The microwave does not heat. It came programed at a certian temputure, but I do not know what it was or in what sequence I follow to reprogram it so it will cook?
If the '80s' you mentioned means the period of manufacture, the most common problem is the failure of the magnetron (that actually does the cooking), the high voltage diode that supplies the rectified voltage to the magnetron, or a fuse that has failed from metal fatigue (expanding and shrinking as current flows through or ceases).
With the cost of labor (if you have any surviving techs around) and the cost of the replacement parts (magnetron $30-$60 US) or the diode (<$10 US) it is questionable if repair makes any economical sense; you might consider replacing it.
