How to replace a dvd rw in a gateway 400 laptop
    Scholar:
  • 54 Answers
Hi esmith0802,
Here we go: Start by powering down your computer. Its easiest if you un-cable everything so you can move the unit to a suitable work location. Remove the unit to be replaced or find the bay in which to install new unit. The old unit will be held in the bay by 2 to 4 mounting screws( a retention clip may also be present). Disconnect the PCI bus cable(this is the ribbon cable that is currently attached to the unit you are replacing. Install the new hardware in reverse order(This would be an excellent opportunity to clean out the dust bunnies, especially around the cooling fan and air intake vent). Make sure the PCI ribbon cable is seated securely and put case back on. Power on the unit. Windows will detect new hardware and install the device, it may ask for manufactures installation cd.
Just follow the given instructions with the cd for installing the extras that may have come with your unit, such as a desktop management utility or whatever. That's it, your done. I hope this helps you.
Thanks for using FixYa.com
Sincerely, cyyyd7
Posted on Oct 10, 2008
  • cyyyd7 Oct 10, 2008
    UPDATE:
    I apologize for the error, I read the problem wrong and gave advice relating to a desktop instead of the Gatway 400 laptop. Disregard my previous post. Again, I apologize for this error.
    Sincerely, cyyyd7
  • 45 Answers
If the nb is still in waranty then Replace it through them, if not then u have to open the NB and replace the drv by removing it.
instructions with screen shots are available on the gateway site for ur model.
  • Imran Fazil
    Imran Fazil Oct 10, 2008
    if the nb is still in waranty then Replace it through them, if not then u have to open the NB and replace the drv by removing it.
Can you use a different stylus for the gateway laptop tablet ?
yes, any tablet stylus with the same plug in will work. Call Tiger Direct and ask them to hook you up for cheap.
Aug 15, 2014 | Gateway Original M285 Tablet Laptop...
I need to replace my Gateway W6501 CD DVD RW Drive
power down unplug, open case, might need to open both sides, undo screws, pull plugs off, slide out replace, close up power up
Mar 14, 2013 | Gateway Computers & Internet
My gateway laptop's dvd/cd drive stopped working, all of a sudden, but it plays music cds, it is just the DVDs that don't play them or even explore... what could it be the problem? how do i solve it? it...
Are you sure yours is a DVD player? It could only be a CD-CD writer, which will NOT play DVDs.
Open your control panel ->system->hardware->device manager and click on the DVD/CD-ROM drives icon. The listed devices will tell you if you really have a dvd player or not. If you do really have a dvd player, try a different dvd
Mar 19, 2010 | Gateway MX3228 Notebook
Gateway mx3222b laptop ram upgrade problem
your computer does not support 1GB memory sticks. The max memory for that system is 1GB which would be 2 sticks configured as 512MB
see below for the specs (i bold, italics and underlined the main part)
Processor Intel® Celeron® M Processor 370
1 MB L2 Cache | 1.50 GHz | 400 MHz FSB Display Screen 14-inch Widescreen Ultrabright™ WXGA TFT Chipset Via VN800 Memory 256 MB DDR2 (1 × 256 MB) SODIMM
Total slots: 1 DDR2 slot | Available slots: 0 DDR2 slots
Expandable to 1 GB Video S3 Graphics UniChrome™ Pro IGP
Up to 64 MB shared VRAM Audio AC'97 2.3 Compliant Hard drive 40-GB 4200 RPM hard drive Optical drive DVD +/- RW Multi-Format Double Layer
Write maximum: 8X DVD+/-R, 6X DVD-RW, 8X DVD+RW, 2X DVD-R DL, 2.4X DVD+R DL, 24X CD-R and 16X CD-RW discs
Read maximum: 24X CD-R/RW/ROM, 8X DVD-R/RW/ROM, 4X DVD+/-R DL, RAM discs Media Reader 4-in-1 Digital Media Manager
Secure Digital™, Memory Stick®, Memory Stick-Pro®, and MMC™ Modem 56K ITU V.92 ready fax/modem Network 10/100 Mbps built-in Ethernet
802.11g integrated wireless (up to 54 Mbps) Interfaces
  • 2 - USB 2.0 ports
  • 1 - VGA external connector
  • 1 - RJ11 (modem)
  • 1 - RJ45 (Ethernet LAN)
  • Microphone jack
  • Headphone jAck
Pointing device Touchpad with vertical scroll zone PCMCIA 1 - Type I or Type II; Card Bus Battery 6-cell Lithium-ion Dimensions 1.1 to 1.24-inches (H) × 13-inches (W) × 9.7-inches (D)
28 to 32 mm (H) × 330 mm (W) × 246 mm (D) Weight 5.01 pounds
  • 2 - USB 2.0 ports
  • 1 - RJ11 (modem)
  • Microphone jack
  • Headphone jAck
  • 2 - USB 2.0 ports
  • 1 - RJ11 (modem)
  • Microphone jack
  • Headphone jAck
Chipset Via VN800
Expandable to 1 GB
Interfaces •2 - USB 2.0 ports
•1 - VGA external connector
•1 - RJ11 (modem)
•1 - RJ45 (Ethernet LAN)
•Microphone jack
•Headphone jAck
Weight 5.01 pounds
Mar 03, 2010 | Gateway Computers & Internet
Motherboard Replacement
I would check Ebay you may be able to find a replacement one for cheap.
Jan 07, 2009 | Gateway MX3560 Notebook
DVD/RW LAPTOP PROBLEM
Uninstall the dvd/rw driver, and reinstall it from the Gateway website. Look for your laptop model there, and they have all the drivers and software for your laptop components.
Oct 27, 2008 | Gateway MX6438 Notebook
Disc drive will not recognize blank discs.
let's make sure that's a DVD RW disk shall we? check the front and make sure it says DVD RW..if it's DVD R, then it can't write.
Mar 17, 2008 | Gateway 7330GZ Notebook
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
