Question about Dual XDVD8181 Car Video Player
I have a Dual xdvd8182 code for video play during drive
I already know how to make my dvd show while drving i was wondering if there was a code for my radio I am tired of using that switch
Try this we dont have the same dual model but the code isnt for my model anyway. put a dvd in the player and after it comes up with the warning screen when you start to hear sound hit stop twice on the remote and then press 26604
then just find the parking break override menu and turn it to on
important. you must ground out the wire and take the switch out first! hope this helps.
Posted on Oct 13, 2008
Poszukuje mechanismu lasera do radia dual xdvd8181 czy dostane ta czesc w chicago i czy jest droga prosze o jakies wskazówki pozdrawiam prosze o e-maila w tej sprawie g.skubacz@interia.eu
Posted on Sep 11, 2009
Nexxteck dvd driver downloads. my dvd is usb pnp rw dvd, it doesn't play movies automatically
This is not an issue with the drive. The drive is not what tells your pc to play movies automatically. Anyhow, I don't know what version of windows you are using, but if you click start-help and then type in 'auto play' it will show you how to change the settings so movies will play automatically. Also, if you don't have it already, install VLC media player.....it plays pretty much any video files.
Hope this helps!
Joe
Jun 04, 2011 | NexxTech DRW-6S160P DVD±RW Dual Layer...
How can i bypass my e brake so i can whatch dvd
The e-brake wire is there for liability reasons. If you're in an accident and there is a video playing, you will probably be liable. Also, it is illegal almost everywhere to have a video playing that can be viewed by the driver. This could get you pulled over and fined. This is why the brake wire is there, so the player knows the vehicle is not moving.
May 09, 2011 | Dual XDVD8182 Car DVD Player
How do i bypass the e brake so i can watch dvd
Dual XDVD8182 dvd code
ground the green wire at the wiring harness at the back of the deck but first try setting the e-brake and the code well u just (hold) the next track button 15secs and it should just go past
Mar 10, 2010 | Dual XDVD8181 Car Video Player
The parking brake on my xdvd8182 doesn't work, im thinking a broken wire. Ive tried the codes, grounding with a switch and hooking up to e brake
It is illegal and unsafe to watch the monitor while driving. I assume this is needed for an RV or something.
STEP ONE. Ground the E-Brake wire.
No matter which method you use, you must ground the brake detection wire. I suggest you tap it into the ground wire on your wiring harness (ensures a good ground).
1. FACTORY RESET METHOD (Temporary)
(This isn't the most effective, but it is the easiest to try, so it's worth a shot since it apparently works on some units.)
** Go to the Menu
** Get to the Settings Menu
** Select <yes> to Reset to Factory Settings.
Credit: DKA
Have recently heard complaints of this method not being permanent, as this is needed everytime they want to watch a DVD. Also, radio and screen angle presets are lost.
2. AUDIO CD METHOD (Permanent)
** Insert Audio CD
** Press PLAY
** Press STOP twice on remote
** Enter 26604 on remote
** Press ENTER
** Take out Audio CD and Insert a DVD
Credit: Myself via a DUAL Tech
3. DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Enter 26604
** Press ENTER
Credit: Adam P.
The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution.
Feb 24, 2010 | Dual XDVD8182 Car DVD Player
Load a cd or dvd it just give no disc
I Have a dual XDVD8182 and i want to get a lense for it dose anyone know were i can get the part...
Mar 31, 2009 | Dual XDVD8182 Car DVD Player
I need a Dual xdvd8182 code for vido play during drive and a e-brake override code please thanks
Ground the emergency brake wire,i used the black wire.
Insert an original DVD and let it play until you hear the sound.Copied DVDs will not work for this.
Press the STOP button TWICE with the remote.
Using the remote enter 26604 and press enter.If done you shoul hear it beep and the video will be viewable.
Mar 24, 2009 | Dual XDVD8182 Car DVD Player
I need help with my dual xdvd8182 player
1 Ground the emergency brake wire,i use the radios black wire to ground it.
2 Insert an original DVD and let it play until you hear the sound.Copied DVDs will not work for this.
3 Press the STOP button TWICE with the remote.
4 Using the remote enter 26604 and press enter.If done correctly you should hear it beep and the video will be viewable.
Mar 24, 2009 | Dual XDVD8181 Car Video Player
Dual xdvd8182
Try doing the following:
1. Find the reset button on the unit and press it down for 10 seconds.
2. Disconnect the battery for at least 30 minutes then reconnect.
These simple options usally work. If not you have a faulty unit and its possible that it has been damaged by condensation from the a/c. Ive seen it a good many times especially in Honda's.
Mar 20, 2009 | Dual XDVD8182 Car DVD Player
Dual XDVD8181 Car Video Player Logo
361 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
