I have a canon c6870 copier/fax. I have loaded the drivers on my server but the fax still does not work. Is there something I need to do on the copier itself other than hooking up a phone line.
    Genius:
  • 2,120 Answers
Make sure it's an ANALOG phone line plugged into the LINE port of the fax machine.
Posted on Oct 11, 2008
I have a Canon Multipass C5500 4 in 1 machine. I changed over to Digital Voice system with Verizon and the FAX stopped working. I called Verizon and was told that with Digital voice the jacks were no...
Fax machines (and modems) have trouble over any non-analog line because its not a true steady stream of audio.
One of the best things you can do is to try to force the fax machine to a slower speed.
here is the link to the manual that should help you out
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000019294.pdf
I've heard of some dsl filters helping this, but the real reason behind it is that there is a certain amount of signal degradation from the filter and that basically forces the fax to a slower speed anyway. If you can do it manually it would be much better because the filter will also cause more errors and cause the fax to take even longer.
May 07, 2011 | Canon Computers & Internet
Environment: Windows Server 2008 as Print Server. Canon Copiers iR3570/iR4570. The Canon Driver Information Assist Service is installed on the server. This allows the server to communicate to the...
I believe you have to identify the accesories that are on the copier. I think you go to the printers section of the control panel on Windows. Right click the copier, select properties, then device settings. Look to see if you can change any of the options. If not you may have to reinstall the print drivers. Hope this helps.
Jan 27, 2011 | Canon imageRUNNER C3200 Copier
LBP2900B DRIVER CD
CANON LBP2900B DriversHere is the driver for Windows 2000/XP/Server 2003/Vista/Server 2008/Windows 7
Installation Procedure when Connecting USB Cable
Do not connect the USB cable until after you have loaded the downloaded files.
After all files have been loaded connect the USB cable to the back of the printer.
DRIVERS
Thanks & Regards
M. Nanda Kishore
Dec 29, 2009 | Canon LASER SHOT LBP-2900 Printer
Canon Imagerunner color 3200 copier
you need to load the copier drivers into your server you can down load these drivers from canon website /or your network outlet is not setup
Dec 05, 2008 | Canon imageRUNNER C3200 Copier
Canon MP780 issue on Mac OS/X
I just noticed that I had the telephone cable connected to the "Telephone" port on the back of the Fax/Printer. When I switched it to the "Line" port, suddenly the clicking stopped and the Memory/In Use light went off. Now we will see if I can Fax something. Hope this works for you too!
Sep 28, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Driver not found for server 2003
when you do not find the drivers for windows server 2003, try using the drivers for Windows XP.
Most drivers for XP work on windows server 2003
Canon Download page is Official Canon Drivers and Software
Follow istructions, insert model and install drivers.
Start driver setup with scanner USB unplugged.
Sep 26, 2008 | Canon FAX-L350 Plain Paper Laser
Canon Pixma MP530 multifunction printer comes up as a fax
This is absolutely the right solution. I used this for my Canon MP780 printer under Vista, as well. I want to include all of the keywords here. It is important to note that the DPR-1260 shipped with Firmware Version 1.12 cannot be seen by Visa until it is upgraded with the Version 1.21 firmware, but after downgrading back to the Version 1.12 firmware, the DPR-1260 is still visible and it now recognizes my Canon MP780 multifunction printer as a printer and not as a fax machine. I plan to post this same solution to other sites, so that hopefully others can get their DPRs working again. Whew!
Sep 10, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Problem with Canon I-SENSYS MF 4150
After several days of researching the same problem for the MF4150, the conclusion is that you have to use an Axis or Silex brand print server developed specifically for Canon. Both have been reported to provide Print/Scan/Fax multi-functionality, but it seems Silex is the one Canon really supports (it's only sold on their website) and is most likely to be the least problematic.
Jan 05, 2007 | Edimax PS-1205UWg (PS1205UWG) Print Server
k24674
