Question about Canon PIXMA MP160 All-In-One InkJet Printer
Need to change inkjets
When I open the lid to change the inkjets, they are on the right hand side underneath. How can I get them to re-position properly. Also, I have just changed the inkjets a short time ago, and print very little, so I'm disappointed in the short life.
    Sergeant:
    Champion:
  • 331 Answers
The short life may be due to the qualiy of prints..............
when u give the printcommand the inkjets move towards the rigt handside then u can remove them.....
Posted on Oct 11, 2008
The instructions tell me to lift the lid, but I don't know how, it seems to be locked, is there something underneath I need to push or pull. I need to change the ink cartidges
On this particular printer there is no locking mechanism to access the ink cartridges. In order to open the cover, use a single open hand and place your fingers just underneath the screen on the front, and pull upward. The entire scanner piece should raise and a plastic bar on the right-hand side will lower down to prop it open.
If you're having a lot of trouble opening it, you may want to check around the sides of the printer to see if there is any tape leftover from when the printer was packed in its original box. When they ship a printer it is always covered in tape to make sure that nothing falls open or breaks before it's delivered, and there may be a piece of clear (almost invisible!) tape left over preventing the printer from opening.
Once it's open, the ink cartridges should come to the middle. Press down on the small lever on the print head (the ink cartridge holder) to pop the cover open so that you can install the cartridge.
Hope this is helpful!
May 09, 2011 | Lexmark P6350 All-In-One InkJet Printer
Printer will not scan ( says scanner locked) it is not locked also will not copy from glass either
Open the latch on the front of the unit above where the paper comes out, underneath the lid on the right side is an orange switch. Flip the switch, turn off the until, wait about a minute and turn it back on. The scanner is physically locked by this switch. I believe the proper position for unlocking is towards the front of the unit, but the diagram is underneath the lid next to this orange switch.
Jul 12, 2010 | HP OfficeJet 9120 All-In-One InkJet...
My machine won't drain. Had it on its back while moving.
look under neath for a belt tension pulley spring off, or unhooked
Jan 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Ink cartridge cradle will not move from right hand side
on right hand side there is adjusment lever just press it . this will move the cartridge
Feb 07, 2009 | HP DeskJet 970cse InkJet Printer
Out of ink. Can't get cartridge to stop in middle to change
hi turn off the printer open lid move cartridge carrier to the middle, this should allow you to change the cartridge, then close the lid and turn on printer this should reset carrier to home position.
Jan 15, 2009 | HP DeskJet 810c InkJet Printer
Clear carrier jamed
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Oct 20, 2008 | Dell 924 All-in-One InkJet Printer
Clear the carrier jam
Solution:
Sep 01, 2008 | Dell 942 All-In-One InkJet Printer
Dell Printer carrierjam
Solution:
Aug 31, 2008 | Dell 942 All-In-One InkJet Printer
Cartridge stall message
Solution:
Apr 07, 2008 | Dell 922 All-In-One InkJet Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
old marine
old marine
