Question about Sony Bravia KDL-42V4100 42 in. LCD TV
Every 30 sec I loose audio, 5 more sec and my screen goes black, instant reset then the cycle starts again
I had the direct tv guys put in a HD box. The tv was fine for the rest of the night. I power down and then turn it on in the morning. Now, every 30 seconds the audio goes out follwed by another 5 second delay then the whole screen goes black and instantly brings the picture and audio back. Like it is reseting over and over again. This happens on tv mode and when I ran my blue ray blayer it did the same thing leading me to believe the direct tv guys are not the problem. My TV is a Sony Bravia model: KDL-42v4100
HELP!!! Its like 2 months old!
  • Anonymous Jan 24, 2009
    I have the same problem with my TV at the moment. Did you ever figure out what it was?
  • 1,605 Answers
It is your HD box. get another one.
Posted on Oct 10, 2008
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ... > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
May 8, 2014 - Uploaded by
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Screen goes black and resets during HD shows
Have you already tried to power cycle all the devices? Unplug the power cable on all your devices for about 1 hour then plug it back in. Check if that fixes it.
Aug 31, 2008 | Sony KP-53HS10 TV
Kworld sp1200 with android 4.0 hangs at kworld screen flickers blue light cycles and starts again over and over, no manual reset on unit, any way to perform a hard reset? appears not to be getting to
should be hold power button for 30 sec, then unplug for 30 sec, then plug back in for 30 sec (never release power button until last step) then turn it back on
Dec 11, 2013 | Kworld Computer Co.,Ltd KWorld Wi-Fi...
Tv turns on about 30 sec later screen goes black sound stays on for about 5-10 sec then just goes off then all 3 lights blink looks like a frowning face i have replaced my bulb about1 year ago is there any...
Bad lamp again. The lamp life is not dependent on install date but more the amount of use. Ebay for the lamps, a lot of the time you can get them 50% off for refurbs.
Jul 28, 2011 | Samsung HL-S4266W 42" HDTV
Setting audio to optical makes hdmi video not work
Here is the solution - in the audio settings you have to select optical out or it will still use HDMI. Regards, Joe
Feb 13, 2010 | Sony PlayStation 3 Slim Black Console
Samsung 50" HD DLP TV video goes out
Common problem of a bad lamp call your local repair shop on price and availability of lamp.
Oct 22, 2009 | Samsung DLP HL-P5663W 56" TV
NO output either HD or normal tvs (not on/off botton hold prob)
Hi, The fact that you are getting a load icon when you put a disc in makes me think you have corrupted system files. If you have a spare 2.5 SATA drive you could put it into the PS3 and let it auto-format it, see if that gets the menu back for you. If it does then your current drive probably needs to be reformatted on a PC and then re-inserted into your PS3.
You'll lose your save games (unlesss you can back the drive up on the PC).
Jan 05, 2009 | Sony Playstation 3 (PS3) Console
Screen goes black
here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board.
Sep 08, 2017 | Televison & Video
Picture goes out, sound stays on
I am not familar with that particular set, but this is what I would check (assuming you don't have a surround sound system hooked up to it as it would sound like a tuner problem otherwise). If you have external Audio/Video jacks with cables hooked up to the Direct TV box, move the video cable and see if you lose video when it is jiggled. If so, you either have a bad cable or connection/connector. When you say you have to turn the TV off for about 30 minutes, do you leave the directTV box on? If so, then the problem seems to be with the TV. Otherwise, maybe the direct TV box is at fault -- leave the TV on and turn off the cable box for a half hour and try it again. You have a few possibilities here, good luck.
Jan 20, 2007 | RCA 27R411T 27" TV
Sony Bravia KDL-42V4100 42 in. LCD TV Logo
331 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
