Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Newer kenmore elite trio refridgerator not cooling
I have a Kenmore (model beginning with 596). For the past several days it has mode a noise every two or three minutes that lasts for 10 seconds, then shuts off again. I thought nothing of it, but this morning I noticed everything in the freezer was thawed, and the fridge section is not very cool either. Any suggestions? Help?
  • 4 more comments
  • Anonymous Oct 17, 2008
    I have the same problem. What are the causes of the fridge and freezer not cooling?
  • Anonymous Nov 11, 2008
    I have the same problem. I think maybe it is the comrpessor?
    I have the same problem. I think maybe it is the compressor?
  • jmn13154 Nov 29, 2008
    I have the same problem and YES it is the compressor. Had a repairman come to the house. He advised me to just get a new refrigerator. Not very happy as it is only 4 years old. Won't make the mistake of buying a Kenmore anymore
  • Anonymous Dec 04, 2008
    my unit is only ablut 4 yrs old, we just moved could that have anything to do with it??
  • mtsolutions Feb 10, 2009
    I have a Kenmore Elite Trio purchased in 2003 Model# 59673503200 with the same issue. I hear a clicking sound every 10 min or so and then nothing happens, compressor does not turn on. Both Freezer and Frig are not getting cold. Fan is running and I cleaned out the condensor. I am awaiting repair persons diagnoses.
The repair person came and in my case it was a start capacitator connected to the compressor. When he replaced the start capacitator the compressor came on immediately and started working. The charge $ 240 (Flat Rate) for the fix. The repair person told me its a universal start capacitator which I found online for $29. Worth trying to fix yourself before paying $240 if your a handy person.
Posted on Feb 10, 2009
  • 61 Answers
There are a number of things that can be at fault but the onlt thing you can try is check and see if the condensor under the fridge behind the front kick plate is plugged with dust . this neads to be cleaned at liest four time a year depending on how dusty its getting . also enshure the fan that circulates air around this condensor can be heard running with the compressor. short of all this you should have it looked at by you local repairman. use the recomended woranty repairman only. hope i was of help . post feadback thanks
Posted on Oct 20, 2008
Elite Trio. What caused it to die suddenly after only six years?
I was going to explain a device called a "defrost timer", but I did a search on your fridge and found the following important information for you to check on FIRST!
CPSC Maytag Corporation Announce Recall of Kenmore Elite Brand TRIO Model...
Info on Recalled LG and Kenmore Elite Trio Three Door Refrigerators
Oct 01, 2015 | Kenmore Refrigerators
How do I take KENMORE ELITE TRIO 596.75533400 out of demo mode?
Try pressing ultra ice and home while the refrigerator door is opened,or ultra ice and the refrigerator pad with the freezer opened. Hold for five seconds. Hope that works.
Jun 12, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
Kenmore elite trio 596 73503201
This happened on my side-by-side. There is a damper at the inside top of the refrigerator compartment that was failing to open to allow cold air in. I took the cover off and propped open the damper while I ordered the part and waited for it to arrive. Problem solved and hope to keep it running another few years.
Nov 13, 2013 | Kenmore Refrigerators
Kenmore/Elite Model 795.7756,7757 Trio: Bottom Freezer Door won't close. The latch or hook at the bottom corner of each side will not hook in.
We have a kenmore elite refrigerator modle number- 795 7756,7757 and it has been making a humming noise very constant now after two weeks, what could it be?
Sep 18, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
Kenmore Elite Trio 795.77563600 Ice Maker Not Working
Try putting ice inside instead. if the machine gives you water then it's converting in reverse order.& still working. put the machine upright & youi'll get ice...
Jul 29, 2010 | Kenmore Refrigerators
Kenmore Elite Trio Fridge Not Cooling
check the over-load/contactor on the side of the compressor,remove it and shake it if it rattles,replace it
Nov 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
1 year old Kenmore Elite Trio Refridgerator not cooling
There are a lot of things that could be the source of the problem... is there no cooling at all going on in the freezer? Is the back wall of the freezer cold? It could be anything from a fan, to the compressor, to the control board... you need a technician.
I would get on the phone with Sears, and explain the continuing problems you have been having, and they may agree to cover service.
Jul 26, 2009 | Kenmore 73503 Stainless Steel Bottom...
Error message
Hello gravyblast.
Welcome to Fixya.
You said, your Kenmore Elite Trio, model 795.7756 or 7757 has an error message simply reading ER IF. No pressing of buttons, or combination thereof changes anything. Also, the ice maker has stopped working although it is turned on.
Can anyone help?
I cannot pull the refrigerator out to unplug and reboot it, thus I don't know what to do.
Try tripping the breaker off for 5 minutes and then see if this method resets the system?
Do not turn it back on for at least tree minutes. That's why I said, Five!!!
Lets see how it resets while I look your fridge up.
Write back. Huuum
7:11 pm eastern standard time . I'm here!
Sep 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite Trio 596 73503200
Did you ever get the problem fixed with the compressor noise
Nov 05, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
939 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
