 displays a series of one-time passwords, which change every 60 seconds, on a small LCD, but it also has a USB plug that allows it to directly connect to an accessible USB port to offer the full functionality of a smartcard. These include an automated SecurID exchange, cert-based authentication, an array of classic PKI crypto functions, and supplementary key and credential storage.
These are complex services, and they require a sophisticated setup.
The SD800 is intended for Enterprise rather than consumer use. Since the driver must be properly configured by an Enterprise to work in its environment, the SD800 is designed to be installed manually or pushed out by an Enterprise using SMS (along with its complementary GPOs, group policy objects).
The quick solution here is for an Enterprise admin to go back to the vendor, RSA, for the right stuff.
Jan 12, 2011 | RSA Security RSA SecurID Appliance...
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
Numbers 1 2 3 appear on screen and small + in box in right hand corner cant see what they are for or how to get rid of them
Just draw your finger from left to right across the centre of the screen and you should be back to normal. Don't know what the numbered boxes are though.
Jan 24, 2010 | LG GT505 Cell Phone
Batteries in keyfob are dead got new ones,how do you reset for a citreon saxo
From what I understand of the RSA Secure log on is that when the unit goes "dead", the connection to the server is lost. In order to restore the connection you will have to call a Helpdesk and have them refresh the server to "find" your keyfob.
Dec 08, 2009 | RSA Security RSA SecurID Keyfobs Full...
I have a Panasonic TH-50PZ700U, with a green 2'' vertical line in the upper right hand corner. The green line is there regardless of input and is constant. Around the line can have lighter lines at times...
It is the buffer X board. They are loacted at the botton of the set. Replace the one connected to the display panel directly in line with the lines in your picture.
May 08, 2009 | Panasonic Televison & Video
Hi can you help /
You can try a master reset. With the unit off hold your finger on the upper right hand corner of the touch screen and tap the power button.  Continue holding your finger on the screen until you see a message "This operation will erase all waypoints, do you want to continue?" (this could take up to a minute)
Tap yes and the unit should reboot then attempt to acquire satellites.
Oct 09, 2007 | Garmin Nuvi 660 GPS Receiver
Computers & Internet Logo
4,749 people viewed this question
David Payne
David Payne
