Question about Mitsubishi WD-62525 62" Rear Projection HDTV
WD-62628 Mitsubishi DLP
What does a NORMAL Power Board look like? Do you have a photo?
  • Mitsubishi Master
  • 19,396 Answers
Here is the picture for a Mitsu62525 power board, which is similar.
You recognise it because you get power cables innesting into the power board.
If you decide to work on your TV, get the service manual first.
Posted on Oct 10, 2008
Mitsubishi wd 62628 flasing timer but no error detected. whats up with this t.v.?
Main digital board fault. Check and replace it contact any service technician. If you wish to get more details visit the site linked here.
Feb 25, 2017 | Mitsubishi Televison & Video
Mitsubishi WD-62628 power shuts off!
You most likely have some faulty capacitors on the power module. You can easily identify a bust capacitor. They will have swollen tops. Here is a sample pic:
Check the specifications of the faulty capacitors, and getthe replacements from your local electronics shop. If you are comfortable withthis, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out thedefunct capacitors. Once that is done, solder in the new capacitors carefully. Ifare unsure how to do this, try to get a friend who knows this kinda stuff to doit for you, or get a qualified technician.
Warning: If you do not have a background inelectronics repair, or are inexperienced, get a qualified technician to do itfor you.
REMEMBER there are very dangerous voltages inside a TVthat can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECTTHE POWER BEFORE YOU DO ANYTHING.
If you want to go in for a long term solution, youcan easily replace the whole power board. You can get spare from HERE.
They also offer FREE online technical advice as you do the DIY..
Hope that helps!
Oct 03, 2008 | Televison & Video
Wd 62628 lamp indicator light is solid yellow / orange what needs to be done
Your lamp cover is not installed. That is what causes the LED to light amber. Remove and re-seat the lamp cover door. There is a switch it hits to tell the TV the door is shut. This is to protect you from electrocution.
Sep 13, 2016 | Mitsubishi 915P026010 LAMP WD-52627,...
My television is as the photo shows like this when I turn it on. I turn it off and on again then it it normal picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 19, 2016 | Televison & Video
My printer has no power i have changed the fuse on the plug but still no power. Does the printer has a fise and where please
It should have a fuse on the internal power board so look at where your power cable enters then you should see glass fuses, check them and you can normally see if the thin wire inside has split or if the fuse has turned black.
Mar 04, 2016 | Canon PIXMA MP210 Photo All-In-One Printer
Swing motor not working
These are quite easily damaged and sometimes just wear out. The cable from the motor can also be easily damaged. They are cheap and easy to replace. Just source a new one for that model online. When you receive it, turn off power to the system, take the front cover off, unscrew inside tray from cover box, slide tray out, remove the power box, get access to the motor and replace. Be sure to check which wires go where before removing and take photos or make accurate diagrams with color codes. Check that the control board functions normally before purchase though. A faulty board could cause this fault.
May 04, 2014 | LG Electronic Window Air Conditioner
Mitsubishi WD-60638 firmware
Make sure software was in top menu in USB stick. Not ib a folder. Try reset buttons on front of TV. Could be bad e2p module. (boot firmware.)
Mar 30, 2014 | Mitsubishi WD-60638 DLP TV
My Whirlpool Refrigerator ED5PVEXWS Not Getting Cold. We got up this morning and everything in the freezer melted. We bought it in November. it still gets power the lights are on inside. still under...
First thing I would consider is the=> W10135899 Defrost Control Board The first thing that stops is the compressor and fans most times when they go bad. You can find this board here=> ED5PVEXWS00 Control Panel Your control panel is found above the top shelf inside the fresh food compartment. Just unplug the power to refrigerator and lower the panel and where part 6 is in the photo is where the board is located. Most times when these boards burn out it creates this problem you described. Replacing that board should get you going and back to cooling normally. I will be here if you have other questions, Thanks, Sea Breeze
Apr 23, 2011 | Refrigerators
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
433 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
