Question about Euro-Pro Shark GI490 Iron
Problem with the iron
The iron heats up, but then turns itself off and then on.
  • 1 more comment
  • teeteeg1 Oct 23, 2008
    the iron auto shut off blakes for about 2mins with ready lights and warm up lights blakes have to unplug iron to start over. then it works for 3-5 mins then starts shuting down. only had for about 6-7 months unhappy
  • phamv164 Apr 28, 2009
    It does not maintain the temperature....it cools down
  • Anonymous May 15, 2009
    The auto shut off does not maintain the temperature, it cools off and won't turn back on to finish ironing even one shirt
    Genius:
  • 1,605 Answers
Tha is the auto-shunt off. it mantains the tempeture you have set .
Posted on Oct 10, 2008
My Iron will not turn on! It hasn't seemed to heat up right lately anyway,but now it won't heat up at all.
Has found all with detailed operation and with comment that from itself this model.Manual HERE
Jul 29, 2011 | Rowenta Irons
My iron does not heat up
The most likely cause is a faulty temperature sensor. The Iron is most likely shutting itself off because it believes that it is already at the correct heat. The less likely scenario would be a faulty heating element. In either case you will not be able to fix this yourself.
Check that the Iron is correctly plugged into a working outlet as that often tends to be the solution we all miss.
Mar 07, 2011 | Oliso TG1050 Iron with Auto Shutoff
Tefal Pro Express GV 8120 Iron. New Iron - will not heat up and turn itself on. Green light just keeps flashing.
If it is a new iron, take it back to the dealer. Any attempt to repair or adjust on it will void the guarantee.
Jan 26, 2011 | Tefal Pro Express GV 8120 Iron
My iron turns off when its hot
Thermostat bad...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Oct 09, 2009 | Euro-Pro Shark GI490 Iron
Auto shut off how to turn back on?
The automatic shut off is a protective device to let the iron cool down when not in use. Normally, if you pick the iron up and sit it down on the board or fabric, the iron will "sense" the motion and click back on to the heating cycle. To turn the iron off, just move the dial to the lowest position, or OFF and or unplug it from the outlet. If left unattended for a while, and when picking it back up to iron, if it does not come back on then you may need to increase the heat setting, move the dial a little, till you see the power light come back on. This is a safety item, and a good one, given the hectic lifestyles we have now, and having busy lives. If we forget to shut the iron off, it does it for itself after a period of non-use. No more trips to the store or wherever and remembering "I forgot to unplug/turn-off the iron I was using". Still, it's best to unplug and or turn it off when not in use. I prefer unplugging, so that it does not be a "vampire device" drawing even little amounts of current when not in use. And it's safest when unplugged and cool.
Sep 26, 2009 | Irons
It shuts itself off
The SHARK ELECTRONIC Iron is equipped with an electronic auto-off. The electronic auto-off switches the iron off if it has been left standing unmoved in any position (sideways, flat or upright) for approximately 7-9 minutes. A red light on the LED display panel will flash when the iron switches itself off. (Fig. 7) To switch the iron back on, just shake the iron side-to-side several times.
Jul 31, 2009 | Euro-Pro Shark GI490 Iron
Shark model G1490 won't heat. Can heating element be bad?
if lights are coming on its either the wire that send power to the heating element or the element itself
Jul 15, 2009 | Euro-Pro Shark GI490 Iron
The iron does not heat up.
heatman101
May 26, 2009 | Rowenta Steam Generator DG050 Iron
The black and decker iron wont heat up
It probably has a high temp overload opened up inside or the thermostat control has gone bad.You can only tell for sure by taking the unit apart and testing the circuit for continuity.The steam feature on the iron is heated by the same element that heats the iron so it wont work.the element itself could also be bad,but I have never seen one go bad.You will have to check each component seperately to find the damaged part.or you can test the whole circuit at the plugs end,and use a jumper across each part until you have continuity through the unit.Make sure the thermostat is turned all the way up.the part that you are bypassing when you get continuity is the bad part.
You can buy a cheap continuity checker at any lowes,or even wallmart for that matter.
Mar 16, 2009 | Black & Decker ICR200 Iron with Auto...
Euro-Pro Shark GI490 Iron Logo
205 people viewed this question
Top Euro-Pro Irons Experts
Henry  Thomas
Henry Thomas
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
