Schneider STV 1404-T is locked
Hi when T.V is switched on cannot get a channel.in the middle of screen LOCKED flashes in Red letters,Ta.
SOURCE: locked or wiped?
Hi , i had the same problem when i went to the download site to make my device up to date , a red x apear in bottom right of the screen and everything freeze , i call the help line and they make me format the harddrive inside the device , i format the device by going to my computer and locate the storage mine was f: , after formating the device i go back to the tomtom home software version 2.1 and download the application software version 7.162 and the map software usa-canada version 710 , install first the application and then the map , after that be shure to click device at top of the tomtom window and click disconnected device , after a message will apear with (you can safely disconnect your device) , i whent outside for a try and it came back at normal operation , hope it will help , good luck !.
Posted on Jan 19, 2008
SOURCE: Recieving "Locked" display message but don't know how to clear it. No reset switch or panel lock button
I have the manual and it is called "child lock" go figure it stumps us adults. Anyway...holding the power button down for approx. 8 seconds can toggle this feature on / off
Posted on Dec 20, 2008
deejaykrish
  • 63 Answers
SOURCE: i need to find the code for my schneider STV
The basic remote code for Schneider is 0065 on the sky remote Ver 8 or 065 for the earlier remotes.... this is a generic TV code that will work with most Tvs.... try it!!! look at Sky Services to set the code
Posted on Jan 17, 2010
  • 1274 Answers
SOURCE: All Channles locked out
To clear all locked out channels, press the SRCH button, select the bank you want to clear, press the FUNC button, then press the L/OUT button, then press FUNC button,then 6, press 1 to clear all...hope this was helpful...
Posted on May 20, 2010
  • 117 Answers
SOURCE: TV went to black screen with red wording saying Sparrad
try hard reset unplug for hrs
Posted on Jun 24, 2010
Galaxy ace red letter on idle screen after odin
Try to flash official firmware on your phone using odin
Jan 14, 2012 | Android Galaxy Ace
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony Bravia KDF-50E2010 LCD Convergence Problem
Well this is the fix for the usual Ghosting problem....
To bring up the "service" menu, put the TV in standby mode, then press in sequence :
Onscreen Display ( the little screen with the i+ in it )
5 ( channel number 5 )
Volume Up ( upper end of volume button )
Analogue ( middle top button )
The TV should switch on and when it's warmed up, you should see a screen with lots of big green lettering on it.
Press the "menu" button ( middle bottom )
Use the direction dial to move down to "LCD Drivers" and press right on the dial to enter this menu.
Move down to "S H Pos Reg R". It should be "10", change it to "11". ( Left/Right to adjust )
Move down to "S H Pos Reg G". It should be "10", change it to "11".
Move down to "SHPos Reg B". It should be "10", change it to "11".
Press the menu bottom to drop out of the menus, and the standy button to drop to standby. Switch back on, and hopefully your ghosting will be gone hope this works davy mac
Dec 21, 2008 | Sony Televison & Video
Sony TA-N9000ES Flash light when turn on.
an amp of this size generates alot of heat internally when in use as these use mosfet ICs and can get very hot.
your problem is most definately dry solder joints and possibly quite a few at that.
i've repaired quite a few sony surround receivers with similar problems and have all been down to dry solder joints.
hope this helps.
Jul 26, 2008 | Sony TA-N9000ES 5-Channel Amplifier
Unlock Hyundai TV
motimoti 's solution worked. Thanks.
By the way, how do you find the solution ?
Apr 21, 2008 | Televison & Video
Instructions on how to change channels on TECHNIKA MODEL TA-13
Basic Instructions for Technika Model TA-13
On this model there are 7 buttons:
Left to Right these are:
PTT, Push to talk on lh side as screen faces you.
Power/Menu
Scan
Call
Down
Up
Torch Light (on rh side)
Assuming you have used the power button to turn on the radio, the default channel after installing the batteries is 1 or else the last channel to be used.
Press the power/menu button once-briefly, (the current channel will flash for about 10 seconds.) Then use the Up and Down arrows to change channel. Wait for the remaining few seconds and the radio will return to normal operation.
Press the menu button twice, the letter H or L will appear and can be altered by the Up and Down keys to change the power level of the radio. I think this is transmit power which may help you avoid infuriating local taxi companies. Switch back to High power when you're about to go out for the night and need a ride.
Press the menu button three times. This will turn off Squelch control and make a terrible din. Not terribly useful unless you want to pick up a really weak signal (or find out where the taxi driver has taken your neighbour.)
An easy way of finding a channel is to press and hold the Scan button and then the device will rotate through the available channels looking for a signal. When someone transmits, the scan will pause and you can capture it by pressing the PTT button for a second or two. I have found this helpful in pairing my radios with other sets, or picking out channels that work with friend's radios.
Finally, Volume control is really simple, just up and down when not in any other mode.
I had the instructions, which I think included a mention of all available channels I'll scan and post them if ever I find them. hope this part helps though.
Jan 29, 2008 | Radio Communications
Haier HTF20R21 20" flat screen
In google search, type in the words "the word "factory on my tv", and it comes up with solution..it worked first time for me!.. Bill
Jan 23, 2008 | Haier HTF20R21 20" TV
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
