Question about HP OfficeJet 6110 All-In-One InkJet Printer
Please help me send a fax on my HP 5610
I need a step by step instruction to send a fax
    Top Expert:
  • HP Master
  • 77,499 Answers
Send a fax
You can send a fax in a variety of ways. Using the control panel, you can send a blackand-
white or color fax from your HP All-in-One. You can also send a fax manually
from an attached phone. This allows you to speak with the recipient before sending
the fax.
If you frequently send faxes to the same numbers, you can set up speed dial entries.
For more information on setting up speed dial entries, see Set up speed dialing.
Send a basic fax
You can easily send a single- or multiple-page black-and-white fax by using the
control panel, as described here. If you want to send a color or photo fax, see the
onscreen HP Image Zone Help.
Note If you need printed confirmation that your faxes were successfully sent,
enable fax confirmation before sending any faxes. For more information, see
Print fax confirmation reports.
Tip You can also send a fax manually from a phone or by using monitor
dialing. These features allow you to control the pace of your dialing. They are
also useful when you want to use a calling card to charge the call and you
need to respond to tone prompts while dialing. For more information, see Send
a fax manually from a phone or Send a fax using monitor dialing.
1. Load your originals, with the print side up, into the document feeder tray. If you
are sending a single-page fax, such as a photograph, you can also load your
original on the glass.
Note If you are sending a multiple-page fax, you must load the originals
in the document feeder tray. You cannot fax a multiple-page document
from the glass.
2. Press Fax.
Posted on Oct 10, 2008
Please help me set up my hp5610 to send and recieve faxes
Posted on Dec 07, 2008
  • rb1423 Dec 07, 2008
    where or how do you hook up the phone line to your hp5610 and what setting do you set the machine on to send and recieve?
    Thanks
    please help me set up my hp5610 to send and recieve faxes
    Comment posted on Dec 07, 2008
    Thanks
I can not receive fax but i can send fax the printer hp officejet5610 was at the client he receive the error that says fax fail brought the printer to my workshop the printer gives the same error please...
Hi, Make sure that the fax header contains the full 10-digit telephone number of your HP fax product, including the area code.
  1. To modify the fax header, use the following steps:
    1. Press Setup on the product control panel.
    2. Press Basic Fax Setup , and then press Fax Header .
    3. Type personal or company information using the keypad, and then press OK .
    4. Type the phone number, including area code, for your HP fax product, and then press OK .
Regards,
Riztech
May 23, 2011 | HP Officejet 5610 All-In-One InkJet...
I can not fax through my 5610 all in one
Hi, Click here and go to page number 64 to read the features of fax and instructions to send the fax.
Please rate your response.
Thanks, SF
Feb 08, 2010 | HP Officejet 5610 All-In-One InkJet...
How to fax with the hp 5610 officejet printer
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab86
Jun 22, 2009 | HP Officejet 5610 All-In-One InkJet...
Cant fax
Are you sure the FAX line is connected to a working phone jack and plugged into the correct jack (line not phone) on the machine?
Step by step FAX instructions can be found here on the HP website.
Jan 07, 2009 | HP Officejet 5610 All-In-One InkJet...
01.12.2008 i fax to one number. now i want aknowledgement of that fax. its gone or not. How i can find on HP Officejet 5610 all in One System?
You can get the manual here if you do not have one - LINK.
Here is an exert form the manual on this:
If you need printed confirmation that your faxes were successfully sent, follow these
instructions to enable fax confirmation before sending any faxes. Select either On
Fax Send or Send & Receive.
1. Press Setup.
2. Press 2, and then press 1.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send &
Receive
Prints a fax confirmation report for every fax you send and
receive.
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
5610 cannot send or receive fax
There are about a billion reasons you could be having this problem, the most common one being that you don't have a phone line plugged into the fax machine. You don't provide very much information about your problem or what you've tried up until now to solve it.
Fortunately, HP.com has a web page that should help you figure out what is going on:
Cannot Send or Receive Faxes
Let me know if this helps. If not, please post back with more information about the problem. Thanks.
Oct 03, 2008 | HP Officejet 5610 All-In-One InkJet...
Oxd0620230 reset power
Below is the document that i want you to follow exactly in order to resolve you issue.
CLICK HERE ==>> DOCUMENT
Please let me know the outcome after following the steps.
thank you so much.
adonscott
Jul 17, 2008 | HP Officejet 5610 All-In-One InkJet...
I hve my logic board changed, but the fax is not working
If you are able to Send and receive fax from the Stand alone All-In-One then try the steps bellow.
And if the All-In-One software is sucessfully installed then.
Open HP Solution Center and click on Settings and Fax Setup Wizard and follow the on screen Wizard.
Good Luck
Jul 14, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 Fax Failure
You can try resetting the printer.
Step 1. Unplug the power cord at the back of the printer while the printer is still on
Step 2. Press and hold the # and 6 button on the printer while the power cord is disconnected. And keep holdig the two buttons until you plug in the power back again.
Note : do not release the # and 6 when you plug the power cord back in. keep holding the two buttons until the printer would turn on then turn off or the printer would say anything about "reset"
Step 3. Try sending a fax after the successful reset of the printer
Jun 21, 2008 | HP Officejet 5610 All-In-One InkJet...
Important, time sensitive
Please follow the instructions to send fax using your printer model.
Here is the web document:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00423753
Just copy and paste the entire link into the Internet browser's address bar and press enter.
That should resolve your issue.
Regards,
Lawrence
Dec 10, 2007 | HP Officejet 5610 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
1,304 people viewed this question
Ben Johnson
