Question about IBM ThinkPad 600E 2645 Notebook
Will not boot up
I have a 600e ibm that will not boot up. When you turn the power on, it acts like it wants to start up but the screeen will remain black. There are 4 panel lights on the top and only the left (yellow) and right (green) will come on. I believe the yellow might be the hard drive light, not sure. I did take the hard drive out of this one and installed it on another 600 e and it ran fine.
Thanks
David
  • 2 more comments
  • dkk3000 Oct 11, 2008
    I did try and hook up a external monitor and had the same problem. Not sure what started the problem;; it seemed that one day, I went to start and t would not. However, I can remember that if i pressed the bottom of the laptop, it would sometimes start. Not sure if that has anything to do with it or not. I do have about 64 m of menory in one of the slots.
    Dkk
  • dkk3000 Oct 12, 2008
    When I put the hard drive in the other ibm, it booted just fine, however, when I put it back in the original 600, it will not boot. The screen remains black. I'm not sure how to boot or bring up using the f keys. I thought it was f12 to bring up to dos or the set up screen. I did hook up a different monitor and it still did not boot. I wouldn't think it would be the cmos battery.
  • len52155
    len52155 May 11, 2010
    so it has booted with the existing cnfiguration?
  • len52155
    have you attached an external monitor? could be the lcd is just bad and the lappie is ok. additionally, what about the memory? if its incompatible you'll get lights and nothing else. what exactly happened to get you to this point? something had to change.. like did ya drop it? dump coffee on gthe keyboard?
Thinkpad 600E won't boot from disk
Set the boot order to boot from cd drive first, to enter the bios ...
With the unit powered off, hold the F1 key and power the unit on. Keep F1 held down until Easy setup appears.
Jul 17, 2010 | IBM ThinkPad 600E 2645 Notebook
Can't get the IBM Think Pad 600E to start.
You need to get into the BIOS setup.
Turn off power to the computer. Wait about 30 seconds. Hold down the F1 key while you turn
on power and keep holding down that key until the setup screen comes up. Go to the network boot section and disable Network Boot. Save setting and restart. That should fix it.
Mar 15, 2009 | IBM Computers & Internet
On a ibm 600e, how do I boot from a cd? I'm
ok go to the bios system by pressing esc or F12 or F2 key when the computer restart. After that change the boot sequence. CD drive first after that HDD or follow the instruction that are given by computer in bellow or side, after configure just press F10 for saving.
Mar 14, 2009 | IBM ThinkPad 600E 2645 Notebook
Ibm think pad 600e
Do a search for memtest86.iso. Burn this image to a cd and reboot your computer. When your computer reboots it should begin checking your memory for errors. If you still have problems it might be your hard drive.
Feb 13, 2009 | IBM ThinkPad 600E 2645 Notebook
IBM 600E 2645 won't boot from CD rom
You can go into the BIOS and change the boot order of the drive devices,change the CD as the 1st boot device.
OR
As the laptop boots up, press F12, this will allow you to select the CD as a boot device.
Dec 07, 2008 | IBM ThinkPad 600E 2645 Notebook
Windows 98 reformat to windows 2000 SP2?
i think it is not possible to install windows 2000 sp2 on your machine,becoz the configurations is not suitable for windows2000 sp2.You may try some other os to boot.
Aug 23, 2008 | IBM ThinkPad 600E 2645 Notebook
IBM ThinkPad 600E problem
might wann redo it or repiar it with orginal xp cd ok boot into cd
Jan 25, 2008 | IBM ThinkPad 600E 2645 Notebook
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
206 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
