Philips 21ST2430/10B - No picture/No sound
On standby LED is red. When I turn TV on, there's no picture and no sound, but LED is green.
  • Anonymous Mar 20, 2014
    When I switch it on the red LED turns blue but there is no picture nor sound.
    Champion:
  • 252 Answers
There's a problem with your tv set, if you know how to solder, then resolder first your tv, but be carefull of short circuit
Posted on Oct 11, 2008
Proscan LED TV Will power up the red standby light & standby on amber when turned on but does not show picture or sound unless I unplug and replug over
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 14, 2016 | Proscan Televison & Video
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
Hello, I have recenty acquired a Philips CRT 29PT9420 Television. However. when i attempt to turn the TV on, the light at the bottom of the TV (Standby, On, Off light) flashes between green and red for 2...
Switch the TV on: Press the power switch A on the front of the TV. A green indicator on the front of the TV lights up when the screen is on. If the indicator is red, press the
-CH + keys on the remote control.
The green light blinks every time you press a key n the remote control.
Ref. link:
https://www.manualslib.com/manual/173137/Philips-29pt9420-69r.html?page=4#manual
Oct 11, 2017 | Televison & Video
I bought my son a 19" philips tv model # 19pfl340d/27.in order to turn tv on it must be unplugged for 10-15 minutes.The first one I bought did the same thing and I returned it.this one is exactly the...
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
Nov 11, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
I have a Philips Plasma tv 42pf5321d/37 with sound but no picture
Thats the great sound of Exploding capacitors on either the power supply board. or another one in there. Now the set is in fault protection. It tried to warn you with the RED blinking LED that there was something amiss by shutting itself down. When you unplugged you reset the error and allowed it to do it again.
Best Regards and Smper Fi
Jun 23, 2009 | Philips 42PF9630A 42 in. Plasma Television
Philips 42fw3090/17 don't turn on, only LED comes on red
first thing i would do is take the lamp out and look at it, it dhould be on the left side of the tv, you will see a little door at the bottom
Jan 10, 2009 | Philips Televison & Video
No picture but normal sound.
projection bulb needs replacement
Aug 11, 2008 | Televison & Video
Philips 29PT9418/69G
A qualified tech will need to practice visual acuity technique! Look at power supply circuit for signs of stress,dis-coloration and/or bad connects.Check for bad 47mf/25v cap in area of stress.Replace BC-327-25 xistor w/BC-328 and replace BC-337-25 w/BC-338,if present in your set's chassis style.
Sep 25, 2007 | Philips 25PS40S 25" TV
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
Electro Med Services...
