ONBOARDSOUNDCARD my onboard sound card appears not to be working.it reports that I have a problem with my Audio Controler.what should I do.
    Brigadier General:
  • 3,614 Answers
You need to install the device driver of your sound card.. if you have a installation driver of your unit, you need this to install again your audio..
let me know, if you still need more assistance on your problem.
cheers
Posted on Oct 10, 2008
How do I test the Sound card when the Control Panel sound states no audio device?
You should check in Device Manager to see if your audio driver is installed and working properly. If not, reload it. You could also check in the BIOS setup to see if the onboard audio has been disabled. There is also a possibility that the onboard audio has failed. You can order a sound board to install in the nachine to restore audio capability. Just disable the onboard audio in the BIOS, install the card and load the drivers supplied with the card. Hook your speaker to the jacks on the new card and you're back in action.
Dec 06, 2013 | HP Pavilion a705w PC Desktop
My new Vidwo carde disabled my PC sound jack, but I have audio from my USB headset. How do I get my audio jack and external speakers to work.
Find and Try reinstalling Driver for onboard audio look in device manager and see if there is an exclamation mark next to your sound hardware, also there maybe an audio out jack on your vid card that has priority over your onboard since its hd
Jun 19, 2012 | Compaq Computers & Internet
After system restore sound card wont work
Removing the sound drivers In Windows XP, click Start , and right-click My Computer .In indows 95, 98, and Me, right-click the My Computer icon on the desktop.Click Properties from the list that appears.In Windows XP, click the Hardware tab, then the Device Manager button.In indows 95, 98, and Me, click the Device Manager In Windows XP, click Uninstall (the small picture of a computer overlaid by an X In Windows 95, 98, and Me, click Remove .Click OK when a warning window appears.Continue to remove sound devices that relate to the audio card brand (not Legacy) until all have been removed. If the device is a combination sound-modem card, remove devices related to the brand name listed under Modem as well.Close all programs and turn off the PC.Back to top Step 2: Disabling on-board sound Skip this step if the PC does not have onboard sound. If PC does have onboard sound, do the following to disable it Turn on the PC and press the F1 key repeatedly at the first logo screen. "Entering Setup" should appear on the screen.In the Setup screen, press the LEFT and RIGHT ARROW keys to highlight Advanced. Press the DOWN ARROW key until Onboard Audio , Onboard Audio Options , or I/O Device Configuration is highlighted, press ENTER .If another menu appears, press the DOWN ARROW key until Onboard Audio codecs or Audio Codec is highlighted, press ENTER .Press the DOWN ARROW key until Disabled is highlighted, press ENTER .Figure 2: Example of one possible Onboard Audio BIOS setting Press F10 , then the Y key, to save the settings and exit.Turn off the power and continue to Step 3.The edges of metal panels can cut skin. Be careful not to slide skin along any interior metal edge of the computer.This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a noncarpeted floor, use a static dissipative work surface such as a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.Unplug all cables except for the power. Write down each cable location if you do not already know where it connects.Unplug the power cable and with the power cable removed press the Power button on the front of the PC.Remove the screws on the rear of the PC.Figure 3: Side Panel screws (your PC may be different Slide the side panel off from the rear of the PC.Figure 4: Side Panel removal (your PC may be different Step 4: Removing the sound card Use this section to remove the sound card. If the PC was using onboard sound and you do not have to remove it, skip to Step 5 .Locate the sound card inside computer case. Use the speaker connections on the back as a reference. Disconnect any cables that are plugged into the back and sides of the sound card. Carefully note where each cable was installed.Remove the one screw that holds the sound card to the chassis. If a metal plate covers up the screw, then remove this plate first.Figure 5: Screw that attaches card to case Grasp the sound card by its edges and slide it out of its slot.Figure 6: Card removal If the sound card is a combination sound-modem card, disconnect all cables from the modem and remove it in the same way that the sound card was removed.5: Installing the sound card Insert the new sound card into an open compatible slot. If you have a sound-modem ombination card, insert the new modem card into an open slot as well. Attach the card or cards with one retaining screw. Replace the metal plate if it was used.Connect all the cables back to their original positions : Replacing the cover Replace a side panel by matching the side panel tabs with the tab openings in the case. Figure 7: Side Panel tabs (your PC may be different Insert the side panel and slide it forward.Figure 8: Side Panel insertion (your PC may be different Fasten the screws to secure the side panel.Figure 9: Side Panel screws (your PC may be different Installing the software and drivers for the new card s Connect all cables and turn on the PC Use the software installation instructions that came with the new sound card to install the software. Normally a CD is inserted after Windows finds the new hardware and displays a message.If the new sound card is a replacement for an original card that came with the PC, Windows should find and install the software automatically. If needed, you can install/reinstall the sound software using the HP Application Recovery software that came with your HP or Compaq PC.Original and updated drivers may also exist on the HP Website. After installing the original driver, go to Software and Driver Downloads site and enter your PC model number to find software and driver downloads.f a window appears stating that it needs help finding particular files, place the driver disc from the soundcard manufacturer into a disc drive. If this does not help, browse to the following pathnames, one at a time, until the file is found: C:indows\inf
C:\Windows\options\cabs
C:\Windows\system
C:\Windows\system32
If the files under these pathnames do not appear, open the C:\ from My Computer . Click Tools , Folder Options , and click the View tab. Remove the checkmarks from Hide protected operating system files , and select Show hidden files and folders . Click OK .Restart the PC and test for sound.
Nov 02, 2011 | Creative Labs Sound Blaster Live! 24-bit...
I recently purchased a new M-Audio Audiophile 192 sound card but I cannot get it to work, I don't hear anything coming from my speakers (M-Audio AV40s), which I know are working because I tested them...
This could be that the Onboard Sound Card is turn on in the Basic Input Output Settings, these control wich devices start and run when you computer is first turned on. Commonly known as the BIOS there very often is a setting in there for the sound to come from the onboard sound card or the one installed seperately. You must access this setting when you first sstart your computer, and switch it to disable onboard sound.
Sep 16, 2011 | M-Audio Audiophile 192 Sound Card
My computer can't hear sound
Right click my computer click property then click hardware click device manager then right click multimedia audio controler click property check device status then follow instruction,you can see if your audio controller is ok or you need to install audio card..
May 16, 2011 | Intel D915GAG Socket 775 Motherboard -...
No sound
Please install / re install the driver and check back the sound.
Regards, Jay
Feb 26, 2011 | Computers & Internet
Windows XP SP3 platform with single Delta 66. Record audio works fine but I'm unable to hear played back audio through computer. It appears onboard audio card disabled. Any suggestions?
Go to Device Manager and enable the audio card.
If you cannot enable the audio card or it is not working then install the audio driver again.
Mar 30, 2010 | M-Audio Delta 66 Sound Card
Avance ac'97 audio for via audio controler
You should be able to use the AC97 codecs available from Realtek for your device. There is a choice of two - standard AC97 or AC97 HD (both are available from the link provided), one of these should be compatible.
Post your results here, especially if you encounter a problem installing the drivers or if this doesn't fix your problem.
Apr 10, 2009 | Computers & Internet
No audio output
Is the audio device onboard, or do you have an addon card? If it is onboard, I will need the make and model of your computer to find the driver.
Apr 10, 2008 | Creative Labs Sound Blaster Live! 5.1...
Onboard sound doesn't work
click search, then type dxdiag, click the sound tab and a diagnostic programme will check your sound driver and report any faults
Sep 26, 2007 | Asrock P4VM890 Motherboard
Computers & Internet Logo
David Payne
David Payne
