Question about Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
Putting back together a poulan 1500le leaf blower
Cord would not retract so i started taking apart when and everything came apart.need manual showing how to put back together
  • 1 more comment
  • e_is_tired May 12, 2009
    The spring will not enguage . How do I rewind and how does it enguage or attach to th eRope coil?
  • Anonymous May 20, 2009
    no spark ..leaf blower engine
  • zacjobob May 23, 2009
    was attempting to start blower for second time this season and cord would not pull out like it did. I tried several times and when it did pull out I noticed the spring had come undone. I took off the casing which was major mistake because I cannot get it to rewind so I can put it back. I have all the parts and screws but need someone that knows what or how to put it back so I can use it. It is almost brand new. Had another like it last year but was robbed and it went with the thieves.
Went to weedeater website and found a picture on how it goes back together
Posted on Oct 11, 2008
Was attempting to start blower for second time this season and cord would not pull out like it did. I tried several times and when it did pull out I noticed the spring had come undone. I took off the casing which was major mistake because I cannot get it to rewind so I can put it back. I have all the parts and screws but need someone that knows what or how to put it back so I can use it
Posted on May 25, 2009
Pull cord binding when mounted on engine but not when removed from engine
When you assemble the Recoil Starter, push it down onto the blower easily and then pull the cord slowly. It should drop into position as you slowly pull the cord.
May 07, 2015 | Poulan Garden
Starter cord pulled out of the housing, it
if it's new take it back should have a one year warrenty on it if yo can't get it done for free get back to me so I can help you you may have a damaged windind head.
Apr 14, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Need to Disassemble a Poulan Pro leaf blower
there are holes on top of the bore assembly you fit a allen wrench which is a t handle you can loosen them or tighten them with them if you can take it out put some locktight on the threads and tighten them down tight with the t handle sould take care of your problem
Nov 03, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I have a Poulan gas blower that will not start. It is getting fuel, I have replaced the plug and coil. It looks like it has a weak spark, but does spark. Will not even fire with starting fluid.
Compression is zero, huh? Well the only thing that could cause that is the piston ring is stuck so that the right pressure never builds in the cylinder. These Poulan blowers are fairly easy to take apart, the hardest part is getting the plastic frame back together...lol! Keep me posted on your progress, parts are easy to get for these blowers. My suggestion to you is order a new piston ring and a gasket kit. Once you take it apart you will have to replace the gaskets and seals.
Oct 22, 2009 | Poulan Featherlite Gas Blower, with Low...
Moby bladez pull cord spring out how do i assemble it
The only trick to getting this back together is patience and determination. You must keep the spring flat as you wind it tight.
Jim
Jun 09, 2009 | Poulan 12a Elec Blower/Vacuum
Poulan pro leaf blower doesn't start
As long as it has fire, all you need to do is:
Check the fuel lines for cracks/breaks. If this is o.k., then you will need to disassemble the carburetor and spray with carb. cleaner. Use a Den Tek Brush,
(http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Make sure the small screen in carb. is free of debris.
If you still have trouble after this, then you will need to buy a carb. kit and replace all appropriate parts.
Jim
Jun 06, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Logo
849 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
