PHILLIPS 6OIN. NEED INSTRUCTIONS ON HOW TO CHANGE OUT THE FLUID IN TUBES BECUZ OF THE ORANGE TINT IN THE COLOR
    Novelist:
    Champion:
  • 203 Answers
Please email me so I can send you the PDF file on how to do it.
Experttv@comcast.net
Thanks,
Tim
Posted on Oct 10, 2008
My tv has a red tint to it not sure what to do?
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
BEFORE
Set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
AFTER
724bcba.pngSolution #2 - CRT FLUID FIX
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Feb 17, 2013 | Philips Televison & Video
My 50 in Phillips rear projection has a bad green tint and switches to a bad red tint what can I do?
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 10, 2011 | Philips Magnavox 9P6034C 60" Rear...
Magnavox rear proj (model# 8p6044 c102) pic is cloudy/green tint
Yes the coolant gets crud buildup in it over time which will cause the color and clarity to get very poor with obects that will glow around certain bright ojects. You can get the Phillips CRT coolant replacement kit from www.tvrepairworld.com which has the CRT coolant for all 3 CRTs and also includes the Cd with instructions on how to do the replacement.
Mar 27, 2010 | Televison & Video
I can adjust the colors, it looks to orange.
The CRT coolant needs replacement. You can get the phillips CRT coolant at www.tvrepairworld.com the kit contains the coolant and the CD with instructions
Nov 26, 2009 | Philips Magnavox 9P6034C 60" Rear...
Magnavox PTV910. The picture is good but color is bad
the coolant in the blue and green crts has congealed which is causing the red tube to become dominate. The coolant can be changed at home. You can get the phillips coolant replacement kit at the following link which contains the coolant and the CD with instructions.
http://www.tvrepairworld.com/
Jul 15, 2009 | Philips Magnavox 9P6034C 60" Rear...
Slight yellow tint to the color.
replace the coolant in the picture tubes that will restore the color and the clarity. Heres a link to the kit which has the coolant and step by step instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Apr 24, 2009 | Philips 51PP9303H Rear Projection...
Philips 60P8342 picture blurry with orange tint
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Oct 30, 2008 | Philips 60P8342 60" Rear Projection...
60" TV Tint does not work
  • Screen looks 3D
Sep 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Television has an extreme red tint
fluid comnated in blue crt and maybe in green
Jun 24, 2008 | Philips 43P8341 43" Rear Projection...
Color problem with Phillips 53" projection tv
Bet the fluid is bad. You can take the back off and look into the green and blue lens. See if the picture is clear. If cloudy the fluid is bad. Be careful when doing this. Changing the fluid should be done by a tech.
Sep 09, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
