Question about Kenmore 24 in. 15079 Built-in Dishwasher
Buzzing sound There is a loud buzzing sound the whole time the dishwasher is running. Dishes come out clean and it goes through all the wash cycles.
  • pinkeysue Oct 10, 2008
    It sounds like most of the noise is coming from the bottom of the dishwasher. Isn't the control/timer module located in the upper part of the door?
    Scholar:
  • 195 Answers
It could also be a bad water valve !
Posted on Nov 30, 2011
  • 1,031 Answers
  • Check the spray arm for damage and obstructions
  • Check the inlet filter screens
  • Test the water inlet valve
  • Check the motor and mounts
  • Check the fan motor and blade
  • Check the drain for obstructions
  • hope this helps
  • Posted on Oct 10, 2008
    • Kenmore Master
    • 19,396 Answers
    A loud buzzing sound it is probably a faulty control/timer module.
    If the appliance works the same, you can keep it like this, if it still under guaranty, call the number listed on the owner manual to get repair.
    If you got the sound only recently, that means that the control is going to fail soon, in that case call a repairman and have the control assembly replaced.
    You find diagrams and parts here,
    just enter the model number.
    Dishwasher dishes cloudy and makes loud buzzing soundf
    I am not sure about the buzzing but cloudy dishes is caused by
    hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
    Jan 03, 2013 | Whirlpool Ultimate Care II LSQ9564J Top...
    I have an kenmore elite "ultra wash" model 665. not sure the rest.. about 7/8 years old, making loud buzzing sound during wash cycles,starts about 5 minutes into the normal wash cycle. i removed the inlet...
    I have the same problem as those who stated their dishes are not getting clean. If you listen to the wash cycle you should hear water sloshing around inside. If you hear just a humming sound the washer has no water. I have this problem. I had a tech come and he told me the water is syphoning out my drain and I need to change my plumbing, then he charged me $65. I have lived in this house for ten years. 6 with the washer that came with house and 4 with this Kenmore Elite. This problem started about 6 months ago. So what I have been doing is opening the door, after the humming starts and the sloshing stops, and adding about 2 L of water. It seems to wash just fine after that.
    Jan 12, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
    Buzzing Sound at Base of Unit does not go away
    If everything is working as it should - the problem may be with the motor.
    Either the starter is starting to fail, or it may have gotten wet. Check for leaks around the base, and be prepared to eventually replace the motor.
    If you can deal with the humming, there is no reason to replace it at this time, and there is nothing you can do to quiet the noise.
    Thanks for using FixYa!
    Nov 02, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
    Our Frigidaire Ultra Quiet II dishwasher loud buzzing noise- wash
    No longer "ultra quiet" huh?
    A sound during certain cycles indicates a broken part. By the information provided sounds like a pump may be the problem. You may need to contact a service tech about this issue. If the appliance still under warranty, the service should be provided for free.
    Every time when you hear noises (other than the normal ones) in the appliance, it indicates there is something wrong and it will worsen over time, so as soon you hear something is not ok, get assistance.
    Aug 30, 2009 | Frigidaire Dishwashers
    Loud Buzzing Sound from Dishwasher
    have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
    Jul 30, 2009 | Dishwashers
    Loud Buzzing noise
    Sounds like something may have got past your filter and is touching the main pump impeller eg piece of broken glass or piece of plastic.I,ve even seen a spoon touching the impeller. You may have to take the bottom off the machine and remove the pump if you can,t see anything under the filter,Hope this helps. Regards Stefan.
    Jul 08, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
    Kenmore elite dishwasher making loud buzzing sound when washing
    it sounds like a broken empellar in the pump like there is a piece of it broken off and ratteling around in there... change the empellar
    Feb 21, 2009 | Dishwashers
    Our dishwasher is making a loud noise during wash cycle.
    if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
    Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
    Buzzing noise and won't clean
    An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.or may be its due to
    Heater fanIf the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
    Jul 16, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
    Kenmore dishwasher "sensing" light
    the sensing light and buzzing are normal let it do that on its on then let me know what happens its a soil sensing light and is supposed to run a cycle on its own to clear it but lets see .we will go from there ok
    Jan 17, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore 24 in. 15079 Built-in Dishwasher Logo
    429 people viewed this question
    Top Kenmore Dishwashers Experts
    Ken Johnston
    Ken Johnston
    Level 1 Expert
    Fred Sops
    vince
    Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
