Question about HP Officejet 5610 All-In-One InkJet Printer
I can't figure out how to send a fax
I can list the destination # but when I try to list the settings, I can only go 2 steps & it returns to the destination #. I know there are code #'s for specific settings, etc. but none of the original literature included lists them. Actually, there is NO information on how to use the HP 5610... only how to hook it up.
The scanner used to be wonderful, now that doesn't work either. I get a message that it isn't connected.
    Genius:
  • 1,605 Answers
Go to the link: user manual. it should have all the information you need.
http://h10032.www1.hp.com/ctg/Manual/c00461378.pdf
Posted on Oct 10, 2008
    Sergeant:
  • 320 Answers
Please click on the below link or copy the URL and paste it in your web browser.. And follow the steps..
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01501463&cc=in&lc=en&dlc=en&product=441125
Thank you....
I need to send 1 fax to several recepts
You can send a fax to up to 142 fax numbers, using any combination of dialing methods:
- One-touch Speed Dialing (up to 32 destinations)
Press the desired One-Touch Speed dial button(s)
- Coded Speed Dialing (up to 100 destinations)
Press [Coded Dial] > enter the 2 digit code (00-99) using the numeric buttons and be sure to press [Coded Dial] before each code
- Regular dialing and redialing (10 destinations)
Enter the number using the numeric buttons or [Redial/Pause] and be sure to press [Set] after each entry with the numeric keys
After all the numbers are listed, press [Start]. The machine will scan in the document (memory) and then begin sending it to the destinations in numerical order, starting with One-Touch, then Coded and finally the numbers dials with the numeric keys.
You can also create a group if you frequently send faxes to the same group of people by first saving them as One-Touch and then adding them to a new group.
Apr 13, 2011 | Canon FAXPHONE L170 Plain Paper Laser
I have a scan button but it always reads "usb not connected". It is connected and print. I have tried connecting it to several ports. I turn off the computer and restart. I turn off the printer and back...
Hi
To resolve this issue I need to know the operating system, but however as you did not provide it I will assume your operating system to be Windows XP and provide this below troubleshooting steps.
Solution:
Step 1.
Try copying form front panel and if copying doesn't work, check for the hardware issues with the scanner. If copying is fine then perform below steps.
Try scanning from Windows internal scanning drivers to confirm if the All-in-One is detected in the computer or not.
Step 2. Scan using WIA
To isolate the issue I suggest you to try scanning from the Windows Image acquisition (WIA) wizard on the computer.
Follow the below steps to Scan using WIA
1.Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2.Click Start then Click All Programs then Click Accessories then Click Scanner and Camera Wizard.
3.Follow the Scanner and Camera Wizard instructions to scan images to the computer.
If the scanning is successful, proceed with step 3. If scanning was not successful then I request you to perform the step given in step 4 and then perform step 3.
Step 3: Manually check for Digital Imaging Monitor and populate the destination list
The digital imaging monitor must be running for the scan to function to work. The digital imaging monitor normally appears in the system tray in the bottom right-hand corner of the computer screen, next to the time.
If the digital imaging monitor appears in the system tray, go to the section Populate Destination List.
Please follow these instructions to resolve Scan from Front panel of All-in-One unit issue:
1. Click the Start icon.
2. In the Start Search text box located above the Start icon, type msconfig and then press Enter.
3. On the User Account Control window, click Continue. The System Configuration window displays. Click on the Startup tab.
6. Search the list for the digital imaging monitor, the file name will be hpqtra08.
7. Recheck the box for hpqtra08.
8. Click Yes to restart Windows.
NOTE: If hpqtra08 is not on the list in the Startup tab, this indicates that the driver was not correctly installed. Uninstall and reinstall the driver.
9. Populate the Destination List with following steps:
a. Open the HP Solution Center.
b. Click on Settings --> Scan Settings --> Button Settings.
c. In the window opened, select "Scan to button" tab
d. Click the Destination List tab.
e. Click on each of the programs you want to appear in the scan to list.
f. Click the Add button. This moves the selected programs to the Front Panel Destination List.
g. Click OK.
h. Now try the scan to function from the all-in-one.
To save the above changes I request you to perform steps given below as Dest test.
Perform the dest test:
1. Close all applications including HP Solution Center.
2. Open and run the DESTTEST file from the location:
C:\Programfiles\hp\digitalimaging\bin\Under Destination:
a. (Optional) Set the Category for the Destination List scroll
down menu on WEB_APP.
2. On the 5th option "Close Dest Test After sending to Destination", put a check mark and click on Save Results Before Exit.
3. Click on Exit in the bottom.
4. Now Open the HP Solution center, Click on Settings -> Scan Settings & Preferences -> Scan To Setup.
5. You will see all Button settings on the right side under the front panel destination List. In Case If not, click on Restore Defaults, click on Apply and click on Ok.
6. Push Scan To button on the unit you will see all the Destination List on the unit. Select the appropriate one.
Yours Sincerely...
Roger
Oct 04, 2009 | HP Photosmart C7280 Printer
My F4240 will print and copy but wont scan
Hi
I am providing you steps for Windows XP if your O.S is other then please reply.
Solution ;
Try copying if copying is fine then Scan through WIA.
Step 3: Manually check for DIM
g. Click OK.
Oct 03, 2009 | HP OfficeJet 6210 All-In-One InkJet...
I only get 2 choices in the scan menu what happened to the rest
Hi
As you have not provided me the O.S information I would still like to perform few basic troubleshooting steps.
Step 1:
g. Click OK.
Step 2: Perform the dest test:
For pictorial representation on these steps, please visit below URL:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00280633
Yours,
Roger
Oct 03, 2009 | HP Photosmart C5180 All-In-One InkJet...
I have two problems with my OfficeJet 6310: 1. The fax screens appear Hebrew. Similary, If I try to use the copier from the printer. This is continuously caused by HP Update 2. I can not send out a...
Use the HP Fax Test
The telephone number for this service is 1-888-HPFaxme (1-888-473-2963). The fax service receives faxes and returns faxes within 5 to 7 minutes to the number contained in the fax header. Solution two: Run a fax diagnostic test
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01669474.gif ) on the product control panel.
  3. Press the right arrow (c01669475.gif ) to select Tools , and then press OK .
  4. On the Tools menu, press the right arrow (c01669475.gif ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
Solution three: Check the telephone line and change the HP fax settings Step one: Test the telephone line
  1. Disconnect the telephone cord from the back of the HP fax product.
  2. Figure 1: Two-wire telephone cord c01501963.gif
  3. Pick up the handset of the telephone and check for a dial tone.
  4. On the single-line telephone, dial the fax number of the receiving fax machine.
    • If the receiving fax machine answers the call, continue with the next step.
  5. Hang up the single-line telephone.
  6. Use a second telephone line or a cellular telephone to call the telephone number assigned to the HP fax product.
Step two: Change the HP fax settings
  1. Connect phone line into line 1
  3. Press the right arrow (c01669475.gif ) to select Basic Fax Setup or Advanced Fax Setup , and then press the right arrow (c01669475.gif ) again to change the menu option settings to the settings listed in the following table. Fax menu Fax menu option Setting Basic Fax Setup Rings to Answer 1 or 2 (At least one more ring than a telephone answering machine, if an answering machine is connected.) Advanced Fax Setup Answer Ring Pattern All Rings
  4. Use the HP Fax Test Service to try to send and receive a fax.
If the HP fax product still cannot send or receive a fax, continue to the next solution. Solution four: Check VoIP digital telephone line Using a VoIP telephone service can cause faxing to fail because fax transmissions are sensitive to the timing of the signals used to transmit the fax. If using a VoIP digital line is necessary, changing the Fax Speed Adjustment setting to Medium might improve the ability to send a fax over a VoIP telephone line. Use these steps to change the fax speed adjustment to a lower speed.
  1. Press the Setup button (c01669474.gif ) on the product control panel.
  2. Press the right arrow (c01669475.gif ) to select Advanced Fax Setup , and then press OK .
  3. Press the right arrow (c01669475.gif ) to select Fax Speed , and then press OK .
  4. Press the right arrow (c01669475.gif ) to select Medium , and then press OK .
  5. Use the HP Fax Test Service to try to send and receive a fax
Jul 05, 2009 | Computers & Internet
How to send fax
1. if it's not already green, press the Fax button
2. load your document
3. enter destination fax number
4. press the Black Start button
5. press 2 to start dialing
6. press Stop/Exit button to cancel fax
Jun 24, 2009 | Brother MFC 210C All-In-One InkJet Printer
Cannot send or receive faxes
Use the HP Fax Test
  5. Use the HP Fax Test Service to try to send and receive a fax.
Jun 23, 2009 | HP Officejet 5610 All-In-One InkJet...
In the - IND. XMT JOURNAL - the destination number is wrong
to set the com journal, press function-7-4-set-1-2-set-2-set-stop
to check the phone number you could look in function-7-1-set- keep hitting set till you see the phone number
Dec 09, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Cannot receive faxes
Step one: Check the fax number
Make sure the fax number is correct; include any numbers that you have to dial to use the telephone, such as an area code, access codes for outside lines or long-distance services, and so on. If you have to dial a particular sequence of numbers to make a telephone call from that telephone line, you also have to dial that sequence of numbers to send a fax.
If the issue is resolved, you do not need to continue troubleshooting.
If the number is correct, continue to the next step.
Step two: Dial the number manually
Instead of using a speed dial setting or sending the fax from the computer, dial the number manually from the product control panel.
If the fax sends when you dial the number from the control panel, follow these steps to recreate the speed dial setting and insert pauses in the number.
On the product control panel, press the Setup button.
Press the Left Arrow button ( ) or Right Arrow button ( ) until Speed Dial Setup appears on the control panel display, and then press the OK button.
Press the Left Arrow button ( ) or Right Arrow button ( ) until Individual Speed Dial appears on the control panel display, and then press the OK button.
Press the Left Arrow button ( ) or Right Arrow button ( ) to select an unassigned speed dial entry, and then press the OK button.
Use the product keypad to enter any numbers that must be inserted before the fax number, such as an area code or access codes for outside lines or long-distance services, and then press the Redial/Pause button to insert a pause.
Enter the rest of the fax number, using the Redial/Pause button to insert pauses between the numbers, and then press the OK button.
Enter the name of the speed dial setting, and then press the OK button to save the speed dial setting.
Try to send the fax again.
If the issue is resolved , you do not need to continue troubleshooting.
If the issue is not resolved , continue to the next step.
Step three: Run a fax diagnostic test
Press the On button ( ) to turn on the product, and then make sure the product is correctly connected to the telephone jack.
Make sure that there is plain white paper in the input tray.
On the product control panel, press 6 , and then press 6 again.
This selects the Tools menu and then selects Run Fax Test .
The fax diagnostic test page prints.
Review the results of the test.
If the result of the fax diagnostic test is All Pass , skip to Step four: Reinitialize the fax.
If the result of the fax diagnostic test is a failure, a page prints that describes the issue and offers possible solutions. Follow the solutions on the printout.
If the solutions on the printout resolve the issue, you do not need to continue troubleshooting.
If the solutions on the printout do not resolve the issue, continue to the next step.
While the product is on, disconnect the power cord from the back of the product and from the electrical outlet.
Make sure that the telephone cord is fully inserted into the port labeled 1-Line on the back of the product.
Connect the power cord to the back of the product, and then connect the power cord to the electrical outlet.
When the product is in the ready state, try to send and receive a fax again.
Step five: Test the send/receive functions
Use the product keypad to send a fax. Watch the product control panel display and listen to the sounds the product makes.
If the product is working correctly, the following events occur.
When the product begins to dial, a dial tone is audible, followed by the sound of the product dialing. A Dialing message appears on the control panel display.
When the receiving fax answers the call, the product and the fax exchange tones. A Connecting message appears on the control panel display. During this phase, the product and the fax compare capabilities, exchange information about how to send the fax, and try to establish a reliable transmission speed.
After the connection is established, the product sends the pages of the document. Messages appear on the control panel display that indicate the status, such as Sending page 1 .
Review the results of the fax.
If the fax is transmitted successfully, continue to the next step.
If there is no audible dial tone or the receiving fax does not answer the call, try sending the fax to a different destination. If this second attempt also fails, continue to the next step.
If the receiving fax answers the call and begins beeping, but the Connecting message does not appear on the product control panel display, the product is not detecting the tones from the receiving fax. Continue to the next step.
Step six: Use an analog telephone service
HP Fax and All-in-One products are designed to work with analog telephone services and might experience some difficulties when they are connected to phone lines with digital services. Make sure the product is connected to an analog telephone service.
To obtain digital services information or support, contact the telephone service provider or system administrator.
Step seven: Check the phone cord and fax connections
Disconnect the telephone cord, and then examine the connector on the end of the cord. Make sure the cord only has two wires.
Figure 1: Telephone cord with two wires
Figure 2: Telephone cord with four wires
If the cord has four wires, replace it with a two-wire telephone cord.
If you must use a cord with four wires, use the converter that shipped with product. The converter allows a cord with four wires to work with a device that requires a cord with two wires.
Make sure the fax is connected directly to the telephone jack by a telephone cord. Connect the cord to the 1-Line port on the back of the product.
Figure 3: Fax only
1 - Telephone jack
2 - Telephone line
3 - 1-Line
4 - 2-Ext
If other devices need to use the same telephone jack, make sure they are connected to the 2-Ext port on the back of the product.
Connect a single-line telephone to 2-Ext , and then pick up the receiver and listen for a dial tone. Make sure you are able to dial out using the telephone keypad. If you hear a dial tone and are able to dial out using the phone, the product is properly connected to a working telephone cord and telephone jack.
Figure 4: Fax and telephone
1 - Telephone jack
2 - Telephone line
3 - 1-Line
4 - 2-Ext
5 - Telephone
Figure 5: Fax and PC or modem
1 - Telephone jack
2 - Telephone line
3 - 1-Line
4 - 2-Ext
5 - PC or modem
If you change any cable connections, try sending and receiving a fax again to make sure that the issue is resolved.
Step eight: Remove any other devices from the telephone line
If any other devices, such as a telephone, an answering machine, or a modem, are connected to the telephone line, remove each device.
NOTE: Remove each device even if it is in another room, connected to another telephone jack, or connected using a line splitter.
Connect the product to an analog telephone line by connecting one end of the two-wire telephone cord directly to the telephone jack and then connecting the other end of the telephone cable directly to the 1-Line port on the back of the product.
Try to send a fax again.
Step nine: Perform a partial reset of the product
A partial reset of the product returns all fax settings to the default values. It might be necessary to reset the language and country/region settings after the partial reset is complete.
Disconnect the power cord from the back of the product.
Wait 20 seconds, and then press and hold # and 3 on the product control panel.
Connect the power cord to the back of the product, and then release the buttons when the product turns on.
The product is reset to factory defaults.
Try to send and receive faxes again. If the problem still exists, continue to the next step.
Step ten: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Aug 05, 2008 | HP Office Equipment & Supplies
Fax unable to receive and send.
Some basic troubleshooting tips are listed below to help determine the cause.
Check the following items :
Ensure the phone cord is plugged directly from the wall jack, into the back port of the fax machine marked "Line", "To Wall Jack", or with a wall jack symbol
Remove any other device from the line such as splitters, credit card machines, or telephone answering machines and retry.
Turn Error Correction Mode (ECM) off ,
For turning off ECM > press set up > press ok >go to advanced fax set up by using the arrow key > press ok > press arrow key go to OFF > press ok .
After these steps > try to send a fax to undermentioned number , once it is sent u will recieve a confirmatory fax in return as well .
self confirmatory no for fax 1 888 473 2963 .
or u can try to send a fax to a different local number as well.
Thanks
Apr 25, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
26 people viewed this question
Ben Johnson
