Question about Samsung Blackjack SGH-I607 Smartphone
Send button The left soft key send button stopped working. What can I do, am unable to send text messages.
  • 805PRINCESS Jan 01, 2009
    I HAVE THE SAME PROBLEM WIT MY PHONE I CAN'T SEND BUT I CAN RECEIVE..EVERYTHING ELSE SEEMS TO WORK XCEPT SENDING TXT MESSAGES!
  • camilis89 Jan 29, 2009
    My left soft key, the 0/+/space key and the * key on my phone dont work! I've tried everything!
Use the enter button above the text message key on the bottom right of the keyboard
Posted on Oct 14, 2008
How do I text with Samsung Gusto 3 flip phone.
Create and Send a Text Message - Samsung Gustoâ„¢
  1. From the main screen, press the left soft key to choose Message.
  2. Select New Message then press OK.
  3. Select TXT Message then press OK.
  4. Enter the desired 10-digit mobile number(s) or email address(s) then press OK.
  5. Enter the message.
  6. To add a graphic, animation or sound:
    • Press the right soft key to choose Options.
    • Select Add then press OK.
    • Select a category (Graphic/Animation/Sound) then press OK.
    • Select an item then press OK.
  7. Press OK to choose SEND....
  8. try this.
Nov 22, 2016 | Samsung Cell Phones
My Nokia N95 Cellular phone wont send ani messages , can you help me fix it please
Go to
menu - messaging
select options (left soft key) - settings - text messages
select message center in use
Change the current message center and choose another one and try sending messages.
This issue is common if u change the SIM
Dec 27, 2010 | Nokia N95 Cellular Phone
Can you save a text template to be put on your texts every time
Yes, it is actually called a signature. Go to your message settings and you should see signature option, select that and then add the text you want to be on your messages. But make sure that your signature is turned ON in your message settings. Hope this helps!
Mar 28, 2010 | Samsung Propel A767 Cell Phone
Samsung Propel A767 left and right soft keys not working
Hi I have the same problem and took it for repair, Its the flex cable, parte of the cable was broken and the area that was broken was the softkey area. It case me $40.00 to be repaired
Feb 15, 2010 | Samsung Cell Phones
Cant send or recieve Text messages.
i have one but it mite not work
try
pressing menu key
go to messages
press the button inbetween the soft keys up top
scroll to message setup
then go to where it says "Use GPRS" and change it to no
It worked for me.
Mar 28, 2009 | Motorola Mobility RAZR V3
HARD RESET MY 02 XDA SMARTPHONE
To perform a hard reset
1. Press and hold the Left SOFT KEY and the Right SOFT KEY, and at the
same time, use the stylus to press the RESET button at the lower left
2. Release the stylus, but continue pressing the two soft key buttons.
Release them only when you see the following message on your
device screen:
“Press Send to restore manufacturer default, or press other keys to
cancel.“
3. Press send on your device.
Jun 01, 2008 | O2 Xda Orbit Smartphone
Text is stuck in my outbox
I had this same problem. Deleting and clicking "yes" at the warning screen would not remove the message from my outbox and the message kept resending for days.
Solution: In the Outbox, click "Menu" > Empty Deleted Items. Click "yes" at the warning. The message should now be gone from your outbox and your text buddy should now be able to regain sanity.
T-mobile credited back the resent text messages when I called them.
May 04, 2008 | T-Mobile Dash Smartphone
How to send picture msg
Here's how send a picture in a message.
1. Press the Center Select Key
2. Press the Navigation Key to scroll to Messaging, and press the Center Select Key
3. Press the Navigation Key and scroll down to Create Message, and press the Center Select Key
4. Press the Navigation Key and scroll down to New MMS Message, and press the Center Select Key
5. Press the keypad to enter desired text
6. Press Options, by pressing the left soft key
7. Highlight Insert, and press the Center Select Key
8. Highlight Picture, and press the Center Select Key
9. Press the Navigation Key and scroll up or down to the desired picture
10. Press Insert, by pressing the left soft key
11. Press Send To, by pressing the right soft key
12. Press the Navigation Key, and scroll down to desired contact, and Press the Center Select Key
13. Press Send, by pressing the right soft key
You can find this, and other helpful stuff at
this page on the Motorola Support site
Don't forget to rate this solution once you've tried it !
Apr 17, 2008 | Motorola Mobility SLVR L7 Cellular Phone
How do i set my autosignature ?
ok on cingular/at&t its not possible but there is a ghetto way of doing it go to ur quick notes and go down 4 lines then type what u would want as your autosignature then when u get done typing ur message press insert>then go to quicknotes then choose what u wanted as ur autosignature then send.
Jan 28, 2008 | Motorola Mobility RAZR V3
Text messages
Hi, Hi-Tech people! I got a Motorola RAZR V3, my problem starts when everytime I press the keys to type a message...it HANGS. Once it HANGS, I can't type anymore and continue the message I suppose to write. It wont move no more. It just STUCK-UP right there on the last letter I'd pressed. I have to take-off the battery at the back to re-start the unit again. Then, start typing again...same thing happens. It just HANG by itself and I can't press other keys no more.
Any HELP?
MannyQ
Jan 21, 2008 | Cell Phones
Samsung Blackjack SGH-I607 Smartphone Logo
89 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
