Question about Samsung Televison & Video
Samsung LE26A LCD Television
What are the best picture settings for Samsung LE26A 26" television
boonys
  • 21 Answers
SOURCE: No Picture or Sound from ASTAR 32 inch LCD Television
Google Allelectronics or Hosfelt Electronics for these caps
I just ordered these at a good price but ordered 35Volt instead.
Also replacing 3300uF caps too as they are bulged at top.
Hope this fixes it. Will let you know.
Posted on Jan 21, 2008
oicur12
  • 31 Answers
SOURCE: Samsung LE46F8 picture setting
It sounds like your TV is in Shop Mode.
Shop mode is a set of picture parameters that have been optimized for a store showroom or display floor. Shop mode does not allow you save any picture settings such as brightness or contrast.
To get the TV out of Shop Mode press and hold the Menu button on the front panel for three seconds, the picture will blank momentarily then reappear with “Dynamic Mode” shown on the screen. At this point the picture parameters can be changed and saved.
Posted on Feb 17, 2008
SOURCE: samsung tv settings
Freeview Built-in Tuner
Picture Mode: Standard
Contrast: 85
Brightness: 53
Sharpness: 25
Colour: 45
Tint: 50/50 (Greyed Out)
Colour Tone: Cool1
Detailed Settings:
Black Adjust: High
Dynamic Contrast: Off
Gamma: 0
Edge Enhancement: On
White Balance:
R-Offset: 17
G-Offset: 15
B-Offset: 11
R-Gain: 7
G-Gain: 14
B-Gain: 30
Backlight: 10
Digital NR (Noise Reduction): Auto
Active Colour: Off (Greyed Out)
DNIe: On
Movie Plus: On
Sound Mode: Music
SRS TX XT: On
Game Mode: Off
Energy Saving: Off
Posted on Jun 03, 2008
  • 3 Answers
SOURCE: my samsung 40
This tv has issues with 4 capacitors. These caps can be replaced for about $10. They are located at the top right corner of the power supply. They will read 10v,1000uF. I had the same problem, then I replaced them wit 16v,1000uF capacitors. And presto tv!
Posted on Jul 19, 2009
  • 5 Answers
SOURCE: N2635w 26 in. LCD Television: help me unlock my viewsonic...
try pressing and holding one of the "channel up" or "channel down" buttons for 5 seconds or more... While holding the button, you should see a progress bar that indicates "menu locking" or "menu unlocking". That should fix your problem...I found that out by accident on my TV.
Posted on Sep 10, 2010
There is a Video problem with my Samsung LCD. The sound is clear but Colour Balance Setting is disturb. The Colour is mixing with each other. Can You tell me the procedure for My TV Setting?
Before you set up try a reset
Resetting The Picture And Sound To The Factory Settings
as far as advanced settings are concerned, set the contrast backlight and brightness so you can see the best blacks without it looking too milky, the best whites so you can discern the whites and they aren't clipped, then look at colour balance if it looks wrong when you turn the colour off.
it shouldn't be very far out in factory settings. Operation How To Change The Picture Settings On Your LCD TV LCD TV...
May 12, 2014 | Samsung LN-S2651D 26 in. LCD Television
Protron PLTV-6 television. Has audio, shows picture very briefly when changing channels, then blank
The tv have a long board call the LCD inverter board.This long LCD inverter board is dead.This long LCD inverter board job is to help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a long LCD inverter board for the replacement.
Oct 18, 2010 | Protron PLTV-26 26 in. HD-Ready LCD...
My plasma samsung model sp r4212 the screen goes black you can still hear and when picture comes back on there is also a buzzing sound
press the center power button for about 30 secs verify that the video cables are plugged in and try a different set of cables. If not unplug tv for 2 mins.
GOOD LUCK.
CNBY
Jun 03, 2010 | Samsung LN-S2651D 26 in. LCD Television
Have snowy picture
Try hooking up a DVD player to the set. If you get a picture and have sound then you might have a issue with the source you are trying to watch. If no source inputs work the you might have a bad main bd. Have a trained Samsung tech troubleshoot the tv.
Jul 08, 2009 | Samsung LNR2668W 26 in. HD-Ready LCD...
Samsung 26 ' 450 series cracked lcd picturescreen no picture
The LCD panel can be replaced but the cost of it will be as much, but usually more then the set. Average cost for a 26" panel is about $400-$600 not including installation.
May 26, 2009 | Sony BRAVIA KDL-46V3000 Television
"Weak or No Signal" message on Samsung 26" LCD TV
I pressed mute on my television and about 5 minutes later it said weak or no signal.What do I do?
Feb 24, 2009 | Samsung LA26R71BD 26 in. HD-Ready LCD TV
Television won't turn on
Hello Missy_71269,
You have a bad convergence board. Replacing this part will fix your set. The part # AA95-00422A. You can purchase it at: http://www.partstore.com/Part/Samsung/Samsung/AA9500422A/New.aspx
Best regards
circuitcity
For additional help Chat live with ma at: http://www.assistrepair.com
Jan 12, 2009 | Samsung LN-T4665F 46 in. LCD Television
Samsung LE26R73BDX 26" HDTV-Ready LCD TV
lcd screens are usually a costly part of the televison yu could check with the samsung service centre in your city
Oct 15, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Best Picture Quality
The set may not be at fault. If you are on cable some channels are still in anolog and some are digital. if you are on a nolog channel the picture will look preaty bad compared to the digital ones.
May 09, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Televison & Video Logo
202 people viewed this question
Henry  Thomas
Henry Thomas
